Author Topic: Stupid PO trick?  (Read 2336 times)
Offline Rgconner
Stupid PO trick?
« on: October 14, 2013, 11:11:07 AM »
So I finally got around to putting on my 520 conversion on the 550.
I discovered the FRONT sprocket appears to be a 520 already, but the back was still a 530?
Stupid PO trick?
Or is there a stock reason for the differences?
1975 CB550K aka "Grease Monkey"
Re: Stupid PO trick?
« Reply #1 on: October 14, 2013, 11:22:29 AM »
That's a new one on me.
Offline Bodi
« Reply #2 on: October 14, 2013, 04:26:57 PM »
No reason for the difference except maybe stupidity, incompetence,  or desperation. The 520 sprocket will work with 530 chain (not vice-versa!) and either the PO didn't have a clue and bought the wrong size (stupidity), a parts dude got him the wrong part (incompetence), or the old sprocket was really really bad and a 520 was all that could be found (desperation).
Offline lucky
« Reply #3 on: October 14, 2013, 07:12:07 PM »
You can get away with it for a while but it will eat up the chain and sprockets.
520 is the pitch between centers.
 So by using a #530 the pitch is longer.
Offline lucky
« Reply #4 on: October 14, 2013, 07:13:45 PM »
It is like telling someone to never weld on a gas tank that has had gas in it.
They will tell you that so and so does it all the time.
Then one day you realize you have not heard from them for a long time.
Offline tomkimberly
« Reply #5 on: October 14, 2013, 07:27:27 PM »
#$%* happens, live with it.
Tom K.
« Reply #6 on: October 14, 2013, 07:38:36 PM »
The second number in chain is WIDTH not Pitch
 520 is 2/8 or an inch wide
 530 is 3/8 of an inch wide
Looks like the PO did you a favor
Offline Rgconner
« Reply #7 on: October 14, 2013, 07:48:44 PM »
Well, looking at the number on the wheel, it says it is a 320!
15 tooth.
Replaced with a 520 18 tooth. Gonna be a different bike, that is for sure!
Offline KJ790
« Reply #8 on: October 14, 2013, 07:58:03 PM »
Not really, a 520 and a 530 are the same pitch. As mentioned already, the difference is in the width. You can get away with a 530 chain on 520 sprockets alright, but there isn't really any reason to unless you cannot find a 530 sprocket anywhere (which isn't the case for these bikes...). Chances are the PO had no idea what he was doing and got lucky that he mixed parts in a way that doesn't cause any issues.
Offline Rgconner
« Reply #9 on: October 14, 2013, 08:05:47 PM »
You know why he is named Lucky?
he is lucky if he gets it right.
I looked, there is no chain size I can find that is "320" so it is likely just a part number of some sort.
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
« Reply #10 on: October 15, 2013, 10:02:18 AM »
^^^^ ;D ;D ;D ROFLMAO THANKS "Rgconner"   ...cougar...
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
Offline lucky
« Reply #11 on: October 15, 2013, 12:18:09 PM »
Thanks for that detail info. I was told that number WAS the pitch.
Thanks for educating me on that.
Offline lucky
« Reply #12 on: October 15, 2013, 12:20:06 PM »
Everybody is wrong sometimes.
I admitted my mistake .
I usually use a #530 chain with a #530 sprocket so I have not run into any problems.
« Last Edit: October 15, 2013, 12:23:14 PM by lucky »
Offline Rgconner
« Reply #13 on: October 15, 2013, 11:46:28 PM »
Putting a 18 on it really changed the nature of the bike.
It is not nearly as fast off the line, but that is not as important to me. I would buy a crotch rocket if it was... take off from first is a lot less thrashy, and I hit 40mph at about 8K, so redline is probably 45ish now.
What is nice is that 55 mph is now about 3800K in 5th, and 65mph is around 5K. Much easier on the engine and me to be 1200 rpms lower. Vibration is not nearly as bad.
4th is now just under where 5th was, and 5th is now a suitable 6th. With the 650 cam in the bike, top end power is still good. I can crack it open at 65mph and it goes to 70 or 75 right quick.
4th is now a better climbing gear and I don't think I have to thrash between 4 and 5 so much on the local roads.
17 might have been a better choice, but this is fine for now.
« Reply #14 on: October 15, 2013, 11:53:28 PM »
the stock 17/37 setup gives around 5000 rpm at 100kph(60mph).
Offline trueblue
« Reply #15 on: October 16, 2013, 04:03:07 AM »
Where did you get your 520 sprockets?
1979 CB650Z
Offline Rgconner
« Reply #16 on: October 16, 2013, 07:32:30 AM »
http://sidewindersprockets.com/index.html
call up and talk to the man, he will get you what you need.
Be prepared to wait, he has to send them out for machining and if it is an aluminum sprocket then it has to be re-hardened.
The chain he provides is really nice too, worth getting unless you already have some 520s O-ring lying around.
Offline trueblue
« Reply #17 on: October 17, 2013, 01:29:36 AM »
Thanks mate, I'll get onto him ;D
1979 CB650Z
