Author Topic: CB500 DIY Preload Spacer Question  (Read 1277 times)
Offline Hrvatski Medvjed
« on: September 29, 2013, 08:43:07 AM »
Greetings,
I have a 73 500 that's a bit mushy up front and I'd love to add some DIY preload spacers when I change out the fork oil to a heavier weight. I've done a few searches but can't seem to locate a simple "how to" for completing this task. Surely someone out there has done this to their bike...
Any info is much appreciated. Parts list, procedure, pictures, etc...
Thanks!
"Two Possibilities Exist...Both are Equally Terrifying" - Arthur C. Clarke
Offline thrutheframe
Re: CB500 DIY Preload Spacer Question
« Reply #1 on: September 29, 2013, 09:29:23 AM »
  Start by draining the fork oil and replacing it with the recommended grade and quantity.  Ride it and see what you get.  If you still think it's mushy you can buy PVC tubing the appropriate OD and cut spacers out of that. Start at 1/2" and make 10 (5x2 forks) varying in height by 1/8" up to 1".  Be sure that all of your pairs are equal heights.  Start at 1/2" and go up until you get the feel you want. Make sure you put a washer between the top of the spring and the PVC spacer.  Make sure to take the weight off of the front wheel when you're removing or installing the cap nut.  Report back what your results are.
Be safe.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #2 on: September 30, 2013, 03:36:38 AM »
Copied from Sonic Springs webpage.  I have used this method for a number of years and bikes and it has been pretty solid.
The purpose of the spacers is to provide the proper amount of pre-load on the springs. In general, street bikes need about ¾” of pre-load, assuming that the spring rate is correct for the weight of the bike and rider. So the question is, how do we determine the right length for the spacer?
Take the fork cap, and if it has a pre-load adjustment, set it in the middle. Now measure the depth of the cap from the bottom to the base of the portion that sits against the top of the fork tube. Include any stock washer that will sit on top of the spacer. Basically we’re measuring the length of the portion that fits inside the fork tube.
Say for example that this length is 2”. If we cut the spacer so that with the spring, washer and spacer installed it came up flush with the top of the fork tube, when we installed the fork cap the spring would be compressed 2”. Too much. So we need to cut the spacer shorter to get the proper pre-load. In this case 1 ¼” shorter. Easiest way to measure this is to put the spring, washer and uncut spacer in the extended fork leg. Mark the spacer tube even with the top of the fork tube. Pull the spacer out and measure 1 ¼” down from the mark. Mark and cut from that point. Now, when you put the spring, washer and spacer in, the top of the spacer should be 1 ¼” below the top of the fork tube. When the fork cap is installed, the 2” section inside the fork tube will compress the spring ¾”. Voila, correct pre-load!! Just make sure you use the right numbers for you, not the ones in this example. Also, back the adjuster all the way back out before re-installing the fork cap, to make it easier to get the threads started. Re-set the adjuster to the middle position after everything is bolted back up.
« Reply #3 on: October 01, 2013, 04:51:52 AM »
Thanks for the tips! Last night I did a fresh oil change on the forks and went with a heavier weight oil. This seems to have really tightened things up quite a bit and I'll be heading out for a ride soon. I'll report back on my final thoughts. Thanks again!
