That number looks like a 1976 CB750F1. If so it has the shorter basket prior to the upgrade used in the 77 and 78 which used a double metal plate from the early Gold Wing in the middle of the clutch pack. Sound right?
Does it fit inside like this?
Earlier basket on left and 77/78 on right. Either will fit but the 77/78 uses a modified cover that has the inside 'ribs' ground down/shorter/not protruding as much.
77/78 Clutch pack
Previous clutch pack - note that it's not put together correctly. I'm thinking this is my Barnett. It's not tight and compressed like the first one. The pressure plate is not installed correctly and it needs to be taken off and rotated so the teeth will mesh properly and it will sit flush. How many discs are you using?
This may help or at least get you started.
