Red wire= fused wire that supplies 12v. to the key switch
Black wire= Gets 12v when keyswitch is turned ON
Yel/red wire= goes to start button, where it gets grounded if the start button is pressed. This the wire that
activates the starter relay internally. when the relay is activated by this wire, it has the same effect as jumping the big terminals on the outside of the relay with a screwdriver.
Red/white wire= feeds 12v. to rectifier assy. It should always have 12v., regardless of keyswitch position, on or off.
viewing the relay as if it were a clock, and the small black wire comes out of the relay housing at the 6 o clock position, the LARGE relay terminal that connects the BATTERY + cable, red fused 12v, and red/wht going to rectifier, WILL BE ON THE RIGHT.
The STARTER CABLE mounts by itself on the LEFT.
Someone verify this please.....Ya .beat me cal
