Author Topic: CB 500 Four (1972?) Full Restoration  (Read 144733 times)
Offline MickB
« Reply #950 on: May 26, 2016, 04:05:11 AM »
Cal, big thanks for your advice today.
I found the wire that was causing the short, it was the Black & White wire coming down from the kill switch to the plug in the headlight then goes to the coils.
I pulled the switch apart - tiny springs and ball bearing, tested the Black kill switch wire no buzz!
Tested the Black & White wire at the kill switch - BUZZ! Unplugged the Black & White wire in the headlight- NO BUZZ at the kill switch.
Put the switch back together.
Tested the Black & White wire (unplugged) going away from the headlight to the coils - BUZZ! The culprit finally.
PS had a mate's son come over and helped put the headlight switch together, I needed 4 fingers in there, hold the switch, put the base into the slots and put the ball bearing on top of the spring and slide it into position - done.
Bonus was he found the lost ball bearing stuck in the grooved part where the throttle goes.
« Last Edit: May 26, 2016, 04:13:39 AM by MickB »
Offline MickB
Re: CB 500 Four (1972?) Full Restoration
« Reply #951 on: May 26, 2016, 04:28:46 AM »
Still to put together the top and bottom of the control then find where the short is, the last thing I want to have to do is cut into the main harness.
Won't the Black & White still short out seeing it's connected to the coils?
Offline b52bombardier1
« Reply #952 on: May 26, 2016, 04:44:16 AM »
If I'm seeing this correctly,  the coils would be a proper "load", not a short. And this would be normal.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline MickB
« Reply #953 on: May 26, 2016, 04:46:46 AM »
Thanks Rick hope you're right, electrics aren't my strong point. If I'd realised about the b&w wire coming from the kill switch I could've saved myself a heap of work by just disconnecting the b&w wire.
Offline Lostboy Steve
« Reply #954 on: May 26, 2016, 06:32:07 AM »
You need to install the slow blow fuse...  Like this:
That is the most awesome photo!
www.lostboysatomicgarage.com
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline MickB
« Reply #955 on: July 24, 2016, 04:13:49 PM »
It's been a while, had problems with a shorting stator, replaced with another stator and Ricks reg/ rectifier all good now and charging at 14.5v.
Decided also to replaced the old plugs (which were causing problems, not connecting correctly).
Noticed a small oil weep at the left side of the head, either a rubber puck or O ring, I hope it's not the O ring that's inbetween the head and barrels.
« Reply #956 on: July 24, 2016, 10:57:40 PM »
Smart move on the connector block & connectors replacement...it really takes that issue out of the equation when troubleshooting. Another thing I have ran into a couple times on cars was the connector was pushing back out of the connector block and it was not readily apparent. It is a real pain in the but to diagnose and sometimes it takes a close look to spot it.
Offline MickB
« Reply #957 on: August 06, 2016, 02:21:56 PM »
I've been wanting a new bike and have ridden HD Sporty (unimpressed), Full Dresser (too heavy), 2008 Softail Custom (too old), Triumph T120 (a great bike), T100 (needed a 6th gear), Tiger 1050 (didn't like it) and Indian Scout - loved it after riding 20 yards in the dealer parking lot!
Drove to Buderim in Queensland 1,100 kms from me and just bought me a 2016 Indian Scout, 2,400 kms, new Ikon rear shocks and front springs, wire wheels with Metzler White Walls, EJK Power Kit and Crusher Pipes all fitted by previous owner (same age as me and really nice bloke) who said he couldn't get used to the riding position, he had 2 fully restored Triumphs- 1970 Bonneville, X75 Hurricane and a beautiful BSA Rocket 3. He's going to buy the new Triumph Thruxton R.
I'm in love
His old Trumpies
« Reply #958 on: August 06, 2016, 03:09:35 PM »
I'm in love
His old Trumpies
Nice new ride.  I just purchased a Thruxton R, so I guess I'm in the seller's camp.  That Scout looks good.  The Victory Octane, too.
Online Stev-o
« Reply #959 on: August 06, 2016, 03:52:01 PM »
Congress Mick, looks like a nice bike.  Very reasonably priced too, only $9K new over here...
http://austin.craigslist.org/mcd/5692087708.html
Offline MickB
« Reply #960 on: August 07, 2016, 01:59:58 PM »
Thanks Stev o, add on 35% for the US$9,000 to Aussie$12,135, then add shipping costs, dealer delivery, import tax, GST and a profit margin, there's the difference.
« Reply #961 on: August 08, 2016, 03:56:21 AM »
How do you like your Polaris Indians overall performance? It's a very pretty bike. I've always loved Indians and these are no exception.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline MickB
« Reply #962 on: August 17, 2016, 12:01:26 AM »
Lostboy I loved it after 20 yards, I test rode one for 2 days and I was getting me one. I think I was always wanting a Scout over the last 2 years.
I rode 4 HDs and wasn't all that impressed, a bit agricultural in comparison to the Scout's twin overhead cams and all the new engineering.
I also tested the Triumph Tiger 1050- didn't like, the 865 Bonneville - it needed a 6th gear in my opinion. Lastly the Bonneville T120 - 1200 cc water cooled head, but I'm past a sports bike.
I'd been looking for 2 months and this came up:-
2400kms on it, new Ikon shocks and stiffer  Ikon front springs, Crusher pipes, wire wheels, white wall tyres and EJK kit.
Here it is again.
« Reply #963 on: August 17, 2016, 03:52:07 AM »
Here it is again.
That is a great explanation. Lol agricultural. Harley does love that primitive technology. Very cool bike. I don't ride enough to get one and keep my others. Enjoy it!
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #964 on: August 17, 2016, 09:50:15 AM »
Mick,
Is the bike complete now? I think it slipped through the cracks of this month's BOTM.
Offline MickB
« Reply #965 on: August 17, 2016, 02:00:41 PM »
Here it is registered and on the road, I've had blokes at the lights, car windows wound down and passing comments at me while riding - looks great, looks amazing, I had one of those, good to see a CB500 on the road again etc. etc.
In the photo where it's parked at my daughters place, cars stopping to look and take photos.
Getting ready to go and get a road worthy (blue slip in Oz) certificate.
« Last Edit: August 17, 2016, 02:03:03 PM by MickB »
« Reply #966 on: August 17, 2016, 03:08:19 PM »
Truly beautiful Mick.  A BOTM nomination is coming your way next month.
Offline MickB
« Reply #967 on: August 17, 2016, 03:12:50 PM »
Thanks CB 750
« Reply #968 on: August 17, 2016, 06:20:49 PM »
All current contenders should be relieved it wasn't this month  ::)
Truth!!
Offline MickB
« Reply #969 on: August 18, 2016, 04:22:53 AM »
Thanks Cal
« Reply #970 on: September 12, 2016, 07:17:53 AM »
Cal and I thought your bike deserved another shot at Bike of the Month, so it's been nominated.
Please post that you accept in the nomination thread:  http://forums.sohc4.net/index.php/topic,160567.0.html
Offline MickB
« Reply #971 on: April 11, 2017, 10:03:26 PM »
Well I'm back again and very motivated to fix some problems with the CB500, now with 36 miles on the clock. I know I've been very slack.
I have some oil leaks (main oil seal behind the alternator, head gasket and I think the little O rings on both sides of the barrels top and bottom (where the oil feeds up to the top end) and I need to replace the cam tensioner.
Q. What are the best gaskets to get, as I think I bought cheap gaskets and they've proven to be dodgy.
Q. Can I replace the main seal (very carefully) with out having to pull the engine out of the frame?
« Reply #972 on: April 11, 2017, 11:45:44 PM »
I have built a lot of these and have never yet had a problem with any gasket kit but saying that never used Athena, both head and barrel surface need to be flat and clean, original Head gasket has a "Sticky" substance round the oil feed holes and cam chain tunnel,
Bad news is that crank seals have a lip so cases have to be split----Advise you to remove rotor before removing engine BUT are you sure its the crank seal and not the oil gallery plug "O" ring -----DO NOT spin the engine with generator cover of or you will shoot that plug into the darkest recess of your workshop and get a huge oil puddle under the bike. I have seen those plugs fitted backwards causing a leak, the little "Pip" faces outwards and is held by the cover.
What is wrong with the tensioner?
Offline MickB
« Reply #973 on: April 11, 2017, 11:52:13 PM »
 Thanks Bryan, I poked the seal in after the cases were together, but I think it went in perfectly. The oil gallery had a new plug and o ring.
I'll pull off the cover to see where it's coming from.
I was advised today to put a new gasket kit in it from the barrels up, which I think is a bit of an overkill, the head gasket is definitely leaking (advised to spray the new HG with a copper gasket compound). Also I think I may have the cam chain 1 tooth out!
More to come after I pull off the rocker box and have a look.
Offline MickB
« Reply #974 on: April 11, 2017, 11:53:00 PM »
I put the old tensioner back in and it won't adjust the chain.
