Author Topic: BabyHawk.. the CB160 build.  (Read 97841 times)
Offline toytuff
  • "watching the pinheads"
« on: October 13, 2013, 01:41:06 PM »
Affectionately named the babyhawk I washed both the 1968 and 1969 model. Both bikes are complete with the exception of the 68 mufflers and seat.
1968...
1969...
Up on the lift and ready to get started.
tt
Re: BabyHawk.. the CB160 build.
« Reply #1 on: October 13, 2013, 02:08:46 PM »
Subscribed. What's the plan,  Toy?
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #2 on: October 13, 2013, 02:29:17 PM »
Sweeeet!  Subscribed for the fun :D
Offline toytuff
« Reply #3 on: October 13, 2013, 03:24:34 PM »
Not sure. Fenders, side covers and fork lowers will be painted. Prefer to keep the red paint. We will see how it shines up. The CT90 I did looked like new.
I think I sold my Tundra today.  ;D I will miss it but don't use it. After all it's an 08 with 13100 original miles.
Now we have bike money!
tt
Offline toytuff
« Reply #4 on: October 13, 2013, 03:25:31 PM »
Glad you are aboard!
tt
Offline MoMo
  • Ride like you're invisible
« Reply #5 on: October 13, 2013, 03:30:28 PM »
Love those bikes, subscribed----have fun with those fun bikes...Larry
Offline toytuff
« Reply #6 on: October 13, 2013, 03:42:06 PM »
Welcome! Keep an eye out for air cleaners and handle bars. On the "hit list" and hard to find.
tt
Offline toytuff
« Reply #7 on: October 13, 2013, 05:48:44 PM »
I have made the decision to redo the front and rear wheels. I can buy OEM rims at David Silver. He also offers aftermarket for less. 1.85x18 36 hole.
Honda still sells the spokes. Aftermarket at DS.
Will need the hubs polished. I believe several members here do this.
Any thoughts on spokes? Not worried about any rust factor here in Arizona.
tt
« Reply #8 on: October 13, 2013, 07:43:51 PM »
If you're going to keep it, buy the best, SS from Buchanan's. I just bought them for the Z. They also lace for $107. I don't see them for a 350, might be special order.
http://www.buchananspokes.net/products/spoke_kits_honda_cb.asp
Raffster polished my hub and did a great job at a fair price.
Offline toytuff
« Reply #9 on: October 14, 2013, 04:06:04 AM »
I'll check it out. It's a CB160. Honda OEM are $2.15 each.
tt
Offline toytuff
« Reply #10 on: October 14, 2013, 08:03:07 AM »
Time to get started. I removed the tank and gave it a quick polish. Nothing heavy.
But speaking of heavy there is quite a bit of rust inside. Greggo, the fill spout is to small for golf balls. I'll have to figure out something else.
I removed the valve tappet covers and it was as clean as a whistle! Very dry but super clean. I soaked the rockers and springs with some Marvel as well as the cylinders. Carburetor slides are clean and slide easily. Was surprised but they will get redone none the less. The points are shot.
Hooked up a shop battery and everything works. Horn, headlight, starter etc.
This however was a big surprise. Although titled as a 1969 I do in fact believe this to be a first year 1965. I'll need to research.
More to come. Much more.
tt
Offline Greggo
  • Somebody's
« Reply #11 on: October 14, 2013, 06:04:46 PM »
Bummer on the tank opening.  What's the capacity?  Is it less than two gallons?
With a little research, I was able to find out a ton of information on my CA95, and I believe you'll find even more on this bike.
« Reply #12 on: October 14, 2013, 06:09:43 PM »
Toy - I used drywall screws to loosen the rust inside the RD350 tank.  Worked well. Then I coated with the Caswell sealer. Pleased with the results, only 6 months so far though.
Offline toytuff
« Reply #13 on: October 14, 2013, 06:25:48 PM »
Still have the CA95 bars.  ;)
tt
Offline toytuff
« Reply #14 on: October 14, 2013, 06:28:06 PM »
The issue is volume. I need something to increase the level of the chemical. Like adding rocks to a glass of water. After soaking I'll strain the chemical then reapply using a small chain.
Coating is a last resort.
tt
Offline toytuff
« Reply #15 on: October 15, 2013, 07:02:21 AM »
This morning I ordered more parts from my NY supplier and from David Silver new OEM rims and F/R spokes. A few other things I could not get here. Expensive morning already.  ;)
I adjusted the valves @ 003. They were a little tight. Hooked up the shop battery and checked the timing. A little off but correct now. Of course when I install the new points this will be done again.
Time for compression. Always a "finger crossing" time huh?
Spec is 128 to 149 psi. With fingers crossed I got this.
Left 142
Right 139
As we all know this will come up once running. I have half a notion to hook a aux. tank and see if it will start. Wouldn't that be something!  8)
tt
Offline MoMo
« Reply #16 on: October 15, 2013, 12:50:08 PM »
It will start for sure,  do it...Larry
Offline toytuff
« Reply #17 on: October 15, 2013, 01:37:53 PM »
2.8 gallons.
tt
Offline toytuff
« Reply #18 on: October 15, 2013, 01:38:43 PM »
Already drained the oil. You'll have to wait several months.  :P
tt
Offline MoMo
« Reply #19 on: October 15, 2013, 01:43:24 PM »
Too bad, those bikes were so stone -cold reliable that I'm sure it would have started.  I usually do start a bike before tear down just to see what I am dealing with.   Have fun with it...Larry
tt
Offline Greggo
  • Somebody's
« Reply #20 on: October 15, 2013, 01:51:43 PM »
2.8 gallons.
tt
How about marbles for filler?  You'd certainly want to be careful putting the first handfulls in, but they could work well, and they're cheap!
Offline toytuff
« Reply #21 on: October 16, 2013, 04:20:11 AM »
tt
Going to drop the float bowls today and take a look. All I would have to do is find a fuel T, 1 1/2 quarts of oil and gap the plugs.
Want to start soaking the tank today. Although the instructions say a couple of hours I'm thinking a couple of days.  ::)
tt
Offline toytuff
« Reply #22 on: October 16, 2013, 05:14:59 AM »
Larry, you got my curiosity fired up! After all, this is a Winter build so no hurry. Being retired offers many days of "whatever."
Got the heat gun out and warmed up the bowls. Much to my surprise these things are very clean! Going to fuss with it a bit and see if she will run.  ;)
Bowls.
Left side.
Right side.
Although the tank has rust I was expecting a mess in here. Some cleaning might just be all they need.
tt
« Reply #23 on: October 16, 2013, 05:43:39 AM »
Fire it up!
Offline HondanutRider
« Reply #24 on: October 16, 2013, 05:50:11 AM »
