Author Topic: cb750 F upper fork tubes on K8 lowers  (Read 615 times)
Offline 78whiteorbs
« on: October 04, 2013, 05:58:10 PM »
will this work? I have some beautiful pit free upper tubes from an F and would like to run them in my K8 lowers.
Forgot to mention its a 78 F
Offline RSchaefer
Re: cb750 F upper fork tubes on K8 lowers
« Reply #1 on: October 05, 2013, 10:50:27 AM »
Seems like it should work.  I have a '75F and I got a '78K parts bike and had pulled the "K" leg apart as I had a few dings in my "F" tubes.  Turned out the K tube was a little shorter I think, not much, but I only had one leg from the K so I ended up dressing my two F tubes instead as I would have ended up with one short one and one longer one.  Diameter is the same and the bolt to secure the damper at the bottom is the same.
All that said I am not the best resource, just letting you know what I found out!!
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Wobbly
« Reply #2 on: October 05, 2013, 11:24:56 AM »
The front fork pipes are identical (i.e., same Honda part #).
Offline 78whiteorbs
« Reply #3 on: October 05, 2013, 11:52:59 AM »
thanks wobbly, that was what I was hoping for. Thinking they might have been longer.
