Author Topic: CB 500 Four (1972?) Full Restoration  (Read 144725 times)
Offline MickB
Re: CB 500 Four (1972?) Full Restoration
« Reply #975 on: April 12, 2017, 03:49:06 PM »
Cal
I knew you'd come to the rescue.
I'll give the head re-tension a go, the cam chain tensioner was dodgy when I put it back (I was trying to save some dosh, big mistake as the chain is rattling it head off), I'll try to get the adjustment to work.
The big oil issue is in the alternator case, that needs a good close look, I'm wondering if I can just loosen the case bolts a little and just crack the top case like a car hood and replace the oil seal on the crank? It maybe just the oil plug, I'm not sure yet where the oil is really coming from.
Offline AndyH
  • My religion:-
  • Pretty well West of Everywhere in Aus!
« Reply #976 on: April 17, 2017, 05:10:11 PM »
Well I've just finished reading all 46 pages of your resto Mick, and have to say I'm mightily impressed mate!  8)
Having recently acquired a CB500 K1 cafe racer to restore, you're going to be a hard act to follow! ;D
Himble (Andy)
Perth
1971 CB750K1 (US import)
1972 CB500 Four K1 (SOLD)
Previously owned..
1967 Honda Sports 90
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
Offline MickB
« Reply #977 on: April 17, 2017, 06:41:16 PM »
Himble thank you for your comments, but read SohRon's build, puts mine in the shade. After reading SohRon's build it made me go back and do a better job.
Offline AndyH
  • My religion:-
« Reply #978 on: April 17, 2017, 07:05:09 PM »
It's all relative Mick!  SohRon's work is in the stars....mine will be somewhat earth based in comparison!! ;)
I blame it all on my close longtime friend who's a passionate restorer...he sucked me in!! :o
I should also say that I'm pretty impressed with the support you've received from members of SOHC4! ;D
« Last Edit: April 17, 2017, 07:08:23 PM by Himble »
Previously owned..
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
Offline MickB
« Reply #979 on: April 24, 2017, 01:25:26 AM »
The members were great and gave me motivation to get it done. The knowledge base is fantastic.
However after I missed out on BOTM I went into a downward funk, nearly slashed the wrists but slashed the tyres instead.
« Reply #980 on: April 25, 2017, 10:53:02 PM »
Best way to do the cam chain tension is loosen the locknut then hold pressure on the kickstart so the engine is nearly, but not quite, turning over so the front run of chain is tight and whilst holding the pressure nip up the lock nut.
You may have to repeat this a couple of times in different places.
N.B. NEVER UNDER ANY CIRCUMSTANCES try tensioning by putting a screwdriver in the end of the lock bolt !! This will normally, even if very careful, cause the tooth and worm gear to dislocate and never work again meaning head and barrel off the remove and repair/replace tensioner mechanism
Offline MickB
« Reply #981 on: April 27, 2017, 03:28:05 AM »
Thanks for the tip Bryan, you're a mate.
Offline SohRon
« Reply #982 on: December 09, 2017, 11:15:18 AM »
Mark - just wondering if you got your tensioner problem sorted. I've been away for a while and am thoroughly impressed with your progress. What a beautiful bike! Here's hoping everything is squared away and that you've just been too busy riding the bike to post!
Offline MickB
« Reply #983 on: December 10, 2017, 01:00:59 PM »
Hey SohRon long time..
No, when I built it I skimped on buying a new adjuster and only replaced the slipper on the adjuster, a bad decision as you can hear the chain clearly.
However, I bought a 2016 Indian Scout last year and with the new toy the old one was just sitting there so I sold the bike with 47 miles on the clock.
The new owner was happy to fix the cam chain and some other minor issues.
All the best for the new year to all the greasy SOHC blokes working on these classics.
« Reply #984 on: December 10, 2017, 02:02:47 PM »
Wow Mick, so disappointed to hear you sold that bike after all the sweat you put into it.
I have multiple bikes, I just rotate the riding schedule, they are all unique in their own way.
Offline MoMo
  • Ride like you're invisible
« Reply #985 on: December 10, 2017, 06:52:00 PM »
Guess you really like the Scout.   I keep thinking of acquiring one, just wish the wheels weren't black...Larry
