Author Topic: BabyHawk.. the CB160 build.  (Read 91881 times)
Offline jas67
Re: BabyHawk.. the CB160 build.
« Reply #250 on: November 20, 2013, 05:26:18 AM »
Have a couple of questions.
Working on the front forks. The parts diagram does not show lower fork bolts and copper washer. Mine has them.  ::)
The parts diagram you are looking at is probably for the earlier steel lowers, which were painted the same color as the rest of the bike.
The silver-painted ones are aluminum, and have some differences, such as different fender mounting hole locations.   The bosses for the fender mounting holes are centered on the steel lowers, and offset on the aluminum ones -- something to keep in mind if you replace fenders.
« Last Edit: November 20, 2013, 05:30:42 AM by jas67 »
Classic Honda:
1976 CB400F
1975 CB400F (project)
1975 GL1000
1968 CL175 (1 nice one, one project)
1967 CB77
1967 CB160 (2 of 'em, both projects)
1967 CL160 project
Triumph: 2017 Thruxton R
BMW: 2016 R1200RS, 1975 R90S, 1973 R75/5, 1980 R100S
Ducati: 2013  Monster 796, 2013 848 Evo Corse SE track beast, 1974 750GT, 1970 Mk3d 450, 1966 Monza 250
Moto Morini: 1975 (titled 1976) 3 1/2 Strada, w/ Sport clipons.
Moto Guzzi: 2017 V7III Special,  1977 Le Mans, 1974 Eldorado
Offline toytuff
  • "watching the pinheads"
« Reply #251 on: November 20, 2013, 06:33:35 AM »
As with any older motorcycle it's hard to know what you have. Titled as a 1969, wiring harness 1965.
I'm looking at the diagram and yes, hard to figure out. If you look at number 14 this is what I am trying to remove from number 5.
It almost looks like it is threaded on but once again, it's not the right diagram compared to what I have. Unless this cover removes new fork seals can not be replaced. I have cleaned the best I could given the depth and I can see the snap ring that holds the seal. This would be item 6. Footnote: There are two (2) items labeled number 6 both being different.
Saga continues. Progress slow. Dust seals removed but the chrome cover will not move. I have soaked in PB Blaster and heated. I tried to wish it off but that did not work.
tt
Offline toytuff
« Reply #252 on: November 20, 2013, 07:03:03 AM »
OK, a determination has now been made. I have fought these covers on other builds.
I did get the dust seals out.
Soaked the forks and cleaned the top of seals best I could.
Then I looked at the spare CB160. (nice to have two huh?)
As I suspected they slide off. In this case they do not slide off. On there pretty deep I might add. Someone was in the fork area at one point.
A long way to go. Around 30mm.
Saga continues. Out of ideas for today.
tt
Offline jas67
« Reply #253 on: November 20, 2013, 08:40:47 AM »
I have two CB160's and one CL160, all three titled as '67.  I haven't checked for a date on the wiring harnesses.
The two CB160's both have the earlier steel lowers, and the CL160 the aluminum ones you have.
It is possible that your forks were changed out for the later style at some point.
Classic Honda:
1976 CB400F
1975 GL1000
1967 CB77
1967 CL160 project
Offline jas67
« Reply #254 on: November 20, 2013, 09:02:53 AM »
OK, here are your two different fork diagrams.    The CL uses different fork ears, and gators instead of the metal covers, but, pay particular attention to the lowers.
The lowers shown on the later CL fork are the same as the lowers you have pictured.
1965 "CB160" -- shows the steel lowers with the fender mount bosses in in the center:
http://www.hondabikes.com/fiche_section_detail.asp?section=2559095&category=Motorcycles&make=Honda&year=1965&fveh=132814
Big Image: http://farm8.staticflickr.com/7431/10964159016_d767f8e353_o.gif
1966 "CL160" -- snows the aluminum lowers with the fender mount bosses offset as your fork is:
http://www.hondabikes.com/fiche_section_detail.asp?section=2559099&category=Motorcycles&make=Honda&year=1966&fveh=132815
Big Image: http://farm6.staticflickr.com/5538/10964158736_1ba0820664_o.gif
Classic Honda:
1976 CB400F
1975 GL1000
1967 CB77
1967 CL160 project
Offline toytuff
« Reply #255 on: November 20, 2013, 09:35:50 AM »
That may be but neither one shows a bolt in the bottom of lower fork.
tt
Offline toytuff
« Reply #256 on: November 20, 2013, 01:10:06 PM »
My Lord that was hard! Not looking forward to the right side.  :o
Both wheels are finished.  8)
Fork is not coming apart. Something is holding it. I'm thinking it's the bushing. Going to attempt removing the fork seal and see what's going on. They should pull apart but they are not. Fighting me all the way.  ::)
tt
Offline MoMo
  • Ride like you're invisible
« Reply #257 on: November 20, 2013, 02:00:13 PM »
A vague recollection but I think once the circlip ring is removed the entire fork tube assembly slides out.  The lower leg would be clamped in a vise while pulling the tube up like a slide hammer.  Not all that sure though...Larry
« Reply #258 on: November 21, 2013, 06:26:50 AM »
Think you need a machinist to fab a pair of pullers that clamp arount tube but engage chome cover. Then a few good smacks on flange machinist made and Bob is your uncle...not assembled.
David
Offline toytuff
« Reply #259 on: November 21, 2013, 09:27:13 AM »
Right cover came off easy. Lower fork bolt took a couple of hours. Drill and easy out. Nightmare.
Forks are apart. Larry was right, heat and beat.
tt
Offline toytuff
« Reply #260 on: November 22, 2013, 08:26:44 AM »
Moving along on this project. All parts are cleaned, paint is done with the exception of the fork lowers. Still deciding which way to go. Waiting on carburetors and a rear tire which should be first of next week.
I got the forks to break free.
Left:
Right:
Removed the triple tree and counted 36 1/4" ball bearings. Check. Cleaned up parts.
Then the neck.
And partially assembled. Lock cleaned and lubed.
tt
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #261 on: November 22, 2013, 09:39:23 AM »
Looking great!
Offline jas67
« Reply #262 on: November 22, 2013, 09:44:30 AM »
Classic Honda:
1976 CB400F
1975 GL1000
1967 CB77
1967 CL160 project
Offline toytuff
« Reply #263 on: November 22, 2013, 09:51:01 AM »
Thanks guys!
One bolt at a time.  ;)
tt
Offline HondanutRider
« Reply #264 on: November 22, 2013, 02:37:03 PM »
Looks great!  Don't forget to get those Thai parts. ;)
Offline toytuff
« Reply #265 on: November 22, 2013, 02:48:42 PM »
Not on this one.  ;D
tt
« Reply #266 on: November 22, 2013, 03:44:14 PM »
Hey tt, I know you didnt paint the frame but that looks too incredibly good to be original.
Any chance that has been repainted sometime in its life?
You are the BabyHawk man!
Offline volare71
« Reply #267 on: November 22, 2013, 04:13:13 PM »
 8)
These little gems are gorgeous.  The less you do in changing the bike the better.  With clean bowls and good compression you might want to start her up.  If it doesn't fire up immediately a thorough carb cleaning is in order.
that tank is ripe for an electrolytic cleanout with washing soda and a strong battery charger.  Fill the tank with sodium carbonate (Arm and Hammer washing soda-not baking soda 1/2 cup to a tank of water and place the negaitve cathode in the tank and the positive anode connected to bare metal.  The rust will migrate from the inner tank to the cathode releasing rusty foam.  Overnight will do it.  I use a piece of rebar bent in an L shape for the cathode and insulate with plastic aerosol can lids and a peanut butter jar lid at the filler.  Works great and you won't need to paint sealer in the tank.  It will also spare the original paint.
Offline toytuff
« Reply #268 on: November 22, 2013, 04:21:37 PM »
It's original Scarlet Red Steve.  ;)
I work the magic!  :D
tt
Offline toytuff
« Reply #269 on: November 22, 2013, 04:23:57 PM »
8)
I have used that method before but this time just a good soak with Evapo-Rust did the job.
I had it running before teardown. Reply #25.
Compression excellent. Reply #15
Thanks for the reply.
tt
« Last Edit: November 23, 2013, 04:54:37 AM by toytuff »
Offline toytuff
« Reply #270 on: November 23, 2013, 11:08:22 AM »
Well it's nice to be going the other way!  :D
Tire showed up yesterday so first thing this morning was down to the local dealer for tire mounting. I feel in love with a Vulcan they had on the showroom. Pics later in "other bike" thread.
 :o
Don't stop!
Mock up.
Ready to mount when the front end gets finished.
Time to take the rest of the weekend off. Well, maybe.
tt
« Reply #271 on: November 23, 2013, 11:30:04 AM »
Very nice, you deserve a margarita amigo!
Offline toytuff
« Reply #272 on: November 23, 2013, 11:42:04 AM »
That's a great idea!
tt
Offline toytuff
« Reply #273 on: November 24, 2013, 07:33:57 AM »
Should have all the paint work back tomorrow with the exception of the lower forks. Having those painted but weighing out options.
Went to install new points but the wrong ones. Honda lists several. Working on that also.  :D
Did a little mock up this morning. Wanted to see where I was going.
Headlight area.
Speedometer and top clamp area.
And a glamor shot.  ;)
Rear fender next as well as the chain. Soaking the chain now but need to find some kerosene or other substitute for a good cleaning.
tt
« Reply #274 on: November 24, 2013, 07:46:43 AM »
The money shot!  Is there a steering dampener on the upper triple?
