Author Topic: Instrument light bulbs  (Read 12565 times)
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« on: August 17, 2006, 02:41:25 PM »
So apart from the blindingly obvious places (the dealer, eBay?) can anyone suggest a source for the 12v 3.4w light bulbs from the speedo/tacho. Please don't suggest the local auto parts store....they are about as useful as t@ts on a nun.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
750k5
Re: Instrument light bulbs
« Reply #1 on: August 17, 2006, 02:44:51 PM »
Did you try Dennis Kirk???
Offline StevieMac
« Reply #2 on: August 17, 2006, 02:46:37 PM »
I actually got a replacement bulb for my tach at Canadian Tire.  As I recall it I couldn't find a bulb there with the exact same markings so I just went with a small round 12V bulb that looked the same.  I'm not sure on the wattage off hand.  Works like a charm though.
"Close enough for the girls I go with" ;D
« Last Edit: August 17, 2006, 02:58:39 PM by StevieMac »
72 CB500 Cafe
78 CB750 Chopper
Gallery: http://www.sohc4.us/gallery/v/members/personal/StevieMac/
Offline StevieMac
« Reply #3 on: August 17, 2006, 02:47:49 PM »
He's in Canada (eh!).  The problem with DK to Canada is they rape you on shipping so it's not worth it unless you're placing a large order.
72 CB500 Cafe
78 CB750 Chopper
Offline tomkimberly
« Reply #4 on: August 17, 2006, 02:56:33 PM »
Those bulbs are not just used on Hondas, the same ones are used on most other Japanese motorcycles.
Tom
Offline crp_iii
« Reply #5 on: August 17, 2006, 03:10:06 PM »
I got some at AutoZone.  Just matched the size and pin location.  They are not as bright but still work.
Lighting Technologies Instrument/Indicator 1445
Part Number LT1445
When it comes to Auto parts store I have determined you have to find the knowledgable parts clerk. The rest are oxygen thieves and must be avoided like the plague.  I knew if walked in the my parts store in Columbia, SC if the bald black guy or the Puerto Riccan girl were not working I turned around and left or asked when they were working.  The other idiots always ordered the wrong parts.  I am struggling to find a new parts guy/girl now that I am stationed in Ohio.
72 CB350F With poor man drag pipes
77 CB750F
Offline nickjtc
« Reply #6 on: August 17, 2006, 03:24:03 PM »
You're lucky. Most parts stores I have gone into, throughout BC, I am hard pressed to find anyone to even acknowledge my existence.  I was a parts guy in a new Polaris dealership for a few months, with little to no knowledge of snowmobiles or ATVs; if I did not know exactly what the customer wanted I would first tell them that, and then second get help from someone more knowledgable. Why anyone would order a part and hope that it would work without actually knowing for sure, is beyond me.
I see this as part of the whole degradation of customer service in retail.
1977 Suzuki GS750
Offline StevieMac
« Reply #7 on: August 17, 2006, 03:26:04 PM »
In my experience it's a lot worse in Canada (or at least BC) than what I see in the US.
72 CB500 Cafe
78 CB750 Chopper
Offline jevfro
  • 1975 CB750 K5
« Reply #8 on: August 17, 2006, 03:44:41 PM »
service manual has the SAE #  (for example: tailights\turns 1156\1157)
it's a #57 most auto places should have them...
Offline nickjtc
« Reply #9 on: August 17, 2006, 03:57:01 PM »
Thanks, one and all.
I'm working in northern BC at the moment so the choices for parts supply are limited. I'll drop in the local Honda shop on the way home to see whether they can help, and whether they will want an arm and a leg to pay for the bulbs.
1977 Suzuki GS750
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #10 on: August 17, 2006, 06:40:23 PM »
Since your doing it anyway, you might want to go with LEDs instead.  I got mine from www.superbrightleds.com, along with the rest of the idiot lights and a new LED taillight.
dave
Offline nickjtc
« Reply #11 on: August 17, 2006, 07:04:14 PM »
Thanks for all of the info and help, one and all.
I must confess that I asked the question assuming that the local Honda dealer here would not be able to help, since they are more an ATV/dirt bike kind of store (also a Polaris dealer).
Anyhoo I dropped by on my way home and apart from insisting that there was no such thing as a '79 650, they had the bulbs in stock! Honda part #34902-259-000, total cost for two bulbs $5cdn and change.
But I do like the idea of doing a LED buld swap out.....over the winter perhaps.
« Last Edit: August 18, 2006, 08:13:36 AM by nickjtc »
1977 Suzuki GS750
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #12 on: August 17, 2006, 07:59:26 PM »
I got mine at Autozone and they were actually a little bit brighter....can't
remember the number but the wattage was obviously a little bit higher.  There
are probably several types that will fit.
And Dennis Kirk does have the bulbs....correct but more expensive.
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline Jonesy
  • Shop Rat
« Reply #13 on: August 19, 2006, 04:00:13 PM »
I had posted a warning about this a while back. The SAE #57 bulb changed along the way, and now it has the correct base and wattage, but the glass bulb is too big to fit into the hole in the back of the gauge!  :P My local dealer had them in stock and were cheaper than if I'd ordered them by mail...
RSV12K
« Reply #14 on: August 19, 2006, 05:16:09 PM »
I have some extra bulbs... I replaced my tach/speedo with aftermarket versions. I'll give you the bulbs from my originals. They work, at least for now but they're ancient as you would expect. Send me an email to mjalex007 at yahoo with your address and I'm mail them. I have four, I think.
Offline jevfro
  • 1975 CB750 K5
« Reply #15 on: August 20, 2006, 09:59:31 AM »
Thanks for pointing that out Jonesy! I think I might go the LED route now
smashme33
« Reply #16 on: August 20, 2006, 06:38:58 PM »
 Hold on there... My 1980 CB650c takes a #53 in the gauges , so try that. I just changed the old bulbs last week, and they work perfectly.
Offline Short Round
« Reply #17 on: August 21, 2006, 09:06:45 PM »
I just went to walmart and got #1445 12V3W bulbs, yes the glass is bigger but I just made the hole a bit bigger.  Cant beat it $1.74 for two bulbs, even if you have to replace them one every few years, walmart is not going anywhere!!!!!!!!!!!!!
1974 CB550
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #18 on: January 09, 2008, 04:07:09 PM »
I know this is an oldie, but I knew it had come up before. I'm in the process of trying to refresh the guages on my 750. Along with the stock bulbs I found one, a GE 1891. Some of the stock bulbs look pretty dark so I might as well replace them. The 1891's are available and fit through the holes easily. They are a bit taller, but that poses no problems that I can see.
Offline WashingtonCB
« Reply #19 on: November 21, 2016, 10:28:22 AM »
Hey everyone, digging up an old thread is better than starting a redundant one, right?
It doesn't seem like a good consensus was ever reached on the LED swap.
From my 15 minutes of research it looks like these bulbs are referred to as BA9 in general industry, does anybody know that I am wrong about that? Otherwise it seems sound since they are bayonet mount and I measure 9mm diameter across the socket. Dual pin, single contact, and grounded body are all the standard/default for bayonet light bulbs.
Wikipedia says incandescent bulbs deliver approximately 16 lumens/ watt, so that would mean the standard 3.4w bulbs for back lighting the gauges are delivering about 54 lumens.
superbrightleds.com has some options. There is PN BA9S-WHP which apparently produces 40 lumens using .4w. But I'm skeptical of that because if the incandescent only used 3.4w I would expect a comparable LED to use less than .4w
PN BA9S-W4-90-12VAC is rated at 15 lumens without a power consumption figure listed.
Does anyone have experience with either of these options? I consider the light output critical in this case because having your gauges blast you with too much light would be irritating, but obviously so would not having enough back light.
If nobody can say what works best I'll order a few and report back, it sure would be nice to stick LEDs in and never think about them again.
« Reply #20 on: November 21, 2016, 10:38:20 AM »
Correct.  The BA9S bases are a direct fit for our gauges and instrument clusters.
I used these, and they are plenty bright.
Wide angle for the gauges, and narrow angle for the cluster.
https://www.superbrightleds.com/moreinfo/ba9s-ba7s/ba9s-led-bulb-1-led-ba9s-retrofit-car/3/
« Reply #21 on: November 21, 2016, 12:07:15 PM »
Sweet thanks for the insight! a dollar each is cheaper than some of those folks payed for old school bulbs! I expected to get worked over on a crazy shipping mark up but it was 3 bucks for 10 bulbs.
Offline Chachi
« Reply #22 on: November 21, 2016, 01:21:14 PM »
I use the superbright leds as well. For the gauges... I tried warm white and cool white and liked warm white much better, it was much more visible.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Phinn
  • Subversive
« Reply #23 on: November 21, 2016, 05:43:13 PM »
I think a better bulb for the speedo and tach gauges is the round-top one that simulates the incandescent version: https://www.superbrightleds.com/moreinfo/ba9s-ba7s/ba9s-led-bulb-1-led-ba9s-retrofit-classic-car-bulb/4/29/
It has the widest angle, and is available in both warm and cool colors.
For the idiot lights, the narrow-angle flat-top ones are better, in the same color as the corresponding plastic indicator lens.
« Last Edit: November 22, 2016, 07:31:34 AM by Phinn »
1978 CB750K -- "Mouse," a former basket case, resurrected
« Reply #24 on: November 22, 2016, 06:57:55 AM »
^^^ A good alternative, but may not be visible in direct sunlight as the output is only 1 lumen.
For the cluster lights, be sure to buy bulbs the same color as the crystal they are behind.
N-green bulb, Oil-Red, etc.
