Author Topic: CB 500 Four (1972?) Full Restoration  (Read 145237 times)
Offline Bootsey
Re: CB 500 Four (1972?) Full Restoration
« Reply #425 on: November 27, 2014, 10:11:32 PM »
Looking good Mick. Did you leave some bare metal contacting between the engine and frame to ensure a good earth?
Offline MickB
« Reply #426 on: November 27, 2014, 10:15:41 PM »
No, I never even thought of  it, I better do it right now.
Thanks Bootsey.
Offline Bootsey
« Reply #427 on: November 27, 2014, 10:21:48 PM »
Hopefully someone else might confirm before you go hacking up your paint, but pretty sure it needs to be done. Hopefully I haven't given you a bum steer.
From SohRon's 550 Gospel.
One thing to mention about the above pic is something we've discussed before, but bears repeating: All of the frame mounts here have been sanded down to bare metal front and back, and the engine has been relieved of paint as well, so that a good ground connection exists between the frame and engine. All of the exposed metal has been coated with dielectric grease in an effort to cut down on corrosion at these connections.
« Last Edit: November 27, 2014, 10:57:01 PM by Bootsey »
Offline MickB
« Reply #428 on: November 28, 2014, 02:12:15 PM »
I'd defer to SohRon's expertise after seeing that 7 year restoration.
I'm cutting of the paint this morning.
Offline MickB
« Reply #429 on: November 28, 2014, 10:47:35 PM »
Made sure the engine's got a good earth, all engine mounts have metal to metal.
Exhaust doesn't fit properly, I'll have to grind the welds and get it to fit then reweld and rechrome.
Gauges, foot brake and kick start on.
A 40mm bolt fits does it go there as I can't see it on any drawing.
Couldn't resist sitting the tank and seat on, the straight bars are too short.
I don't want to rush it but I can see the end coming in about 2 months.
Offline Valhad
  • Clearly they let anyone call themselves a
« Reply #430 on: November 29, 2014, 08:38:06 PM »
Just beautiful work you're doing, Mick. And at an impressive pace, by my book. Thanks for letting us all in pictures.
Speaking of, did you ever get the pictures you were after to clarify the steering lock?
In the works:
1972 CB500 project
Rideable:
1972 CB500
1975 Kawasaki S3 400
1982 Kawasaki KZ250
Offline MickB
« Reply #431 on: December 12, 2014, 12:00:49 AM »
Just got the front and rear guards from the chromer.
You'll notice the chrome is slightly dull this is because it's got a film of oil over them.  Ultimate Shine suggested to tip the guards upside down and  pour oil into the rolled edges of the guards and all the brackets welded on the underside to ensure rust is minimised, all done.
Got new points and condensers, carby clamps, fuel line and clamps.
« Last Edit: December 12, 2014, 12:04:56 AM by MickB »
Offline MoMo
  • Ride like you're invisible
« Reply #432 on: December 12, 2014, 01:46:09 AM »
Interesting idea about the oil, does make sense.  Bike is coming along and looking good...Larry
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #433 on: December 12, 2014, 09:57:49 AM »
The chrome looks great, I need to re-chrome my 500, you can find new 750 rear fenders but not 500 rear ones.
Im wondering if a 750 will fit and look correctly on a 500., Im looking onto re-chroming if cant find a new one.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Offline MickB
« Reply #434 on: December 12, 2014, 11:55:57 AM »
RTB I think you'll have to get and rechrome an old one, that's what I had to do.
Offline rtbmrgl
« Reply #435 on: December 12, 2014, 12:28:25 PM »
thats, for info, I also need the fork ears done. I just got a new 750 fender thats works fine.
thanks, Mark
Roseville, Ca
Got Points!
Offline MickB
« Reply #436 on: December 14, 2014, 02:01:03 AM »
Got a bit more done, finally finished the front end, really pleased. Only thing is to fill the forks with some ATF.
Rear guard and blinkers on, waiting on a new rubber gasket for the tail light, tail light is at the Chromer.
New points and condensors, haven't set the gap as yet on the points. .
Rocker cover on but I'll need to take it off again as I found a stripped thread in the head. Still need to do the tappets.
Exhaust I bought doesn't fit so I'll need to do some modifications, then re chrome.
Got a reasonable tail light for $15, drop in at the chromers tomorrow.
g
« Last Edit: December 15, 2014, 09:42:12 PM by MickB »
Offline MickB
« Reply #437 on: December 21, 2014, 03:33:54 AM »
Tail light back from the chromers, started rebuilding the carbies.
Still waiting on the rubber gasket between the guard and tail light.
Have to use some heat shrink tubing under the guard, when the guard was repaired some of the metal and wiring tunnel was cut away to get the dints out of the guard.
Offline MoMo
« Reply #438 on: December 21, 2014, 03:52:36 AM »
WOW,  he does beautiful work.
« Reply #439 on: December 21, 2014, 08:46:49 AM »
Nice work.  We used to have plenty of platers available here, but environmental regs dried them up.
Offline MickB
« Reply #440 on: December 21, 2014, 09:50:31 AM »
I'd comb my hair if I had enough to stay down. Some people are picky picky.
Just noticed the finger print smudges on the chrome.
And btw, the Honda tail light could be used on a jumbo jet it's so huge.
« Last Edit: December 21, 2014, 09:53:03 AM by MickB »
Offline MoMo
« Reply #441 on: December 21, 2014, 07:43:29 PM »
MoMo you took the words right out of my mouth!
Down side to chrome that pretty is the quality of reflection would embarrass me that I'd have to comb my hair and shave before approaching the bike; wouldn't want to catch a glimpse of myself before I rode off...  :o
I don't have to worry about hair to comb, plus I don't cast reflections ::)
Offline MickB
« Reply #442 on: December 23, 2014, 02:51:54 AM »
Touché
Offline rtbmrgl
« Reply #443 on: December 24, 2014, 04:46:40 PM »
Wow i have got to get some re-chroming on mine. Thats gorgeous
thanks, Mark
Roseville, Ca
Got Points!
Offline MickB
« Reply #444 on: January 23, 2015, 03:21:23 AM »
Just easing back into the build after 3 weeks in Queensland and 2 back working, I've started on putting the carbies back together. I realise when dismantling I didn't take anywhere near enough photos.
I think Dave Barbier put Alen heads on the carby clamps, and it looked good so I copied you Dave.
Question the schematic shows a spring and a 5/16 ball bearing. Does anyone have a photo of where they go? I can't figure it out from the drawing.
More carby photos.
Lviv
« Last Edit: January 23, 2015, 04:17:58 AM by MickB »
Offline MickB
« Reply #445 on: January 24, 2015, 01:38:57 AM »
Can someone please advise exactly which orifice does the spring "3" and ball "90" go?
DH
« Reply #446 on: January 24, 2015, 08:49:43 AM »
Mick, if memory serves me, the spring and ball go into a cavity behind , (and are held in, by) part #47 on carb #1.
They are used as part of the choke linkage and serve as a "detent".
« Last Edit: January 24, 2015, 08:53:03 AM by DH »
Offline MickB
« Reply #447 on: January 24, 2015, 12:58:28 PM »
Thanks DH, I see now where jit's got to go, carb 1 has the little orifice where it fits and 47 holds it in place. You had me with detent (a very technical term, I had to look it up).
I wonder why they don't have the spring and ball on all 4 carbies?
« Last Edit: January 24, 2015, 01:08:28 PM by MickB »
Offline MickB
« Reply #448 on: January 24, 2015, 02:26:11 PM »
Question I'm going to use a 4 into 2 exhaust with baffles. What jetting should I use?
Currently I've got what I think is a stock set up - 100 and 40 in the carb I rebuilt so far.
DH
« Reply #449 on: January 24, 2015, 08:55:08 PM »
Aww c'mon mick, you're makin me sound smart cuz I use them fancy words ;D.....I'm thinking they didn't use them on all 4 carbs due to high effort it would take to apply the choke(?) We may never know.
