Author Topic: CB550 - CB650 interchangability  (Read 19478 times)
markymark
Re: CB550 - CB650 interchangability
« Reply #100 on: October 30, 2006, 04:21:15 AM »
Sorry about the last post.  i guess the 81' cb650 head has different spacing, is that right?   If that is so, has anyone found a carb set up that will work for this spacing?
Offline kayaker43
« Reply #101 on: October 30, 2006, 06:13:25 AM »
That remains a mystery?? It would take someone at a salvage yard to rummage around and find a match? I'm sure there are common carbs that would fit.
Offline Brauner cb550
« Reply #102 on: August 01, 2018, 12:13:55 PM »
The cb650 motor is taller having taller jugs for a longer stroke.
I am currently borring 550 jugs to fit 650 pustons as well as using a cleaned up 650 head and 750 carbs. Also using a 750 tank.
Offline DaveBarbier
« Reply #103 on: August 02, 2018, 02:12:55 AM »
This post is 12 years old.
That being said, the jugs may be taller (by one fin it looks like) but the overall height is the same-ish. They make up the height difference with a shallower breather cover. If it’s taller overall it’s not by much.
650 left, 550 right
Offline LittleJoe
« Reply #104 on: January 11, 2025, 05:40:12 PM »
Reviving this one from the dead before I go making a new post: does anyone know if a 550 lower case will mate to a 650 upper case?
« Reply #105 on: January 11, 2025, 05:49:59 PM »
You can not interchange upper and lower cases ever: they are machined as a matched pair.
