Author Topic: Can I eliminate the solenoid????  (Read 1775 times)
Offline fdbrat
« on: September 30, 2013, 09:57:10 PM »
OK here's the deal. I was thinking about removing the stater solenoid altogether.
I'm thinking if I were to uses an ignition switch with a key that has a momentary switch.
From my research I believe  it would be wise to use 6 aug wire.
From what I understand the purpose of a solenoid is to use a low voltage remote switch to activate and deactivate the starter via the solenoid.
Can any one confirm this?
1975 CB750F
4-4, Dyna S and box
5 ohm coils / 5k ohm caps
In- .05 / Ex- .08
San Luis Obispo
Re: Can I eliminate the solenoid????
« Reply #1 on: September 30, 2013, 10:14:11 PM »
Not unless you want to fry all the wiring and your ass.
The starter takes 180amps THAT IS WHAT THE SOLENOID IS FOR
Offline Pecantree
« Reply #2 on: September 30, 2013, 10:14:22 PM »
Yes
Your 4th sentence is correct.
Put the screwdriver down and step slowly away from the bike and no one will get hurt.
« Reply #3 on: September 30, 2013, 10:18:16 PM »
 I you kick start it only I'd say yes. If you want the starter to work it will need to be a special switch because most (all?) aren't designed for that many amps.
  My opinion is, if it wasn't needed Honda wouldn't have wasted the money putting it on the bikes to begin with.
Offline fdbrat
« Reply #4 on: September 30, 2013, 11:04:29 PM »
I hear your points. And Honda made it as easy as pushing a button on the bars. I don't want anything on the bars.
So... Not possible. Could never happen. Never been done.... :/
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Nic
« Reply #5 on: September 30, 2013, 11:50:22 PM »
If you have an ignition switch like a car with the momentary starter contacts ( if I understand what you're trying to do, or even a separate moment sw, whatever)  then just connect the red yellow wire from the main loom which is inside the headlight ( usually connected to the starter button on the right switch ) to your momentary sw and the other side of the switch to ground n leave the solenoid as is, easy.
Offline fdbrat
« Reply #6 on: September 30, 2013, 11:54:32 PM »
I know where to put the wires. It just bugs me thinking I could get rid of it. Less #$%* to go wrong if there is less stuff. Know what I mean. And all the original wiring is gone.
But okay. I'm not going to get stubborn about this one. :)
Thanx guys.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline spazz1984
« Reply #7 on: October 01, 2013, 12:33:24 AM »
Can I ask you what is your real goal here ?
Do you just want to run as little as possible (headlight, tail/brake light, tach, speedo )
Sent from my SPH-L710 using Tapatalk 2
« Reply #8 on: October 01, 2013, 02:27:14 AM »
you could use one of those big frankenstien knife switches like in the old scary movies for your starter switch?the bike will only start in a lightning storm though?
« Reply #9 on: October 01, 2013, 03:26:43 AM »
There are some threads describing the minimum wiring without the starter. There is also a CB750 chopper forum.
Here some info.
http://forums.sohc4.net/index.php?topic=72169.0
http://www.hondachopper.com/
« Reply #10 on: October 01, 2013, 05:08:29 AM »
LOL!
You could move the switch off the handlebars too.
Offline lucky
« Reply #11 on: October 01, 2013, 07:18:44 AM »
Answer....NO.
Offline vames
« Reply #12 on: October 01, 2013, 08:24:53 AM »
Great idea for shaving weight off your "Cafe Racer" -- you can probably save 1/4 pound by eliminating the solenoid. Every ounce counts when you wanna go superfast!
Next up: Eliminating those pesky and heavy coils. Why can't I just hook the battery directly to the spark plugs and eliminate the coils?
Offline phil71
« Reply #13 on: October 01, 2013, 08:55:51 AM »
I was looking for a 10 foot pole to touch this with, and then I found one. Still, it seemed a waste of a ten foot pole, so I took the open can of worms I found here, tied it to the end of the 10 foot pole, and swung it wildly to fight off the elephant in the room.
Thinking this would also work in an oil thread.
Offline 72 yellow
« Reply #14 on: October 01, 2013, 09:05:17 AM »
Only if you also have a supply of popcorn ready..
Offline 74750k4
« Reply #15 on: October 01, 2013, 09:28:46 AM »
Throw away the side cover (useless Honda junk), and manually close the solenoid with your hand. Presto!
Offline Elan
    • Vital Motor Parts
« Reply #16 on: October 01, 2013, 09:33:01 AM »
If you dont want the button and wiring on the bars, why not keep the solenoid, and put the button somewhere else? headlight? under the tank, maybe in your seat so when you sit, the bike starts right up !  ;)
76 750k
Offline spazz1984
« Reply #17 on: October 01, 2013, 09:39:34 AM »
Elan
The seat one is a great idea. you need a timer to kill the starter after a few seconds.wait now your adding to it #$%*
Offline Pecantree
« Reply #18 on: October 01, 2013, 10:13:10 AM »
We all ask questions that to somebody else seem stupid.
Questions are good. That's how we learn!
Spaz's question "What are you trying to achieve?" is a good one.
Be clear about that and then see where that takes you.
Let's hear your goal.
Steve
Offline thrutheframe
« Reply #19 on: October 01, 2013, 10:14:37 AM »
  You can do it if you eliminate the starter.   The solenoid passes LOTS of current.   Otherwise just stick with what you've got.
'74 cb 750 K4
'75 CB 360T
'90 RC31 Hawk GT
« Reply #20 on: October 01, 2013, 12:31:06 PM »
Eliminate the solenoid?  Sure.  Just search and find; 100Amp momentary switch (200A rating will last longer).  Mount it wherever you want and run your 6 ga, wire to-from it between battery and starter motor terminal.
Look for battery disconnect switches, too.  These aren't usually momentary.  So, don't forget to turn them off after the bike starts.  Smart people never forget, though.
http://www.texasindustrialelectric.com/switches.asp
