Author Topic: 76 cb550 Leaking oil from stator cover/housing  (Read 3484 times)
Offline kippstakes
« on: October 08, 2013, 09:22:56 PM »
recently my cb550 has started leaking oil from the stator cover.
from what i've read, it's not unusual for oil to collect in the stator housing, and that it acts as a lubricant for the moving parts- this info seems like it could be false.
 after replacing the cover's gasket, it continues to leak and soak my foot with hot oil every time i ride.. not too great.. not to mention the spots on my driveway. additionally, i have replaced the o-ring on the plug beneath the stator. i also replaced the oil drain plug and ring nearest the stator housing, just in case.  no luck.
any ideas where the oil leak might originate? is it maybe the seal on the crankshaft? if so can it be replaced by removing the rotor?
typically don't mind getting my feet wet, but have to draw the line somewhere.
suggestions??
thank you
Strength is just an accident arising from the weakness of others.
-J. Conrad
Online dave500
Re: 76 cb550 Leaking oil from stator cover/housing
« Reply #1 on: October 08, 2013, 11:29:37 PM »
are you sure its from the alternator and not the oil pump right next to it?is there oil inside the alt?
« Reply #2 on: October 09, 2013, 06:53:34 AM »
The 500/550 does not have, or rather should not have, oil in the generator cover. The only way oil gets in there is from the gallery plug or the crank seal----you have to split the crankcases as well as remove the rotor to change the seal.
As dave said far more common is oil leaking from the oil pump at either the pressure switch or outer cover
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #3 on: October 09, 2013, 08:45:03 AM »
Like Dave says. There are lots of places for oil to leak under the sprocket cover. Three o0rings at the oil pump and two oil seals. Common problem area for leaks.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline kippstakes
« Reply #4 on: October 09, 2013, 01:51:22 PM »
yes, there is oil in the alternator cover. i have replaced the oil pump seals, so those should be good. i also checked around the oil pump within the time frame of the leak and it seemed dry. guess it must be the crankcase seal. dammit.
thank you
-J. Conrad
Offline lone*X
« Reply #5 on: October 09, 2013, 02:08:26 PM »
Have you replaced the o-ring on the oil gallery plug that is held in by the alt. cover?  Definitely check that before you go into pulling the motor and splitting the cases.  That plug is just sealed by the o-ring and is under full oil pump pressure.
« Last Edit: October 09, 2013, 02:32:56 PM by lone*X »
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline kippstakes
« Reply #6 on: October 09, 2013, 02:26:14 PM »
unfortunately yes. slightly less leakage, but the problem is still there. i guess a few drops here and there won't kill me.
-J. Conrad
Online dave500
« Reply #7 on: October 10, 2013, 12:47:14 AM »
lay the bike over the other way from the side stand and pull that bung again,be sure the hole is real clean and use hard setting compound on a fresh o ring,clean the hole and bung with spirits/prepsol and stick it back,might save splitting the cases?
Offline flatlander
« Reply #8 on: October 10, 2013, 01:09:02 AM »
did you check the pressure switch?
Offline kippstakes
« Reply #9 on: October 11, 2013, 05:34:54 AM »
i will give cleaning the plug and hole a shot- bike could use an oil change anyway.
i have not checked the pressure switch. i made sure it was snug last time i looked at the oil pump, but didn't inspect it closely. how tight should it be in there? also, my oil light has been coming on since i changed out the seals on the oil pump-  i have been wondering what was going on with that, maybe this has something to do with it.
thanks
-J. Conrad
« Reply #10 on: October 11, 2013, 07:31:08 AM »
They don't always leak arround the thread, the internal diaphragm can get a pinhole and oil leak up through the top
Offline kippstakes
« Reply #11 on: October 11, 2013, 08:41:22 AM »
hmm might be time for a new one then. pretty cheap, as i recall. be nice if that was it.
anyone know how to udjust the diaphragm tension screw on those things, or i should say what it needs to be adjusted to?
-J. Conrad
« Reply #12 on: October 11, 2013, 12:16:13 PM »
Not adjustable mate
Offline flatlander
« Reply #13 on: October 14, 2013, 04:32:01 AM »
yes if it's gone, just replace it. don't remember how much but they're not expensive.
