Author Topic: CB 500 Four (1972?) Full Restoration  (Read 140464 times)
Offline MoMo
  • Ride like you're invisible
Re: CB 500 Four (1972?) Full Restoration
« Reply #350 on: October 23, 2014, 03:58:07 AM »
You are right -no spokes should stick up. True the vertical hop first then lateral side to side...Larry
Offline MickB
« Reply #351 on: October 23, 2014, 04:23:57 AM »
 Larry thanks for the confirmation, the problem is, It's got me how to do it. I've got to read up and figure it out.
I presume I need to drawn the hub closer to the centre, there's obviously a way to determine the best way to do that.
It's a steep learning curve.
Offline calj737
  • I refuse...
« Reply #352 on: October 23, 2014, 04:46:49 AM »
Mick - start over by loosening all spokes so they're same length. Then, turn, tighten in sequence, spin, tighten little by little. This should get you even length and true. It's a gentle process of tiny adjustments.
Hard the first time, easy the 20th.  ::)
Offline MickB
« Reply #353 on: October 23, 2014, 04:56:06 AM »
Thanks Cal, next time'll be try number 4.
Offline calj737
  • I refuse...
« Reply #354 on: October 23, 2014, 04:56:42 AM »
1/5 the way to competent then!
Offline MickB
« Reply #355 on: October 23, 2014, 05:05:38 AM »
Getting the wheels then rubber on them will be a huge step, then insert engine.
Offline MickB
« Reply #356 on: October 23, 2014, 05:07:13 PM »
Can someone please advise if the exhaust collars were  chromed or zinc when new?
« Last Edit: October 23, 2014, 05:09:10 PM by MickB »
Offline MickB
« Reply #357 on: October 23, 2014, 07:32:24 PM »
Cal after sleeping on it and another 2 1/2 hours, I'm pretty happy with the front wheel.
I started by bringing up (closer to the hub) the half (marked with tape) where the rim was out by about 1 cm.
Loosened the opposite spokes and gradually brought the rim up and after I was reasonably happy with the getting the rim round I finished getting rim straightened. Is 50thou still too much, it's not much with the naked eye.
Comments are welcome if needs to be better.
Offline MickB
« Reply #358 on: October 24, 2014, 03:42:27 AM »
Was able to get the front wheel truer than earlier with more tweeking and the back wheel started with anti seize grease  on all spokes and was much easier than the front, pretty much straight and the axle was only a few millimeters off.
Offline MickB
« Reply #359 on: October 24, 2014, 03:45:12 AM »
[quote
« Last Edit: October 24, 2014, 03:47:04 AM by MickB »
Offline oasis
« Reply #360 on: October 24, 2014, 11:32:56 AM »
Looks awesome, love the way the wheels turned out!
mike
75 Honda CB750, 74 Honda CB750, 05 Honda RC51 SP2, 05 Ducati 999r, 03 Ducati Monster 1000s, 96 Kawasaki zx7rr n-1, 08 Ducati Monster S4RS TriColore, 71 Vespa Rally
Offline MickB
« Reply #361 on: October 24, 2014, 02:02:24 PM »
Thanks Mike
Offline calj737
  • I refuse...
« Reply #362 on: October 24, 2014, 02:38:12 PM »
She's turning out top notch, Mick! Tremendous result for your efforts  :)
Offline MickB
« Reply #363 on: October 24, 2014, 02:59:24 PM »
Thanks Calj
DH
« Reply #364 on: October 24, 2014, 03:20:49 PM »
This is the coolest part/segment of the build Mick. At least, imo. You're actually getting a hint of what it's gonna look like as it slowly takes shape.  8)
Offline calj737
  • I refuse...
« Reply #365 on: October 24, 2014, 03:24:57 PM »
A little commentary: oddly enough, there are those who would never ride a bike so meticulously restored and pristine as you're building. Me, I'd never undertake this level of restoration as its not my interest. But, if I did, I'd ride the bike every day, everywhere. I think the best testimony to these machines is their classic beauty and reliability. And if they get dirty or scratched, well, just fix her up again  :D
I sure hope you enjoy this thing immensely and regularly, Mick. It reflects your attention to detail and deserves to be shared on the open road for many others to admire.
Hats off to a real pro!
Offline MickB
« Reply #366 on: October 24, 2014, 03:36:14 PM »
I don't don't feel like I'm a pro Cal, just a plodder.
Offline MickB
« Reply #367 on: October 24, 2014, 05:45:08 PM »
Can someone please advise if the exhaust collars were  chromed or zinc coated when new?
[/quote]
« Reply #368 on: October 24, 2014, 06:24:39 PM »
Collars were zinc'd...   Nice job on the rims.
Offline MoMo
« Reply #369 on: October 24, 2014, 06:25:27 PM »
Not chrome-Honda would not have spent the extra money for that
Offline MickB
« Reply #370 on: October 24, 2014, 06:50:19 PM »
Thanks for the compliment Steve.
Honda led the way with plastic though!
« Last Edit: October 28, 2014, 11:02:00 PM by MickB »
Offline MickB
« Reply #371 on: October 27, 2014, 01:55:14 AM »
Wheels went in today to get tyres and balance. More back from chromers.
Question. Is the Throttle Shaft chrome or zinc? I was told if it's chromed I'll have difficulty getting the joint connectors on to it.
Offline calj737
  • I refuse...
« Reply #372 on: October 27, 2014, 04:54:07 AM »
Zinc. You're certainly providing a University Fund for your Chromer's kid, Mick  ::)
Offline MickB
« Reply #373 on: October 27, 2014, 11:09:37 AM »
Thanks Calj
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #374 on: October 27, 2014, 05:27:57 PM »
You know just a thought, you might want to put tires on those rims, otherwise might be a bumpy rough ride, I just sayin'
Nice job!
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
