Author Topic: Tach Seal Leaking 78 CB750F  (Read 597 times)
Offline CafeDawg
  • Not All Those Who Wander Are Lost!
  • Gone to the Dogs
« on: October 03, 2013, 06:39:43 PM »
So I installed a new tach seal awhile back, and finally took the bike out for a ride and it's still leaking.  Is the seal monodirectional ie could I have put it in backwards?  Thier pretty cheap so I was going to put another one in but didn't want to repeat the mistake.  If anybody has any ideas I'd appreciate hearing them.
Respect
CD
Respect & Understanding. U get what U give!
1976 CB550 basket case cafe rebuild
http://forums.sohc4.net/index.php?topic=106235.0
1978 CB750F evolving, daily rider
http://forums.sohc4.net/index.php?topic=89745.0
Re: Tach Seal Leaking 78 CB750F
« Reply #1 on: October 03, 2013, 06:58:16 PM »
Yes it is directional. When you buy another seal, people use seals from the 1980 DOHC as they are thicker.
Offline CafeDawg
  • Gone to the Dogs
« Reply #2 on: October 03, 2013, 07:32:31 PM »
Thanks Bobby I couldn't remember and putting it in backwards seemed the most likely culprit.  Good tip on the 80 DOHC will give that one a shot.
Respect
CD
« Reply #3 on: October 03, 2013, 08:43:18 PM »
Good luck
« Reply #4 on: October 03, 2013, 09:09:42 PM »
Assuming you are talking about the seal in the valve cover, did you get it seated /bottomed out correctly?
