Author Topic: more noise than i am comfortable with  (Read 1599 times)
Offline hymodyne
« on: August 23, 2006, 10:02:51 AM »
my 72 cb500 and I have logged over 3000 miles over the last season and a half of riding. I change the oil (Rotella synthetic)  about every 1000 miles. I have had, as I've read, many cb owners do, a clunkiing in my gearbox or lower end at low speeds. riding to work this morning I noticed that the clunking did not go away as it has in the past. what would or could be making that type of noise, and, should I be riding or tearing this engine down?
hym
eldar
Re: more noise than i am comfortable with
« Reply #1 on: August 23, 2006, 10:04:44 AM »
Is it only in certain gears or at certain rpm? Does the engine vibrate more than it used to?
Just as a check cause you never know, make sure your center stand pulls up tightly. If it is loose, it may clunk.
Offline hymodyne
« Reply #2 on: August 23, 2006, 12:29:35 PM »
riding this afternon, it was loudest in the first three gears, accompained by a jerking forward as I accelerated. at 60 mph, I still felt it, although not as strongly. cneter stand spring is working fine; thats not the source of the clunking.
hym
Offline dusterdude
« Reply #3 on: August 23, 2006, 12:32:58 PM »
rear chain adjustment?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
eldar
« Reply #4 on: August 23, 2006, 12:39:42 PM »
Doubt a chain prob but maybe. Might want to drop the oil pan and check things out. See if there are any metal shavings.
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #5 on: August 23, 2006, 01:42:20 PM »
This might sound crazy but.... are you having any problems top part of the engine/carbs?  It could be there and causing some lash in the gearbox.
Just a little think.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline dusterdude
« Reply #6 on: August 23, 2006, 01:45:29 PM »
if the chain and/or sprockets aint right you will get a herky jerky motion
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
eldar
« Reply #7 on: August 23, 2006, 02:55:54 PM »
Well the reason I dont think it is those is that it is only lower gears. But loads are different through the gears. You never know sometimes. Still think pan should be dropped though.
Offline hymodyne
« Reply #8 on: August 23, 2006, 05:35:21 PM »
I'm going to drop the pan and see what's going on down there. lower end on this found bike has not yet been opened...
hym
