Author Topic: CB 500 Four (1972?) Full Restoration  (Read 147768 times)
Offline MickB
Re: CB 500 Four (1972?) Full Restoration
« Reply #150 on: June 12, 2014, 03:17:17 AM »
Today I started with this
And after doing this
And this
And installing new bushes in both ends
And installing new brushes after cleaning the armature up
b
The new bush
I ended up with this
Tomorrow I'll finish the oil pump
Offline MickB
« Reply #151 on: June 12, 2014, 03:22:25 AM »
This was the end of the 12th day of winter 20 Celsius. Worked in shorts and tshirt.
Sunset
« Reply #152 on: June 12, 2014, 05:41:10 AM »
Great job on the starter.  Wish it was winter here, too hot!
Offline MickB
« Reply #153 on: June 13, 2014, 01:15:54 AM »
Oil pump finished
Before
After
Now the hard part.
Can someone  help me, what am I missing, I've walked away after pulling all apart cleaning, oiling and reassembling I can't see what I doing wrong. There's always tomorrow.
Offline MickB
« Reply #154 on: June 13, 2014, 09:07:38 PM »
I think I've cracked it, I was trying to install the cogs from the incorrect end.
Can someone please advise does this look right?
Regards
Offline MickB
« Reply #155 on: June 13, 2014, 10:08:11 PM »
Don't take any notice of the gunk, I'm still to fully clean the cogs
Regards
Offline MickB
« Reply #156 on: June 14, 2014, 12:24:49 AM »
Got lots done, I'm really keen to get this finished.
Today painted parts, gearbox, cleaned pistons ready.
Big step today
Da Daa
Crank fits beautifully.
Gearbox is the hard one and I've misplaced my manual.
Regards
Offline Oddjob
« Reply #157 on: June 22, 2014, 04:48:28 AM »
Mick those markings you can clearly see on the crank are the ones I was referring to in the other thread. They look like they are all A1 with a 1 on the end, please confirm that.
Also no idea why nobody has mentioned this before but the seat isn't off a 500, the shape of the pan is wrong, the handbook doesn't locate there and there are rubber cushion stops missing. Get some advise before you do any more work on the seat or you may find you've wasted a lot of time and money on something that doesn't fit.
Offline Oddjob
« Reply #158 on: June 22, 2014, 04:59:15 AM »
Also one thing I noticed is that non of the cam covers appear to have a rev counter drive fitted. Is this somewhere else in the boxes or are you missing that piece?
Offline MickB
« Reply #159 on: June 22, 2014, 11:40:05 AM »
Oddjob the crank has all all A1 markings, the seat is (I'm pretty sure) off a 500, I'd removed all the rubbers. But I'll double check.
Thanks for your advice.
Regards
Offline MickB
« Reply #160 on: June 22, 2014, 11:41:09 AM »
Oddjob I bought a tachometer drive and the cap.
Regards
Offline Oddjob
« Reply #161 on: June 22, 2014, 11:55:23 AM »
MIck seat is most definetely not off a CB500K, there are or seem to be 2 seat pans in the pics, neither are even remotely close to being off a 500. The first pic I have no idea what it is, the second is probably off a CB360 as it seems to be stamped with 369 and that's the CB360 model code.
Here's my NOS CB500K1 seat just before I sold it, look at the layout of the rubbers, the placement of the handbook pouch and the place where the hinge bar would go, not there on that pic but you can see the 2 bolts it goes onto.
This is a CB500K2 seat, same layout, only the seat cover pattern changed.
If I had a CB500K0 seat it would be identical except that never got the handbook pouch and the seat lock plunger was much different as it used a different locking system.
Offline Oddjob
« Reply #162 on: June 22, 2014, 12:16:11 PM »
Ok some more observations.
You seem to have a CB500K0 frame but the engine isn't. Or at least the engine your using isn't, the K0 frame and engine numbers all started with a 1, the K1 started with a 2 as did the K2. However the clocks seem to be off a K2 as the K0 and K1 used much smaller clocks, nothing at all like your working on. You may need to check to see whether they will fit the top yoke as the K2 used a different mounting plate to accommodate the larger clocks.
It's coming on though, starting to look the part.
Offline MickB
« Reply #163 on: June 22, 2014, 05:09:06 PM »
Oddjob Engine is marked Cb500E 2......
Am advised built in '72 and probably registered in '73.
Regards
Offline MickB
« Reply #164 on: June 22, 2014, 05:10:13 PM »
Clocks are off a later cb500/ 550 I believe
Regards
Offline Oddjob
« Reply #165 on: June 22, 2014, 11:58:25 PM »
Yeah I read that Mick, I have a copy of Bryans build date list so I was aware of how old it was. My comment was that the bike is a real mongrel of the 500 family ( no offense) frame is a K0 as it begins with a 1 and is about 1 year older than the engine, engine is a K1 and clocks are off a K2. Nothing at all wrong with that and I'm not mentioning the forks  :)
Offline MickB
« Reply #166 on: June 23, 2014, 12:20:01 AM »
It's a mix and match as best I can in Oz, very few 500s left.
I hope you're wrong about the seat
Regards
Offline MickB
« Reply #167 on: June 23, 2014, 12:47:18 AM »
£10 just sent
Thanks Ken
Regards
Offline MickB
« Reply #168 on: June 23, 2014, 12:58:47 AM »
Sing out if post costs more and I'll transfer. M
Regards
Offline MickB
« Reply #169 on: June 23, 2014, 02:37:43 AM »
Oddjob, I'm amazed I just got in Oz a brand new CB500 seat never used.
Regards
Offline Oddjob
« Reply #170 on: June 23, 2014, 09:04:22 AM »
Yeah that looks like a 500 seat pan, doesn't look like the foam and cover are on though. Are they seperate or did you find just the pan?
Offline MickB
« Reply #171 on: June 24, 2014, 05:12:03 AM »
Just got the pan
Regards
Offline MickB
« Reply #172 on: June 26, 2014, 12:35:10 AM »
After reading DLHoulton  http://forums.sohc4.net/index.php?topic=137510.msg1551239#msg1551239. I was given the confidence "to have a go ya mug" as they say in the classics.
I've started spraying 2 coats on my head light after 3 - 4 hours filling, then sanding and then more sanding, and then more sanding, and then more sanding, you get the picture.
From the start
After 2 coats
Next more sanding, then 3 - 4 coats of clear.
Very pleased after 2 coats,
Regards
Offline MickB
« Reply #173 on: July 04, 2014, 01:41:26 AM »
Ended the head light restoration finally.
Today I lapped all inlet & exhaust valves.
Regards
Offline MickB
« Reply #174 on: July 10, 2014, 03:29:57 AM »
Valves lapped, next head and barrels are going on a machine (not sure what it's called) to ensure perfect matched surfaces.
Head painted and ready for assembly.
Regards
