Author Topic: BabyHawk.. the CB160 build.  (Read 91712 times)
Offline toytuff
  • "watching the pinheads"
Re: BabyHawk.. the CB160 build.
« Reply #300 on: November 29, 2013, 04:05:08 PM »
Starter removed for painting. Wasn't to bad of a job. Just filthy.
tt
More to come.
tt
Offline toytuff
« Reply #301 on: November 29, 2013, 04:58:44 PM »
Looks much better. On to the right cover next with a clutch inspection.
Before.
After.
tt
Offline MoMo
  • Ride like you're invisible
« Reply #302 on: November 29, 2013, 05:35:41 PM »
Very nice, TT, nice and clean-ready to ride soon?...Larry
Offline toytuff
« Reply #303 on: November 29, 2013, 06:50:39 PM »
End of December is the target date. Left cover installed and done. Start on right tomorrow.
Waiting on carburetors and painted fork lowers. Shopping for a chain in 108 links. Don't want to bust one down to fit.
Found a good left muffler today. Still need right. Found correct side cover for the 350G also. It was a good day.
tt
Offline toytuff
« Reply #304 on: November 30, 2013, 05:35:41 AM »
Playing with the NX2000 this morning. Shoots huge pictures. Still reading. Still learning.
I bought a book that relates to me and a camera. DSLR for dummies.  :D
tt
« Last Edit: November 30, 2013, 01:52:25 PM by toytuff »
Offline toytuff
« Reply #305 on: December 01, 2013, 09:54:46 AM »
Right side cover is now removed and ready for paint. The screws were not to bad, just a little fight. The side cover was not. Man, thought it would never break free.  :o
I did not have a flash connected but this side was just super clean. Honestly, I started to doubt whether the oil pump even works.
Wanted to throw a pipe on the right side. Cleaned up nicely.
And a full shot using the fluorescent light setting on the camera. Has three so I need to read. More.  :D
tt
Offline MoMo
« Reply #306 on: December 01, 2013, 10:24:25 AM »
Is the inside of the oil slinger clean?  Usually filled with crud...Larry
Offline toytuff
« Reply #307 on: December 01, 2013, 10:31:59 AM »
Everything is super clean with a light coating of oil. I was prepared for a mess on each side but not the case. I did not wipe either side it was so clean. Just a little around the starter area.
Left.
Right.
A little oil dripped out when removing covers which is usual.
tt
Offline MoMo
« Reply #308 on: December 01, 2013, 10:37:45 AM »
That is really rare that  inside the slinger is clean-obvious the PO took exceptional care of the bike...Larry
Offline toytuff
« Reply #309 on: December 01, 2013, 12:36:41 PM »
Well, that may be but it has not run in years. I only ran it for the length of the video. 24 seconds or so.
tt
« Reply #310 on: December 01, 2013, 02:50:12 PM »
Unbelievably how clean that bike is.
Who is doing your carb, just 1 right?
Offline toytuff
« Reply #311 on: December 01, 2013, 02:52:08 PM »
Crazy isn't it. Two carburetors.
tt
Offline toytuff
« Reply #312 on: December 03, 2013, 06:20:09 AM »
Moving forward this morning.
Changed out the exhaust gaskets.
Mounted pipes but did not snug them. These will need to move a bit when installing mufflers.
Right cover painted and installed with new kick start seal, cover gasket and OEM screws.
Notice the condition of the kick start rubber. Love the "Honda" inscribed.
Fitted the right side cover. Great tip on using O rings to protect the tabs. Think it was HondaNut.  8) Had to use the original rear brake cable. Flea Bay part did not work. Gee, I'm so surprised.  ::)
Waiting on drive chain then button up the rear. Forks and carburetors are next when they are done.
tt
« Reply #313 on: December 03, 2013, 06:30:58 AM »
Wow...duel exhaust, looks cool!  tt, is rare see something that you've overlooked but the exhaust valve adjustment covers are looking a little sad, ya know?
Offline toytuff
« Reply #314 on: December 03, 2013, 10:43:09 AM »
I'm not sure if they were the color of the engine or Silver. Thoughts?
tt
« Last Edit: December 03, 2013, 10:50:53 AM by toytuff »
Offline toytuff
« Reply #315 on: December 03, 2013, 10:49:29 AM »
Mock up. Still working on cleaning the exhaust but done for the day. Hit the Shop running at 0330 hrs.  ;D
Right. Still looking for a better muffler. Hard to find part.
Left.
Money shot.  :o
tt
Offline jojo
« Reply #316 on: December 03, 2013, 12:53:53 PM »
that is a really nice looking ride.  8) Props for all the work
Offline HondanutRider
« Reply #317 on: December 03, 2013, 02:34:54 PM »
tt
I believe they were just an aluminum finish, maybe clear coated.  They should be the same as the finned cylinders and head. I don't think they were painted as the side panels were.
Offline toytuff
« Reply #318 on: December 03, 2013, 03:57:30 PM »
Thank you Sir.
tt
Offline toytuff
« Reply #319 on: December 03, 2013, 03:59:37 PM »
tt
Yeah, knew they were not Cloud Silver. Could paint the same as engine covers but had doubt's they would look good. Undecided at this time, best to leave as is for now.
tt
« Reply #320 on: December 03, 2013, 04:06:18 PM »
tt
tt
If same as 550/750, they were just cleared.  I would strip and lightly polish. No biggie, but I know how detail oriented you are!
Offline toytuff
« Reply #321 on: December 03, 2013, 04:51:46 PM »
Might throw them in the tumbler and see what happens. Sometimes you just have to roll with it.  ;)
tt
Offline toytuff
« Reply #322 on: December 04, 2013, 01:26:40 PM »
tt
« Reply #323 on: December 04, 2013, 02:12:33 PM »
That's better!  More like they should look.
« Reply #324 on: December 04, 2013, 03:31:22 PM »
+1.....knew you wouldnt just leave it!
