Author Topic: 750 K1 Valves cover  (Read 591 times)
Offline Tews19
  • I am no
750 K1 Valves cover
« on: October 06, 2013, 08:50:03 PM »
Roughly 2 weeks ago my valve cover started to seep oil on the left side... nowhere else.... I'm pretty sure I am done riding for the season...Is it possible to simply loosen all screws on the valves cover and retighten to see if the seepage subsides? Or should I attempt to tighten the one side?
1970 Honda CB750 survivor.
Re: 750 K1 Valves cover
« Reply #1 on: October 06, 2013, 09:42:50 PM »
Check if they are loose' only snug them a bit. Really cranking it up...just bends parts.
« Reply #2 on: October 06, 2013, 10:00:02 PM »
I've never seen a bent valve cover, but I guess it's possible. I like plan A, loosen all screws and re-tighten them evenly, and see if that seals it. The oil should have swelled the gasket slightly, so that might actually help it seal. Cheers, Terry. ;D
« Reply #3 on: October 06, 2013, 10:12:48 PM »
The cover wont bend but th screws dig in a bit' if its hooped overtightening..helps nothing.
« Reply #4 on: October 06, 2013, 10:14:30 PM »
I think I'd be more worried about stripping the threads out of the head Frank, especially if the screws have been replaced with stainless socket heads. ;D
« Reply #5 on: October 06, 2013, 10:20:02 PM »
If youcan get at them 2 under the breather cover loose, you could lift cover and apply sealant.
