Author Topic: CB 500 Four (1972?) Full Restoration  (Read 141832 times)
Offline calj737
  • I refuse...
Re: CB 500 Four (1972?) Full Restoration
« Reply #300 on: September 10, 2014, 04:58:16 AM »
I'm GMT -5, but I never sleep anyway.
Can't believe it's time wasting to spend valuable time with a cold and frothy friend??? I'd rather see you devote some idle to that undertaking than dither away scrubbing on rusty metals. Let the goo do the work while you reminisce about the good times forthcoming with a mate. Much better, no?
If our passion for these machines is due to them having a soul, and our interaction with it, then surely it's food to feed ours that we embrace camaraderie and fellowship with beer and mates while we work on or ogle them.
That's my story, and I'm sticking to it  ::)
Offline MickB
« Reply #301 on: September 10, 2014, 05:51:44 AM »
Cal it was a joke, the problem with short notes you can't see the smile on my face as I'm typing. Tongue in cheek.
I still can't believe I'm doing up a 500, last time I rode one was when I was 20 and I loved it.
In some respects I'm enjoying the journey of the restoration rather than the arrival. I can now see the end of the build, I've really enjoyed the camaraderie and encouragement from those who've helped in many ways. Stop it now or you'll make me blubber.
Offline calj737
  • I refuse...
« Reply #302 on: September 10, 2014, 07:17:03 AM »
I saw it. And replied entirely tongue in cheek. Let the blubbering commence.
Offline MickB
« Reply #303 on: September 10, 2014, 04:23:35 PM »
Very impressive and detailed!  Subscribed!  Do not forget the big one rings that go on the outside of the cylinders. Do this before putting the cylinders on the lower end.
Tews I read this in Bootsey's build and am wondering what exactly are you saying?
"Do not forget the big one rings that go on the outside of the cylinder"
Can you please expand on this or explain to me in simpler terms.
Offline Bootsey
« Reply #304 on: September 10, 2014, 04:46:36 PM »
These here suckers.
Offline Tews19
  • I am no
« Reply #305 on: September 10, 2014, 05:50:18 PM »
Those are the O rings. Sorry I do most responds in threads on my phone and it has crazy auto correct. Bootsey to the rescue!
1970 Honda CB750 survivor.
Offline MickB
« Reply #306 on: September 14, 2014, 11:13:34 PM »
All in all it's just another couple of bricks in the wall. A couple more pieces for the jigsaw
l
Just waiting for the swinging arm bolt to marry the nut
Cal by the way, I saw your comments in Dave Barbier's build about changing the clutch plates, cork plates and springs!
You just cost me another couple of hundred bucks -THANKS A LOT, as I thought the clutch I had was ok, but you said to Dave "seeing you're going to all this trouble in the build....."
Then I realised I should also fix the clutch properly in my resto.
« Last Edit: September 14, 2014, 11:32:44 PM by MickB »
Offline calj737
  • I refuse...
« Reply #307 on: September 15, 2014, 04:09:06 AM »
I know the economy in Oz is a bit soft, thought I'd do my part vicariously through you.  :)
Where's your swing arm bolt? And tell me you've found a source for a beautiful stainless steel cotter pin for that rear axle. Wouldn't be right slapping any old piece of pot metal in there.
Offline MickB
« Reply #308 on: September 15, 2014, 04:11:51 AM »
Cal I'm still waiting for the Chromer to finish the SWA Bolt, it'll be ready on Saturday.
Offline MickB
« Reply #309 on: September 19, 2014, 03:02:23 AM »
Was able to finish the alloy including carby bodies polishing and lacquering, it's ready for the build - when will the rezinced bolts be ready?
Next true the wheels and fit tyres, not far away before I start building.
« Last Edit: September 19, 2014, 03:09:39 PM by MickB »
Offline MickB
« Reply #310 on: September 23, 2014, 03:13:01 AM »
Today I picked up the re-zinced nuts, bolts, washers and other parts, I can now start on the engine build all the engine bolts are back.  Long engine bolts zinced and the swinging arm bolt chromed - all nice and shiny.
Offline calj737
  • I refuse...
« Reply #311 on: September 23, 2014, 06:06:31 AM »
Mick - be careful with a few of those that were corroded heavily before re-plating. Torquing them down might shear them. To be certain, I'd install them in a test first. Use only the bottom half of the case before fully assembled. Use a bit of lube in the threads, then torque carefully into the bottom half only. This way, if it does shear, you aren't separating the case to retrieve it.
If I had known yours were so badly damaged, I'd have sent you some from one of my motors that weren't buggered up...
And just makes sure you do use thread lube or sealant in all of them installing into the aluminum cases.
Offline MickB
« Reply #312 on: September 23, 2014, 12:01:00 PM »
Thanks Cal, I sorted through them last night into sizes, I saw what you meant about corrosion, I'll be flicking them. However when sorting, most seemed pretty good, but as per your advice I'll test them up to torque spec before I use them.
I appreciate your advise particularly about the bottom half.
I've copper grease for the threads, locktite to use where recommended and gasket sealant. I need to get some surface cleaner.
Cal in the photos can you point out any specific bolts you believe would be suspect?
Or, are you suggesting I should get new nuts and bolts? If you think i should I don't have an issue with that.
« Last Edit: September 23, 2014, 12:05:46 PM by MickB »
Offline calj737
  • I refuse...
« Reply #313 on: September 23, 2014, 12:06:14 PM »
The bolts that "concern" me the most are the M8 flange heads pictured with the pivot bolt. They are the case bolts and they do need full torque. The M6 won't require much more than a firm hand tight, but the case bolts do get a wrench to them.
Offline MickB
« Reply #314 on: September 23, 2014, 12:09:30 PM »
I'll be vigilant in my testing before usage, thanks again for your advise.
Offline MickB
« Reply #315 on: September 23, 2014, 12:14:53 PM »
Cal what I really need to do is make sure I've the correct number of bolts prior to assembly, which is something I didn't think of prior to getting them zinced.
I tried to take note of SohRon's tip about getting bolts that looked in good condition from eBay.
To me the flange bolts looked in pretty good condition. I'll take some photos of the flanged ones and post them for a better inspection.
« Last Edit: September 23, 2014, 12:19:24 PM by MickB »
Offline MickB
« Reply #316 on: September 23, 2014, 04:11:50 PM »
Cal you mention "concerns", can you explain specifics? Or was it the heavy corrosion?
Offline calj737
  • I refuse...
« Reply #317 on: September 23, 2014, 04:19:01 PM »
Yeah, it was just the corrosion on those bolts that caught my eye. I italicised it as a reference. I always either run them on a wire wheel to remove the corrosion, then test their torque strength. Or, I replace them. I've had to make a few that seem unobtainable.
Offline MickB
« Reply #318 on: September 23, 2014, 04:21:37 PM »
Thanks mate
Offline MickB
« Reply #319 on: September 26, 2014, 04:28:06 PM »
Some Questions
1. Is this the Oil Control Orifice (description is from the parts list), it fits the top case
2. This is the picture from the parts list
3. Does anyone have a spare? I only have 1
Offline MickB
« Reply #320 on: September 28, 2014, 01:22:48 AM »
Was able to purchase the Oil Control Valves (thanks Mo), however, it's moving slowly at present, got only little bits done nothing major.
Finished the battery box
Must true the wheels next.
« Last Edit: September 28, 2014, 04:58:00 AM by MickB »
Offline MickB
« Reply #321 on: October 04, 2014, 03:30:08 PM »
Still moving at a snails pace, but I got the swinging arm in and the snapped the grease nipple in half on the new chromed SA bolt - aaaah!
Got back a stack of various items rezinced both in silver and gold
Offline MickB
« Reply #322 on: October 07, 2014, 11:12:10 PM »
One more step in the long march, polished the breather, now have lots of parts completed and ready for installation.
Also,  parts arrived from CSMNL - seat rubbers  and David Silver - blinkers, Airbox Drain Tube and 4 new chrome  screws for the front mudguard.
Next big job is the truing the wheels, got to stop procrastinating and get rubber on them.
Any suggestions regarding tyres would be most welcome.
« Last Edit: October 08, 2014, 12:04:45 AM by MickB »
Offline MickB
« Reply #323 on: October 09, 2014, 02:11:48 AM »
Getting a start on the seat, repo pan (fiberglass) and foam (thanks Chaser), drill where rubbers are to be mounted
and decide on whether to rivet seat cover to the pan, open to suggestions.
Waiting on chrome strip from SohRon's tip where to buy it from, the strip is far deeper than most that advertise on eBay.
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #324 on: October 09, 2014, 03:32:38 PM »
Where did you get the seat cover? (website)
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
