Author Topic: CB 500 Four (1972?) Full Restoration  (Read 145224 times)
Offline MoMo
  • Ride like you're invisible
Re: CB 500 Four (1972?) Full Restoration
« Reply #225 on: August 03, 2014, 07:33:26 PM »
sorry for the hijack Mick and thanks to those who answered my questions.  Back to sohc talk lads...Larry
« Reply #226 on: August 06, 2014, 12:44:49 AM »
and don't use the word clappers,it just causes trouble.
Offline vfourfreak
  • Do you think that's wise
« Reply #227 on: August 08, 2014, 12:01:20 PM »
Yes David,
let us avoid the usage of such words. Oh it is 9pm, the clapper in the bell in the church in town is striking 9 times.
Oops sorry,
Kev
« Reply #228 on: August 10, 2014, 02:47:36 AM »
let me remind you of the last time that word was uttered.
http://forums.sohc4.net/index.php?topic=130299.msg1585129#msg1585129
Offline MickB
« Reply #229 on: August 13, 2014, 11:30:27 AM »
Q. Will the exhaust off a '76 CB 550 fit a 500?
Can anyone advise?
It's this vs $2500+ for 500 exhaust from CSMNL, I don't want to but the cost differential is a big part of the decision.
Offline MickB
« Reply #230 on: August 13, 2014, 11:55:31 AM »
Cal thanks, you're a champ, but I'm still balancing "full restoration" against a major corner cutting with the 550 exhaust. I'm leaning more towards the CSMNL pipes.
Offline MickB
« Reply #231 on: August 15, 2014, 03:31:41 PM »
The verdict will come down to a money decision.  I've asked a manufacturer if they do 4 into 2 pipes (they do them for 750s), I'm waiting for a reply.
Offline MickB
« Reply #232 on: August 16, 2014, 04:47:04 AM »
Finished putting the valve collets in, and completed cleaning and reinstalling all the gears and thrust washers etc.
Got to locate the parts for the Gear Shift mechanism.
Offline MickB
« Reply #233 on: August 16, 2014, 04:53:22 AM »
Valve compressor worked a treat
Offline MickB
« Reply #234 on: August 19, 2014, 03:27:21 AM »
Did a little work on the electrics, started the cleaning process and fitting to the supporting plate.
Offline MickB
« Reply #235 on: August 19, 2014, 10:02:01 PM »
Thanks Cal for your comments, however it's a pretty dark photo, I think I'll take a day time photo.
« Last Edit: August 19, 2014, 10:03:35 PM by MickB »
Offline MickB
« Reply #236 on: August 22, 2014, 07:30:39 PM »
Gear shift mechanism is in, can anyone tell me if it should go further in? It looks like it should, so the steel ball and cap and spring fit into the counter bored slot?
Thank you in advance
Offline MickB
« Reply #237 on: August 22, 2014, 08:09:57 PM »
Can anyone help? Is this correct, I've checked workshop and clymer and can find nothing about correct position
« Last Edit: August 22, 2014, 09:38:08 PM by MickB »
Offline MickB
« Reply #238 on: August 22, 2014, 09:36:57 PM »
After a couple of hours I think I've got figured out. The channel for the ball comes from the top duh! I was looking at it from the inside of the case!!
3 Questions
What length is the spring? Is it
Is this the collar for the ball?
What size is the steel ball?
Can some one please help.
« Last Edit: August 22, 2014, 09:38:53 PM by MickB »
Offline MickB
« Reply #239 on: August 22, 2014, 09:40:09 PM »
Does the gearbox look ok?
Offline MickB
« Reply #240 on: August 22, 2014, 11:11:33 PM »
I think this might be the collar the ball sits on?
Offline MickB
« Reply #241 on: August 24, 2014, 04:08:18 AM »
Can anyone assist with some answers to some questions regarding the steel balls used in the clutch and drum?
What sizes are the balls used in the clutch is says#10, what is that in mm's?
What is the size ball used in the drum in mm's?
What is the length and width of the spring used in the drum stop?
Many thanks in advance
Offline 2strokeTrush
  • Can you get that back together sonny?
« Reply #242 on: August 24, 2014, 05:22:41 AM »
The steel ball just sits freely in the clutch cover, I purchased new ones from Honda 1.00$ (USA) but i dont remember a collar being i there. Could be though.  Gearbox looks good to me, no rust is a positive thing.  As far as going in deeper, the 500's clutches were known to have problems, so there is a way to fix it, but you have to keep going to find out what to fix.
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
Offline MickB
« Reply #243 on: August 24, 2014, 11:54:22 AM »
Thanks you blokes, I was able to get 2 springs off eBay this morning. I just realised I don't need one, another newbie error, oh well just one more the the list.
Ball 1 is at the end of the clutch rod
Ball 2 is at the end of the Drum Screw
Offline MickB
« Reply #244 on: August 24, 2014, 11:57:41 AM »
On CSMNL THERE AR 2 differing setups.
I have the setup in the bottom left of the picture, is the other a different model?
Offline MickB
« Reply #245 on: August 25, 2014, 04:10:07 AM »
Picked up the 2 ball bearings for the clutch and drum.
New OEM horn arrived and new locks for seat, steering and ignition from Z1
« Reply #246 on: August 26, 2014, 01:31:50 AM »
The spring and ball bearing were only used on the very early settup, if you have the two roller settup on the outside behind the clutch you dont use the ball and spring you need the later parts which are the bolt that just has a pin on the end (no hole for spring) and a loose collar that the pin fits inside and locates the selector drum.
If you look at a later parts book it will show you both settups
Offline MickB
« Reply #247 on: August 26, 2014, 02:51:11 AM »
Thanks Bryan, what a great tip as I've been scratching my head about the spring. I have the bolt and collar but no spring (no spring is unusual as when I bought the bike in pieces I've had almost every part, in fact pretty much 2 of everything). I just shone a light in the hole and I don't need a spring at all only the collar and ball, there's not enough room to fit a spring as well as collar and ball.
I have this set up which must be correct for the '72 model? The 2 Stopper parts with little wheels on the ends
« Reply #248 on: August 26, 2014, 10:42:16 PM »
No ball needed just the bolt and collar mate
Offline MickB
« Reply #249 on: August 28, 2014, 01:34:45 AM »
Feel like I'm really starting to make progress - Finished putting the gearbox, primary shaft and crank into the bottom case. The engine is coming together finally! New bearings on primary shaft, other bearings were all good, new primary chain and new shock rubbers in the primary hub (rubber was Oddjob's recommendation)
Got Oil GuideB in ok.
But can someone please help - where does Oil Guide A go? I can see it's meant to go! I can see it on the schematic but that's it, I can't figure out where it fits.
« Last Edit: August 28, 2014, 01:42:07 AM by MickB »
