Author Topic: Rear Sets solutions  (Read 2112 times)
Offline Matt Hubbell
Rear Sets solutions
« on: August 17, 2006, 09:02:08 AM »
Dose anyone hear have some good ideas about rear sets.
Offline StevieMac
Re: Rear Sets solutions
« Reply #1 on: August 17, 2006, 09:15:58 AM »
Errrr, well, depends what you mean by good ideas?  Do you want to buy them? Make them?  Make something from a different bike fit?
The RASK ones IMO put the pegs a little too high for my liking and they are pricey.
You can buy a set of sport bike rearsets from a wrecker and make mounting brackets to adapt to your frame or you can make your own from scratch.  I made mine.  You can see pics in my gallery.
72 CB500 Cafe
78 CB750 Chopper
Gallery: http://www.sohc4.us/gallery/v/members/personal/StevieMac/
Offline cmorgan47
  • smaller, lighter, quicker
    • theundergr0und
« Reply #2 on: August 17, 2006, 09:23:49 AM »
if you're looking to buy there's some options here and here.
ever since swtching to cafe bars, i desperately need a set on my 400.  haven't yet decided what i'm going to do.
i love babies...
with a nice chianti sauce and a side of fava beans
« Reply #3 on: August 17, 2006, 09:56:06 AM »
Thanks, those are cool rear sets you made Steve, are you a machinist? I can weld, but that is about it.
Offline StevieMac
« Reply #4 on: August 17, 2006, 10:00:16 AM »
Thanks dude.  No, I'm not a machinist.  The pegs are aftermarket sport bike pegs that I modified with a hacksaw, drill bit and tap.
Everything else is just made out of steel.  No fancy tools other than an angle grinder, dinky little drill press and a mig welder.
If you can cut, drill and weld steel you can make what I did.
72 CB500 Cafe
78 CB750 Chopper
« Reply #5 on: August 17, 2006, 10:06:30 AM »
Yeah, that is a very nice job, I like the shifter linkage and the way you set up the brake as well, good thinking. I guess I will have to try an set somthing up like you did.
Offline cmorgan47
    • theundergr0und
« Reply #6 on: August 17, 2006, 10:09:52 AM »
StevieMac, do you know how far back/up those are?
also, you're the guy who relocated the battery under the cowl right?  that's pretty badass.  might try to steal the idea over the winter.
i love babies...
Offline StevieMac
« Reply #7 on: August 17, 2006, 10:33:10 AM »
Half the battle is being willing to try  :)
If you can weld it's really not very complicated IMO.  Let me know if I can be of further assistance.
72 CB500 Cafe
78 CB750 Chopper
Offline StevieMac
« Reply #8 on: August 17, 2006, 10:44:44 AM »
I just ran outside to look.....  Obviously I don't have the stock peg there for comparison but measuring from the center of the motor mount bolt the stock pegs mount to, I'd say:  back = +/- 5.25", up = +/- 1.5"
So not all that high but very comfortable for me actually.  The new pegs don't stick out nearly as far as the stockers so I should have lots of ground clearance.  Not that I'm that much of a peg scraper on the street anyway.
The hardest part for me was probably deciding exactly where I wanted the pegs to be.  Especially since my seat wasn't done and I didn't have the final handle bars yet!   I found an old Motorcyclist magazine that showed the measurements between handle bars > seat > pegs on some popular sport bike.  I measured mine out to try to get close to a CBR600 as I know those are relatively comfy.  Luckily that worked out great!
Yep, that's me.  FYI: Gel batteries are more expensive but they are smaller!
72 CB500 Cafe
78 CB750 Chopper
Offline cmorgan47
    • theundergr0und
« Reply #9 on: August 17, 2006, 12:29:20 PM »
that won you my vote this month.
i love babies...
Offline StevieMac
« Reply #10 on: August 17, 2006, 12:32:02 PM »
72 CB500 Cafe
78 CB750 Chopper
Rocking-M
« Reply #11 on: August 17, 2006, 05:04:20 PM »
Hey StevieMac, wonder about using heim joints and making that linkage adjustable?
Also, the shifter section that mounts to the foot rest, how did you make the pivot there?
With the 77 I have a pretty good block to decide where exactly I want to mount mine,
can you steer me to that article you read? Thanks,
Offline StevieMac
« Reply #12 on: August 18, 2006, 07:38:51 AM »
Heim joints and adjustable linkage are both good ideas but I didn't feel they we're necessary for me.  if you make the linkage the correct length to begin with your all set!.   The holes in my linkage are oversize to go over a sleeve on the mounting bolt so I don't have any problems with binding.
Shifter pivot:  There is a 1/2" bolt coming through the mounting plate that the peg screws onto.  The bolt is welded to the back of the plate. With the peg screwed on tight there is maybe 1" of the bolt shaft still exposed between the peg and plate and that's what the shifter pivots on (the bolt).
I then used a short section of tubing to slide over the bolt.  Then weld the shifter pedal to the tubing.
Article:  That's a tougher one.  Next time I come across the article I'll try to post the info but my magazine collection is somewhat large and trying to find the specific article is probably not something I'll get done in the next bit.  What I can recall is that it was
'Motorcyclist" magazine and somewhere during the mid-90's for a few issues they included those measurements in each bike test and comparison.
« Last Edit: August 18, 2006, 07:40:24 AM by StevieMac »
72 CB500 Cafe
78 CB750 Chopper
Rocking-M
« Reply #13 on: August 18, 2006, 04:30:20 PM »
I guess a nylon washer on each side of the shifter tubing would insure no binding?
or is that necessary? Thanks for all the info.
Offline StevieMac
« Reply #14 on: August 22, 2006, 01:02:20 PM »
I've got the linkage bolts slid through a small section of tube.  The hole in the linkage then slips over the tube.  The tube is slightly longer than the linkage is thick which means I can torque the linkage bolts up as tight as I want and it's only pressing on the tube.  The linkage is still free to move so I have no binding at all.
Hope that makes sense.
72 CB500 Cafe
78 CB750 Chopper
