Author Topic: RE: Gas Tanks You Made Pic request  (Read 4095 times)
Offline chewbacca5000
  • I polish covers!
« on: October 02, 2013, 06:04:06 AM »
I am interested in making a gas and would really like to see some pictures of tanks that members here on the forum have made.  Fibreglass perfered, but metal is fine as well.  Did a quick search and only turned up a couple pics.  Want to use a CB750 tank as a plug and make a copy, also interested in fake tanks in fibreglass or plastic overlays that hide dents.  Kinda like a "hat" for your tank.
Let's see your pics!  Thanks!
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
Re: RE: Gas Tanks You Made Pic request
« Reply #1 on: October 02, 2013, 07:12:58 AM »
I am about to do that with my frigging Dunstal glass tank. I caswell lined it and......dripping gas. I am thinking of just putting a little peanut tank and doing the "hat trick".
Offline lucky
« Reply #2 on: October 02, 2013, 07:15:42 AM »
When you do a search do this:
Type in the words to a search engine like Google.
Then when you get the results(WEB) results then go up to the top of the page and click on IMAGES. There are web results ,image results,and video results as well.
You will see many, many photos.
Offline lucky
« Reply #3 on: October 02, 2013, 07:24:56 AM »
Does not sound like a liner problem, it sounds more like a large hole problem.
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #4 on: October 02, 2013, 08:04:49 AM »
Ethanol in your gas will eat any fiberglass resin away unless you can locate the phenol ester resin somewhere.  One pinhole in your tank liner and you get a leak.  If you read the literature on the liners, almost everyone I've seen either avoids mentioning alcohol related performance, or merely says it's 'resistant'.  Yes, you will find by using Google, that there are any number of alcohol resistant epoxy resins available now...but resistant is not the same as alcohol proof.  The only advertised alcohol proof liner I've seen is from Caswell, and I have no experience with it, but they do say right up front that it's formulated with phenol resin based epoxy.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
Offline KJ790
« Reply #5 on: October 02, 2013, 08:46:59 AM »
Not a CB tank, but here is one I did for an XS650. The tank had some dents in it, but was clean on the inside and did not leak. I filled the dents, wrapped it in carbon fiber, then painted it (leaving some of the carbon fiber exposed). It didn't come out the best, and it was a pain in the butt to do, but it looks ok now.
  • I polish covers!
« Reply #6 on: October 02, 2013, 12:41:12 PM »
I'd love to see it when done.  Please, keep us updated on progress.
Offline kghost
« Reply #7 on: October 03, 2013, 12:14:19 AM »
I just made mine......
Stranger in a strange land
  • I polish covers!
« Reply #8 on: October 06, 2013, 12:47:03 PM »
kghost,
That looks great how did you do the welding?  Tig, Mig, Torch?
Offline kghost
« Reply #9 on: October 06, 2013, 02:31:56 PM »
TIG
Offline neevo
« Reply #10 on: October 06, 2013, 03:55:43 PM »
Here is my CB400F tank with knee cut outs, R1 fuel cap and stretched:
  • I polish covers!
« Reply #11 on: October 07, 2013, 05:15:45 AM »
neevo,
Great work on the tank!  Did you also Tig weld the tank.
Offline Lostboy Steve
« Reply #12 on: October 07, 2013, 10:55:06 AM »
I assume you got those straight cuts on a band saw? Can we see a pic of the underside?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #13 on: October 07, 2013, 11:03:14 AM »
WOW!! neevo you are a real pro working with stuff like this, right?
Offline neevo
« Reply #14 on: October 08, 2013, 04:27:08 AM »
Eeeeeeeeeerm... no!
This is my first bike I'm building up. All done with an angle grinder, some sheet steel, a little DC TIG welder (that I bought for this project) and a tonne of patience.
The tank sections were cut with a 1mm cutting disc on the grinder and then bent over a drill bit shoved into my work bench:
Underneath is a little messy but works as I tested it with approx 15 PSI:
« Last Edit: October 08, 2013, 05:27:29 PM by neevo »
