Author Topic: Need help finding headlamp  (Read 9130 times)
Bobber
« on: October 06, 2013, 03:32:26 PM »
Hey all, I'm new to the forum and to the 73 CB500.  I'm looking for this headlamp.  Is it even Honda?  Trick is I have built a bobber using a box of parts.
Sent from my DROID RAZR HD using Tapatalk 2
Online Don R
Re: Need help finding headlamp
« Reply #1 on: October 06, 2013, 03:38:22 PM »
It looks like the original headlight. Stanley 7" In an emergency a car headlight can be used a bike headlight has a better light pattern.
Bobber
« Reply #2 on: October 06, 2013, 03:42:27 PM »
Alright thanks, any idea where to find one?  I can't find them online at all.  I find plenty that will fit and work but don't have the tabs for the bolts to hold it steady.
73 CB500 Bobber
Offline thirsty 1
« Reply #3 on: October 06, 2013, 03:43:09 PM »
Bobber
« Reply #4 on: October 06, 2013, 04:06:58 PM »
http://store.candlepower.com/ca53mohe.html
Mine is about 6.5 inches in diameter.  However the tabs that I was speaking of don't seem to match up with the ones in my image, maybe they do and are just bigger.  Does Stanley 001-1047 ring a bell?
73 CB500 Bobber
Offline thirsty 1
« Reply #5 on: October 06, 2013, 04:27:43 PM »
Good question. I ride a 400 so ? Try the search function you'll be amazed what with what you find.
Black 750K8
« Reply #6 on: October 06, 2013, 10:15:43 PM »
DSS and many others have them they are not a hard item to get.
Bobber
« Reply #7 on: October 06, 2013, 10:21:08 PM »
Turns out that I have a Kawasaki light setup.  Gonna find some OEM and go with an HID
73 CB500 Bobber
Online Don R
« Reply #8 on: October 06, 2013, 10:26:32 PM »
It's hard to see in the pic. So the tabs don't remove from the glass?
Bobber
« Reply #9 on: October 06, 2013, 10:43:56 PM »
No they don't.  They're pare of the sealed backing.  Weird right?  The Stanley part number leads me to Kawasaki parts.  Even then however I can't find one with the tabs/brackets on the metal backing sealed to the glass
73 CB500 Bobber
Offline LesterPiglet
  • 1977 CB550F2
« Reply #10 on: October 07, 2013, 02:39:52 AM »
I bought a new complete headlight and bucket from Fleabay for £25. It's listed for Yam RD/LC but does the job perfectly.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #11 on: October 07, 2013, 02:47:42 AM »
Do you still want sealed beam? I went with a Hella H4 halogen conversion kit when my last sealed beam died. Got it on amazon.
--Evan
1975 CB750K "Rhonda"
Bobber
« Reply #12 on: October 07, 2013, 07:22:58 AM »
Lester, going with a new bucket and something more modern would be a long term solution, good suggestion.  No, I don't have to stay with a sealed beam.  I'll check out hella's kit
73 CB500 Bobber
Offline evanphi
  • Apparently I'm an
« Reply #13 on: October 07, 2013, 07:44:19 AM »
73 CB500 Bobber
http://www.amazon.com/gp/product/B0002M9QK6/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
This is the one I got
--Evan
Bobber
« Reply #14 on: October 07, 2013, 07:47:34 AM »
What bucket do you use?
73 CB500 Bobber
Bobber
« Reply #15 on: October 07, 2013, 07:50:00 AM »
Wow, nice bike btw
73 CB500 Bobber
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #16 on: October 07, 2013, 08:00:08 AM »
73 CB500 Bobber
That should do the job. But unfortunately, it's a car headlamp designed to be used in pairs. The motorcycle headlamps have an altered beam pattern designed to illuminate the road in the same pattern as a pair of car lamps and have the word Motorcycle embossed on the glass.
Stu
« Last Edit: October 07, 2013, 08:08:51 AM by chickenman_26 »
MCN DTF
Offline evanphi
  • Apparently I'm an
« Reply #17 on: October 07, 2013, 08:35:27 AM »
73 CB500 Bobber
Stock bucket and rings.
--Evan
  • 1977 CB550F2
« Reply #18 on: October 07, 2013, 09:25:02 AM »
http://www.ebay.com/itm/Motorcycle-Headlight-Universal-Round-8-Side-Mount-Fits-Yamaha-RD250LC-RD350LC-/150661111873?pt=UK_Motorcycle_Parts&hash=item23141a2041
This is the one I used, just had to remove some of that blocky bracket thing at the rear of the bucket.
Not from that particular seller though.
« Last Edit: October 07, 2013, 09:28:11 AM by LesterPiglet »
Bobber
« Reply #19 on: October 07, 2013, 09:41:52 AM »
Alright, again I am new to the CB500, terminology for things, etc. completely.  This is my bucket, along with the mounting brackets, holes for screws etc.  Pictures of the headlamp is at the top of post.  The pictures of the headlamps in the links we first discussed don't seem to match up with my tabs which has led me to believe my sealed headlamp/bucket isn't Honda at all.  Correct?  So let's go with a bucket that supports my brackets, and the bulb/light that goes with it.  You guys may have already shown me those answers.  Basically an entire "light kit".  And if at all possible, one that will support HID in the future.
73 CB500 Bobber
Bobber
« Reply #20 on: October 07, 2013, 09:45:30 AM »
Perhaps this is my answer?
73 CB500 Bobber
Offline evanphi
  • Apparently I'm an
« Reply #21 on: October 07, 2013, 09:48:32 AM »
--Evan
Bobber
« Reply #22 on: October 07, 2013, 10:24:05 AM »
Perfect.  Greatly appreciate the help!  Next is the entire front brake assembly...  Woo hoo
73 CB500 Bobber
  • 1977 CB550F2
« Reply #23 on: October 07, 2013, 11:32:46 AM »
The beam from the light in DimeCity link may have a crap spread. I had one with the same reflector arrangement and I couldn't use it at night. In fact I was told by the MOT tester not to use it at night.
« Last Edit: October 07, 2013, 11:35:11 AM by LesterPiglet »
Bobber
« Reply #24 on: October 07, 2013, 11:36:44 AM »
I'll tell you now, the beam from the light in DimeCity link will have a crap spread. I had one with the same reflector arrangement and I couldn't use it at night.
Alright.  What's a better suggestion?
73 CB500 Bobber
