Author Topic: Cleaning carbs (credit to AndreRA3)  (Read 3849 times)
50words
« on: April 01, 2005, 05:56:27 PM »
Well, I just spent the afternoon cleaning my carbs as AndreRA3 recommended.
Drain float bowls. Fill float bowls with a turkey baster through the fuel line with a 3:1 gas:Yamaha carb cleaner mixture. Kick the starter twice with the bike OFF. Let sit for 20-30 minutes. Repeat until the float bowls drain clear.
I just did it a few times, actually. It was looking pretty clear, and I wanted to get out and ride. But man, what a difference. I used to have to ride with my choke all the way open for about 20 minutes before it would hold even a 2200 rpm idle. Now, it idles nicely at 1000 rpm after just a few minutes! I can start without lurching, which is nice.
Next up is the brake light switch repair and a new seat and left side cover (anyone have an extra?). After that, I'm set for the summer!
AndreRA3
Re: Cleaning carbs (credit to AndreRA3)
« Reply #1 on: April 01, 2005, 06:36:42 PM »
Cool, man...
I'm glad it as well for you as it did for me.
Take care,
André
Honda_Dan
« Reply #2 on: April 10, 2005, 10:53:07 AM »
I was trying to find the origiinal post from Andre. I have carb problems as well, and am hoping to get away with not taking the assemble off and individually cleaning.
Sounds like the recipe is 1/3 yamaha carb cleaner to 2/3rds gas. Fill flow bowls through fuel hose, Kick over the starter twice and let sit for 20 minutes, then repeat until the mixture is clear.
Anything I'm missing?
Dan
AndreRA3
« Reply #3 on: April 10, 2005, 11:02:33 AM »
Dan,
The recipe is actually 1/4 yamaha cleaner, 3/4 gasoline (1:3 ratio makes for 4 parts  ;))  As far as the rest goes, you got it.  Fill the bowls through the fuel line (I did so with a 10cc syringe, others have used funnels, or 50cc veterinary syringes, or whatever else you can think of), and kick the bike twice with ignition off.  drain the mix, and it should come out pretty dark (mine did).  Repeat until it comes out clean (I only had to do it twice, and when I disassembled the carbs later to check my jets, everything was shinny and new).
It makes a world of difference...
André
Honda_Dan
« Reply #4 on: April 10, 2005, 11:39:13 AM »
Thanks Andre. I'm going to get to work on this afternoon. I tried runing some carb cleaner additive (mixed in the fuel tank) through there, but I don't think it did too much.
Let's Hope this solves my problem :-* :-*..
Dan
Offline cben750f0
« Reply #5 on: April 10, 2005, 04:34:06 PM »
just a question, does the carb cleaner harm the nylon slide guide?...peace...
AndreRA3
« Reply #6 on: April 10, 2005, 07:14:40 PM »
good question... i don't know.  I don't think it would, but I've been known to think some very silly things before.  I think Bob Wessner (sp?) dipped his whole carbs in this cleaner before.  Maybe he would know the answer...
