Need some help/ advice/ comments for those know this far better than I.
Is this advance mechanism correct for my 500?
Also note the little dot on top of the advance is it set in the correct position?
Timing
1. I've set the left cylinder to just on TDC
2 the cam is set to the notch half way in the notch level with the head
3 the advance is set to the mark on the engine
You'll notice The advance mechanism is not quite spot on with the notch, it's close but not exact, is this OK?
M
Will it run on this setting? Even though I've still to set the points.
Am I on the right track?
After thinking and reading I now think I know what I've done wrong.
