Author Topic: 77 cb750k.. slowly coming along.  (Read 6101 times)
Offline garygnu
Re: 77 cb750k.. slowly coming along.
« Reply #25 on: May 09, 2014, 10:42:17 PM »
Cue the slasher flick scary music.. reee!reee!!reee!!
Had to cut into the support bracket a little to get the hoop right for the seat length but that'll actually work out well for a spot to mount the rear blinkers.  Also, the DCC 'slugs' didn't fit at all and I had to spend a bit of time grinding them down with a drill press and an angle grinder.
Here it is mocked up with the seat before welding..
I'm not the biggest fan of the 77 tank with a bratstyle seat.  I might put some knee dents in it to see if that helps or else go with a smaller, earlier model tank.  I already have a tank from a 74 cb450.. maybe that'd work.
Anyways, got my electronics tray and oil can in from Cognito Moto.. I have to say pretty happy with almost all of the workmanship.  Everything feels really solid and I like the lines of the can.  I like the cap and drain plug on the the oil can a lot.
Some of the welds could use some work tho.. maybe I can clean those up with a grinder?
So that's where I'm at.. I'm fixing to get a Hondaman fuse block and a new reg/rec unit this week.  Does anybody have any thoughts about mounting all the electronics to the steel electronics tray?  Any pics?
Thanks!
« Reply #26 on: May 09, 2014, 11:16:52 PM »
I can relate to your feelings about the K7-K8 gas tanks. I'm not a huge fan of the lines, hence why I swapped to an F Super Sport tank with knee dents.
Offline 7aliveatlast7
« Reply #27 on: November 17, 2014, 04:17:18 PM »
What tires are you running on this, they look nice.
Offline AintNoEasyWay
« Reply #28 on: November 18, 2014, 07:06:15 AM »
Nice choice with the Cognito Moto parts!
