Author Topic: 1971 CB500 build from the Magnolia State  (Read 12513 times)
Offline Shifter19
Re: 1971 CB500 build from the Magnolia State
« Reply #50 on: November 07, 2013, 05:32:39 PM »
Next thing I did was finish the seat pan. Once I got it smooth and fairly even with bondo and glaze, I started on the seat pad. I cut out a wood base made of 1/4" plywood. Then a high density foam pad.
Offline Shifter19
« Reply #51 on: November 07, 2013, 05:42:09 PM »
Then I took some basic flat black vinyl fabric, some very thin upholstery foam, and some muslim cloth and sewed them together. I first drew some evenly spaced lines on the vinyl to follow. I used heavy duty black nylon thread. This was just to give the pad a nicer finished look.
Offline Shifter19
« Reply #52 on: November 07, 2013, 05:44:54 PM »
Here's a shot of my 50 something year old sewing machine too!
Offline Shifter19
« Reply #53 on: November 07, 2013, 05:50:08 PM »
Next I worked out a way to mount the pad to the pan using three t-nuts.
Offline Shifter19
« Reply #54 on: November 07, 2013, 05:53:30 PM »
I used spray glue to attach the foam to the plywood. Then sealed them both with several layers of Saran Wrap.
Offline Shifter19
« Reply #55 on: November 07, 2013, 05:58:40 PM »
Got the fabric lined up and spot tacked into place, then stapled it down with my nifty little Harbor Freight staple gun.
Offline Shifter19
« Reply #56 on: November 07, 2013, 06:01:01 PM »
And here's how it will look on the pan.
Offline Shifter19
« Reply #57 on: November 11, 2013, 03:59:27 PM »
With the seat all made, I wanted to get some paint while I had the weather in my favor. I don't have a fancy climate controlled spray booth. But I do have a spiffy collapsible tent and a fan I can set up in the garage. So the first thing I did was lay down some high build 2k primer.
Offline Shifter19
« Reply #58 on: November 11, 2013, 04:01:48 PM »
A whole lot of wet sanding, color sanding, and more coats later.....it was time for base coat.
Offline Shifter19
« Reply #59 on: November 11, 2013, 04:13:30 PM »
I chose  Ford "Race Red" from a 2012 Mustang GT for my color.  And also "High Performance" white for my stripe from that same vehicle. I figured if ever I get a scratch or nick in the paint, I can just order some color coded matching touch up paint from any number of venues. And besides, I really liked the colors! So I laid some basecoat.
Offline Shifter19
« Reply #60 on: November 11, 2013, 04:16:44 PM »
Next came some inter-coat clear to protect the base while I worked on the graphics.
Offline Shifter19
« Reply #61 on: November 11, 2013, 04:24:39 PM »
Laying out the racing stripe.
Offline Shifter19
« Reply #62 on: November 11, 2013, 04:26:33 PM »
More pics
Offline Shifter19
« Reply #63 on: November 11, 2013, 04:27:40 PM »
Now the white.
Offline Shifter19
« Reply #64 on: November 11, 2013, 04:31:54 PM »
Then using my stencil I got from a fellow forum member, I airbrushed the lettering. I even threw a little silver white pearl on top to make it pop in the sunlight.
Offline Shifter19
« Reply #65 on: November 11, 2013, 04:35:21 PM »
Finally the clear coat went on.
Offline Shifter19
« Reply #66 on: November 11, 2013, 04:44:25 PM »
After the clear coat dried for about 24 hours it was time to wet sand to 2000 grit. Then buff with four grades of compound to a brilliant shine.
Offline Shifter19
« Reply #67 on: November 13, 2013, 03:33:28 PM »
Before I bolted the seat and pad to the pan, I had to work out the battery placement. It looks like there would be plenty of space in the "hump", but in reality there wasn't really enough. I bought the smallest AGM battery that I dared. Then had to cut a bit of a slot in the metal pan to get clearance for the battery. But it all eventually worked out.
Offline Shifter19
« Reply #68 on: November 13, 2013, 03:37:06 PM »
Here's a couple of shots of the battery cable wiring going to my makeshift electrics basket.
Offline Shifter19
« Reply #69 on: November 13, 2013, 03:43:30 PM »
In order to mount my stock controls on an aftermarket handlebar, I had to mod the controls. I did this by cutting a slot for the wiring to fit through with my trusty Dremel.
Offline Shifter19
« Reply #70 on: November 13, 2013, 03:45:16 PM »
Here's the controls attached to the handlebars.
Offline Shifter19
« Reply #71 on: November 19, 2013, 04:10:43 PM »
Ran the carb overflow tubes, speedo cable, and tach cable.
Offline Shifter19
« Reply #72 on: November 19, 2013, 04:12:56 PM »
Got the wiring pretty much buttoned up and installed the headlight and turn signals.
Offline Shifter19
« Reply #73 on: November 19, 2013, 04:17:37 PM »
Had to fab a little bracket for the taillight and license plate to go on.
Offline Shifter19
« Reply #74 on: November 19, 2013, 04:20:33 PM »
Got the taillight, turn signals, and license plate mounted.
