Author Topic: CB 500 Four (1972?) Full Restoration  (Read 145238 times)
Offline MickB
« Reply #450 on: January 24, 2015, 09:11:52 PM »
DH Smarter than the average bear, they're only tiny springs.
Offline MickB
Re: CB 500 Four (1972?) Full Restoration
« Reply #451 on: January 26, 2015, 02:21:34 AM »
Finished the carbs this arvo.
Hopefully on the bike tomorrow.
More carb pictures
Can someone advise me how tight the nuts are where the 2 little flat springs (are between 1&2 and 3&4) go into the holder then attach into the carby stay plate?
« Reply #452 on: January 26, 2015, 10:17:52 AM »
Don't forget to attach fuel pipes whilst carbs on bench , its a swine when they are fitted
Offline MickB
« Reply #453 on: January 27, 2015, 12:27:15 AM »
Thanks Bryan, I've just worked that out tonight, just pulled 3&4 off to fit the hose.
Offline MickB
« Reply #454 on: January 28, 2015, 10:16:06 PM »
Just bought SS 3mm screws to replace the rubbish screws on the choke flaps and the throttle valves.
« Reply #455 on: January 29, 2015, 12:19:00 AM »
Careful what and how you fit to choke flap as anything that unscrews will destroy the engine
Offline MickB
« Reply #456 on: January 29, 2015, 12:45:29 AM »
Thanks Bryan I'll use a little locktite on the screws. They were tight anyway but the locktite will make it more secure
Offline Restoration Fan
  • My wife will never call me
« Reply #457 on: January 29, 2015, 03:20:28 AM »
Did you buy those at a store or as part of a kit?
I'm about to purchase the same thing.
Offline MickB
« Reply #458 on: January 29, 2015, 01:14:17 PM »
Resto Fan I bought them at at at place called Boltmaster in Sydney, they've had every nut and bolt I needed.
Offline MickB
« Reply #459 on: January 29, 2015, 01:21:30 PM »
Anybody notice the deliberate mistake, the carby drains are all pointed inwards! Doh!
Offline MickB
« Reply #460 on: January 31, 2015, 01:15:02 AM »
Finished installing fuel lines on the carbs today (after having to take them off the support plate) then bench synced the carbs. Bryanj I doubled checked the choke screws all nice and tight
Carbs are connected to the engine, thanks SohRon for your thread it was made easier.
Installed the new oil pump pressure switch
New rear brake shoes were meant to be fitted today after the carbs, but it always takes longer when you've never done it before.
Can anyone assist? What is this from because I can't remember?
« Last Edit: January 31, 2015, 03:11:26 AM by MickB »
« Reply #461 on: January 31, 2015, 03:33:23 AM »
Mick,
Just reread your thread from start to finish.  Amazing work, man.  You're getting close now!
Offline MickB
« Reply #462 on: January 31, 2015, 12:36:35 PM »
Thanks Ron, a lot of help from Calj, Bryanj, DH and many with advise and what to watch out for.
Others who have been encouraging, and also, all the blokes that published on tips and tricks.
I've made plenty of mistakes, some of the build is not as I would have liked due to lack of funds. I would have liked to have fully rebuilt the engine but the cost was prohibitive.
And I've got to make it run yet!
« Last Edit: January 31, 2015, 12:40:47 PM by MickB »
Offline Valhad
  • Clearly they let anyone call themselves a
« Reply #463 on: January 31, 2015, 04:35:02 PM »
At a guess, that looks like it might be part of the electrical plate? The bit the blinker relay rubber mounts on?
In the works:
1972 CB500 project
Rideable:
1972 CB500
1975 Kawasaki S3 400
1982 Kawasaki KZ250
Offline MickB
« Reply #464 on: February 01, 2015, 02:10:31 AM »
Valhad I think it must come from another bike as the electrical support plate already has the blinker support.
I'm going to install the air filter next and have a question.
The tube that connects to the bottom of the filter box has a small piece of sponge in the large end of the tube, does it remain or should it be pulled out?
The schematic shows a hollow tube at the wide end.
Part number is correct.
Note the sponge in the wide end.
I've got to get a new piece of wire gauze as this one's rusted.
« Last Edit: February 01, 2015, 02:15:38 AM by MickB »
DH
« Reply #465 on: February 01, 2015, 08:27:04 AM »
Mick, Not 100% sure, but I think the "sponge" in the end of the tube is a filter to keep out dirt / water.
maybe someone else will add here.....If the metal screen is still in one piece, and still strong and resilient, try soaking it in white vinegar for a while, and take any necessary steps afterwards to stop flash rust. Lookin good Sir 8)
« Last Edit: February 01, 2015, 08:29:18 AM by DH »
Offline MickB
« Reply #466 on: February 01, 2015, 09:50:25 AM »
Thanks DH for comment and advise regarding the rust.
However regarding this tube.
SohRon quotes:-
The two final parts that finish up the installation are the drain hoses for the filter/element case and the plenum. They come in two sizes, and while they may look similar, they're actually quite different
The longer hose is the plenum drain hose. It is has an internal foam filter
Foam filter. Remove this when using hose for drain on the filter/element case
Its primary purpose is to drain any gas that might somehow escape the carbs and splash into the plenum. The foam acts as a kind of barrier that lets gas out but doesn't let in a lot of air or debris, so that the correct pressures are maintained inside the plenum during engine operation. It connects to the plenum via this outlet formed into the plenum body where it's secured by an omega clip
This photo is of the Plennum (left) and Air Filter Housing (right).
... the plenum hose can still be had and, with a couple of mods, will work fine. Just cut it to length and remove the internal foam filter mentioned previously.....
I'm confused, do I leave the sponge in or remove it?! Does it drain or keep stuff out of the air filter housing
It finally dawns on me, the 500 doesn't have a Plennum drain, so there's no tube needed, therefore the sponge comes out as it's going into the filter housing; per SohRon's comment ... Foam filter. Remove this when using hose for drain on the filter/element case.
Problem solved unless anyone else disputes my finding.
« Last Edit: February 01, 2015, 10:11:00 AM by MickB »
DH
« Reply #467 on: February 01, 2015, 07:49:45 PM »
SohRon quotes:-
Sounds plausible to me :) Either way I'd think you can't go horribly wrong. I'd go with Ron's method as well.
Offline MickB
« Reply #468 on: February 01, 2015, 10:04:35 PM »
Can someone advise where I can get replica electrical connector blocks to suit the electric plate.
Thanks in advance.
« Reply #469 on: February 01, 2015, 10:29:25 PM »
Those are not easy as the round pin ones were only fitted for about the first 6 months, if its the sub loom on the electrical plate you could try Western Hills Honda for the early part, they also sometimes come up on ebay
Offline MickB
« Reply #470 on: February 02, 2015, 12:55:47 AM »
Well now I see the drain tube is on the Plennum after thinking it was on the body, all I have at the base of the air filter is a small hole.
Offline MickB
« Reply #471 on: February 03, 2015, 02:14:17 AM »
Thanks Cal
Offline MickB
« Reply #472 on: February 03, 2015, 02:17:18 AM »
Air filter on thanks to SohRon for his little how to install the air filter box in one easy lesson.
Waiting on part #10 listed on  the air filter schematic, I got the last one in Australia.
Offline MickB
« Reply #473 on: February 06, 2015, 11:46:45 PM »
Moving along - installed new rear brake shoes, new coils and drilled handlebars for wiring.
Handlebars with clutch and handbrake.
Installed throttle cables
Is the spring installed correctly as the throttle doesn't snap shut.
« Last Edit: February 06, 2015, 11:48:37 PM by MickB »
Offline MickB
« Reply #474 on: February 07, 2015, 12:24:28 PM »
Thanks Cal, but I realized I've forgotten to put the spring with the plastic cover on that goes in between carby 2 & 3.
No raw aluminum, it's  there to clamp the handlebar in place, I have 2 of the clamps, the other one is being painted.
« Last Edit: February 07, 2015, 12:39:35 PM by MickB »
