Author Topic: Oil presure  (Read 1154 times)
Offline Dion
Oil presure
« on: October 09, 2013, 12:00:11 PM »
I'm on the point of staring up my 836. What oil pressure at what rpm is acceptable?
Offline 01Thomas
Re: Oil presure
« Reply #1 on: October 09, 2013, 02:35:36 PM »
No one else has responded yet and I don't know but if the oil pressure light goes out after a lot of kickstarts without plugs you moving in the right direction.
A guide would be the Pressure Relief Valve setting, which my Original Honda German-language Honda factory manual from 1970 says is about 4,0 +- 0,2 Kp/cm^2 at 4000 rpm at an oil temperature of 80°C.
As an aside, my English Honda factory manual from 1972 says 56.9 lb/in^2 and 4.0 -+ 0.2 kg/cm^2, also at 4000 rpm and 80°C.
The fact that you're running 836cc should make no difference to the required oil pressure.
HTH
Thomas
PS While on the subject of factory manuals, I also have an original Honda CB750 Shop Manual Supplement dated 1972 covering the K1 but it seems not the K2 (yet)
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline Dion
Re: Oil presure
« Reply #2 on: October 09, 2013, 11:33:46 PM »
Thanks bud
Re: Oil presure
« Reply #3 on: October 10, 2013, 01:23:01 AM »
With 20W50 I dont go under 20psi in idle fully warm.  With the same oil over 60psi when started cold.
After oil change I am able to make the oil light go off running the starter with Kill switch off.  Oil light sender is - I believe - 7psi.   It takes quite a while to pump the oil around with just oil change when the oil pump is full.  Makes me nervous everytime :)
People here, after complete rebuild, filled the oil galley with oil to help the distribution and also priming the oil pump before installation.
Offline Dion
Re: Oil presure
« Reply #4 on: October 10, 2013, 06:25:01 AM »
Thanks chaps
