Author Topic: CB 500 Four (1972?) Full Restoration  (Read 138453 times)
0 Members and 8 Guests are viewing this topic.
Offline MickB
Re: CB 500 Four (1972?) Full Restoration
« Reply #100 on: February 13, 2014, 11:15:09 pm »
Back to the rebuild, I have been away in the Tasmanian wilderness for approx 1 month plus back at work. I've done some little things in the background which have taken time. Everything I do it's got to be fully restored - time and money.
I'm missing so many pieces.
I now think I'll build the bike and then I'll see all the parts I need, when complete strip it down to do the chroming and bring it back to original.
Big thanks to Tom Jeff for box of electrics, cookies are on their way
Offline SohRon
« Reply #101 on: February 14, 2014, 11:58:27 am »
This is looking very sharp! Good on you for keeping it stock. That frame looks great... I'm pretty sold on POR15 myself, so good to see it on your frame. Here's a tip: don't think about how much it's going to cost or you'll just drive yourself nuts.  ;D
I'm not sure how I missed this before, but will be following your progress!
Offline MickB
« Reply #102 on: May 06, 2014, 03:47:09 am »
Haven't posted for a while, but been doing lots of derusting, cleaning, rocker, head, barrels, cases all blasted and the put through a specialized motor (dish) washer. Came out fantastic.
Have rebuilt tachometer and speedo. Re built front caliper including polish and paint.
Now concentrating on the motor build.
Front and rear guards been at metal repair workshop then to chromers
Offline MickB
« Reply #103 on: May 06, 2014, 04:00:20 am »
Some photos of work in progress, headlight needed crack repair then shell needs more sanding then paint, seat stripped de rust with POR15, need to get new foam and fashion from old foam
Offline MickB
« Reply #104 on: May 06, 2014, 04:06:05 am »
Speedo and tachometer shells first removed rust then copper, then chromed, they came up well, domed nuts at chromers now.
Found out today from Honda dealer my motor CB509E 2414 is actually a 73 not 72 model, they told me Honda japan have plenty of bearing shells for crankshaft, except here in Oz cost is $250!
« Reply #105 on: May 06, 2014, 05:11:56 am »
Subscribed.  I recently bought a CB500
Offline MickB
« Reply #106 on: May 06, 2014, 11:27:31 am »
SohRon I'm budgeting on 5 grand
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #107 on: May 06, 2014, 03:55:15 pm »
Hopping on the 500 bandwagon  ;D
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
Offline MickB
« Reply #108 on: May 07, 2014, 04:17:12 pm »
Just received the reconditioned cam back from "Tighe Engineering" in Queensland, lobes (stock grind - they had the specs) and bearing surfaces all restored. Bearings are taped to protect.
Engine back from washing (a huge engine washing machine - like a dish washer) and all oil channels cleaned, wire through each and compressed air -not a spec of sand from blaster. A mate of 25 years (the best mechanic in Sydney) did it freeby.
Now to start the engine rebuild!
« Reply #109 on: May 07, 2014, 04:21:51 pm »
That motor cleaned up nice.  A good clean slate to start from.
Offline MickB
« Reply #110 on: May 08, 2014, 08:20:03 pm »
Between 1969 and 1979 I had 7 motorbike licences, never got of "P" plates (in Australia it's a provisional licence, don't exceed 90ks and no pillion for 12 months).
Pleased to advise I got a new motorbike learners licence today, got to get ready for when the build is complete.
Next - get stack hat, boots and gloves, I'll practice on my daughter's ZZR250.
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #111 on: May 08, 2014, 08:47:13 pm »
Look better than new!  8)
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Offline pangloss
  • CB500 K2 1975 NZ model
« Reply #112 on: May 09, 2014, 02:22:43 am »
Who did the Cases.? Campbell's.??  Looks very good.
Offline MickB
« Reply #113 on: May 09, 2014, 03:54:49 am »
Thanks , the chroming done by Ultimate Shine in Liverpool South West Sydney, not cheap but very thorough.
Offline MickB
« Reply #114 on: May 10, 2014, 02:42:19 am »
I found a stack of bearing shells in a bag in amongst the boxes.
The crank is right on spec.
Do I get new shells or reuse the old ones?
My feeling is get new ones.
Also found not 1 but 3 oil pumps!
Cleaned the oil way in the bottom case with a push through
« Reply #115 on: May 10, 2014, 03:09:46 am »
ive used old shells over and again from running engines,not best practise to use unknown bits and pieces though,if they aint scored you can try squeezing them up with plastiguage,if you get a good reading and they aint damaged youll be ok,if its a race/drag engine use new,ive thrashed these little motors for years on old bottom ends with rebored top ends,they handle it,just do it all clean.
don't mix up the caps to rods!run a cap over the rod and youll feel a snag/grab everytime,give them both a few strokes over wet/dry on flat glass and theyll glide with no snags and close up with more precision,polish the shell seating area aswell by hand with say autosol polish,you want perfect shell to backing contact,the heat is transferred squarely then.
which two look polished?its just that its apart now so do it perfectly!
« Last Edit: May 10, 2014, 03:26:15 am by dave500 »
« Reply #116 on: May 12, 2014, 10:50:08 pm »
Remember to clean AL the autosol off as it a mild abrasive
Offline calj737
  • I refuse...
« Reply #117 on: May 14, 2014, 06:33:35 am »
Mick - been trying to post up for a few days, but my hands have been quite full of cookies. Huge thanks, Mate.
Btw - project looks like it's coming along great
Offline MickB
« Reply #118 on: May 15, 2014, 01:15:01 am »
Was able to finish the assembly of the front wheel retainer ring ivan suggested I use his thread cleaner he bought it 30 years ago and it did a great job.
A dab of spray grease and it almost spun on, I screwed it off and on a few times and it's great, finally fastened down nice and snug onto the bearing with a special tool which worked beautifully
Tachometer and speedo are nearly finished, was able to put the tachometer back together yesterday, now just waiting on the little chrome nuts and new grommets. Mustn't forget the felt washers around the shafts.
Note the speedo set back to "0".
Offline MickB
« Reply #119 on: May 15, 2014, 01:56:57 am »
Dave thanks for the advise, it asked for  it! You've thrown me now as I was all set for new bearing shells!
When I had the cylinders honed at Heads Plus he said the bore was completely stock all the main journals were right on spec and the rods were all good - but he suggested new shells for the bottom end.
Dave it'll certainly save money, but how do I know about what one's green or brown etc. as per the code on the back of the cases? Is that a problem? Or doesn't it matter?
Offline MickB
« Reply #120 on: May 15, 2014, 06:20:26 am »
No sweat I'm glad you like them. Just remember what your mum said - don't eat too many before dinner time, you'll ruin your appetite.
Bet you've never had an Anzac BISCUIT (not a cookie but a biscuit-  by law in Australia) before.
Regards
Offline calj737
  • I refuse...
« Reply #121 on: May 15, 2014, 10:53:36 am »
Actually, my sister lived in Melbourne for 5 years. Treated us 1 Xmas to a mixed ton of biscuits. They seem familiar, but not certain. Also turned me onto Tim-Tams. Can't get those here. Tragic-
Offline MickB
« Reply #122 on: May 15, 2014, 05:38:41 pm »
At our age the last thing we need is Tim Tams - mmmm the dark Choc ones with a cup of tea.
The milk Choc ones would kill a black dog.
Offline calj737
  • I refuse...
« Reply #123 on: May 15, 2014, 07:09:21 pm »
I fancy the milk chocolate ones with an espresso macchiato myself... As for killing a black dog, I've survived them for a decade  ;)
« Reply #124 on: May 15, 2014, 08:39:43 pm »
you mixed them all up didn't you?
