Author Topic: 750 Engine parts swapping  (Read 1178 times)
Offline RAZOR
« on: October 11, 2013, 02:59:10 AM »
Simple question.
Can I fit an sohc 750F2 cylinder head to a 750K sohc engine ?
I have aquired a CB750 (836cc) special, and the guy I bought it from is not 100% sure of the mix and build of the engine. Apparently it has a ported K series head & K series engine & mildly reprofiled cam.
I have bought a second hand F2 head and need to know if it is easy enough to swap the head over without issues
Cheers
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 750 Engine parts swapping
« Reply #1 on: October 11, 2013, 04:20:37 AM »
NOT SO Simple question.
Nope.  :(
In order to fit an F2/F3 head to a K motor you must also use the F2/F3 cylinders. You must also study and understand the oil paths for the top end of the F2/F3 in order to get all of the seals in the correct places. F2/F3 head/cylinder assemblies require additional O-rings as well as four acorn head nuts with copper crush washers. There are many threads addressing this.
Study the F2/F3 oiling system long enough and you will understand.  8)
(hint: the return oil paths are the deal breaker here)  ???
« Last Edit: October 11, 2013, 04:22:40 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline mick7504
« Reply #2 on: October 11, 2013, 04:24:52 AM »
Have a read of reply #6 in the Engine FAQ section mate.
Dr Rieck sums it up.  ;D
If I was you
I'd be worried about me.
Offline brandEn
« Reply #3 on: October 11, 2013, 05:21:04 AM »
+1
