Author Topic: all balls steering kit 350f  (Read 662 times)
Offline skidooextreme
« on: October 12, 2013, 09:06:56 AM »
I threw out the old bearings before k could measure the distances
  Anyone know if I need the washers they provided?
Re: all balls steering kit 350f
« Reply #1 on: October 13, 2013, 05:21:33 AM »
No one?
Offline puppytrax
« Reply #2 on: October 14, 2013, 06:18:24 AM »
The instructions for my 22-1011 All Balls kit say + or - 1mm from 'stacked' height of old [lower] bearing assembly. That's the upper race + balls + lower race, of the lower bearing assembly. If you've thrown out just the balls, Ace hardware has them (they're 1/4"). You only need 3 (to measure).
If you're thrown out the entire assembly, you could just try the tapered bearings without shims and see how they turn out.
Here's their instruction sheet...
http://www.allballsracing.com/media/installation/22-1011_washers.pdf
« Last Edit: October 14, 2013, 09:10:28 AM by puppytrax »
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
« Reply #3 on: October 14, 2013, 07:39:32 AM »
After digging around for a few days on and off , i finally found a post by camelman that said he used the small washer. Thats what i did and it works perfect, thanks for the reply!
