Author Topic: Mini speedo (or tach) replacement bulb?  (Read 616 times)
Offline Scott S
« on: October 14, 2013, 04:51:21 PM »
Picked up one of those generic mini speedometers for nearly free, but it's missing the bulb and wires. Anyone figured out a cheap and easy replacement? Maybe some type of LED from Radio Shack or something? It needs to have some type of rubber mount to press into the hole.
 The hole is roughly 8.7-8.8mm or approx. 5/16", best I can measure.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline bjbuchanan
Re: Mini speedo (or tach) replacement bulb?
« Reply #1 on: October 14, 2013, 05:27:46 PM »
They use these tiny minibulbs with a little foam grommet, they suck
I used the foam grommet to mount a single white led, with resistor so it doesn't blow. On all the time the way I wired but at night it is a gentle white, not blinding and daytime can't be seen.
Offline Scott S
« Reply #2 on: October 14, 2013, 05:40:38 PM »
 I'm missing the grommet or rubber or whatever, too. Where'd you get the bulb? I may stroll through Radio Shack tomorrow and check them out.
'71 CB500 K0
'81 Yamaha XS650
Offline bjbuchanan
« Reply #3 on: October 14, 2013, 05:45:07 PM »
From radioshack. It was a bare white led, one of the small "bright" ones, grab a pack of resistors if you use the plain bulbs, ln4001 I believe, it is 470 ohm, 1/4 watt. They are sufficient to not blow the led when you hit it with 12v
I hot glued them in to the grommet, I know you don't have them tho.. They may have something
