Author Topic: uhOh  (Read 1206 times)
Offline donny
uhOh
« on: August 24, 2006, 02:12:36 PM »
 ;D..after loosing in Works fine, except..I see this is bad, both bulbs are on,  on hi beam.  The bid I won on a switch, It didn't work, can't return it.  (slaps self upside haid)..So I ain't ever gonna bid on  anything I can't return, and a lot of  things I can.
Anyway, it there some kind of a a new switch to use for a dimmer?? ;D
thank,  Don
2007 Husqvarna self propelled lawn mower    1976F    1971K    1974K      1990 FXRS-SP
Offline KB02
Re: uhOh
« Reply #1 on: August 25, 2006, 04:54:50 AM »
sounds like a wiring issue. Check your harness for any splicing, worn or incorrect wires.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Re: uhOh
« Reply #2 on: August 25, 2006, 08:03:17 AM »
Now no laughing, but years ago when MOT ing ( like US safety inspection) a Yamaha 100 i found that both high and low beam patterns were identical, after much searching, cursing and other such mechanical nieceties i discovered that the one filament had broken and the one end dropped down to touch the second filament and weld itself there meaning that both came on no matter where the switch was.DOH!! One new bulb and fixed!
Offline donny
Re: uhOh
« Reply #3 on: August 25, 2006, 01:20:30 PM »
 ???wuz I bad? ? I see I was censored? ?  Real bad? .. I removed the old wiring harness, as it was rotten in several places.  Just a hotwire to the front. I tested the heck out of the switch my bid  "won"  but it didn't work, hence the two toggle system. The headlight works fine. I was hoping someone would say" yea,  Acme makes a good switch, model 576XP, made for widgets, but will work well as a mc dimmer switch." I don't want to " bid " on another used electrical part. ;D
thanks,  Don
