Author Topic: CB350F runs horrible on reserve  (Read 2300 times)
csiress2
« on: August 21, 2006, 05:19:10 AM »
I have '73 CB350F, and whenever I am low on fuel and need to switch to reserve, but bike has no 'pick-up and go'.  It bogs really bad with no acceleration. Definitely not good in traffic, or on a long trip with no station in site.
Now I know that it is not the reserve part of the petcock, for when I have full tank and set it to reserve, she runs perfectly fine.  I know that there is something I am missing, I just don't know what.
Thanks for you input.
Craig II
Offline Gordon
  • 750K1, 550K2
Re: CB350F runs horrible on reserve
« Reply #1 on: August 21, 2006, 05:44:36 AM »
Had the exact same problem with my 750 a while back.  Rebuilt the petcock and now it works fine.
Offline jgary
    • Catholic Nature Cards
« Reply #2 on: August 21, 2006, 06:11:46 AM »
My 76 750 wouldn't even run at all on reserve.  Just a tiny dribble of gas came through.  I didn't rebuild the petcock, just took it apart & cleaned it out.  There was a filter screen over the tubes that go into the tank that was alll clogged up.
John.
1972 CB 750
1976 CB 750
Peter
« Reply #3 on: August 21, 2006, 07:06:20 AM »
This may be too simple, but if there is #$%*e in the tank, when the fuel gets low, you will have that, but if the problem only happens when on reserve please ignore this
brimar6
« Reply #4 on: August 21, 2006, 07:42:55 AM »
I had the same trouble with my 750 last year. Drain your tank, pull it off of the bike, remove the petcock from the tank and you'll be suprised at what you'll find. Clean it all up real good, put it back together and it'll be good to go. The reason the bike runs ok with a full tank, on reserve, is because the weight of the fuel is creating pressure forcing fuel through all the crap. When your fuel level drops so does the pressure it is creating. This will take you all of an hour or so.
csiress2
« Reply #5 on: August 21, 2006, 08:46:18 AM »
Thank you for your replies.  I'll have to try the cleaning.  What should I use to clean it out?
Craig II
Offline Bodi
« Reply #6 on: August 21, 2006, 08:51:39 AM »
It's not really a pressure problem. When you're just running out of gas on "ON" the pressure is just about zero. Switching to reserve gives actually you a higher pressure (until you run it dry).
The "ON" fuel pickup is about 2 inches above the petcock, through a simple brass tube sticking up. Junk, dirt, rust flakes, sludge, whatever... is at the bottom of the tank and doesn't get into the "ON" pickup tube easily.
The "RESERVE" pickup is a hole in the top of the petcock itself, actually down inside the petcock nipple on the tank (if you have that type) and it naturally fills up with all the garbage in the tank.
SO if the reserve fuel flow is way low, it's probably plugged with guinge so removing and cleaning the petcock is required. If you're down to reserve, you can probably lay the bike as far over opposite the petcock - lay the seat on a chair or something - and remove the petcock with little or no gas spillage. If you have the screwed-on-from-inside petcock you have to remove and drain the tank to get it off.
There's a plastic filter screen "sock" over the pickups, it gets clogged with goop too and if it's clogged below the ON pickup level then the reserve flow will be rather poor too. You CAN do without the screen if it's ruined but if you can clean and salvage it that's best.
You should fit a simple inline fuel filter between the petcock and carbs. This will eliminate a lot of "dripping carb" problems.
Draining and washing the tank out is a good idea anyway.
Oh, and a tip if you DO run dry: There's no crossover tube on the SOHC4 tanks I've seen, so when you run dry and coast to a stop the bottom of the tank is empty on the petcock side, but there's still quite a bit of gas on the opposite side. Lean the bike way over towards the petcock and that gas is available to get you at least closer to the next gas station!
If your petcock is assembled with screws you can take it apart and clean it, use some silicon petcock grease or electrical dielectric grease on the moving parts. If it's riveted you CAN drill out the rivets and drill/tap for small screws. First thing I would do is jusy blow with compressed air back through the petcock from the carb port, in ON and RESERVE. This should clean out the inner workings, probably the biggest problem is a buildup of goop on the top of the petcock. Just use a toothbrush and solvent to get it off, and get any sludge out of the reserve port with a Q-tip wooden stick. The sock is pretty easy to tear when cleaning, stick a pencil or marker inside and brush against it gently with a toothbrush.
