Author Topic: Looking for a 16" 16mm swingarm pivot bolt  (Read 1254 times)
Offline mono
  • Definitely no
« on: October 16, 2013, 06:27:33 PM »
Anyone by chance know of a bike that came with one that size?  I'm coming up empty all over the net.
Sent from my SPH-L710 using Tapatalk
Re: Looking for a 16" 16mm swingarm pivot bolt
« Reply #1 on: October 16, 2013, 09:06:48 PM »
 Just get 16 mm ground shafting, thread both ends.
Offline mono
  • Definitely no
« Reply #2 on: October 17, 2013, 09:51:20 AM »
Ground shafting like for lightning strikes?
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: October 17, 2013, 10:53:29 AM »
Ground as in grinding.
Offline mono
  • Definitely no
« Reply #4 on: October 17, 2013, 12:55:41 PM »
should it be stainless, hardened, etc?  also, if it's case hardened, how would i thread it? :/
« Last Edit: October 17, 2013, 01:00:10 PM by mono »
« Reply #5 on: October 17, 2013, 08:37:10 PM »
Turn and ground precision shafting is usually 1045, but you may be able to find 4140 will thread fine on a lathe. McMaster Carr may have it. The trick is to find it in a small quantity.
 If you have a Metal Supermarket  similar, near you, they usually sell small quantity
Offline mono
  • Definitely no
« Reply #6 on: October 18, 2013, 04:36:22 AM »
thanks, man.  just wanted to make sure i was doing it right -- google gave me too many options!  :)  I work for a hardware distributor -- I can special order anything I need for a small premium.
this would still be easier if i could just find a swingarm bolt the right size from another bike... going to check with my local old-jap-bike-used-parts dealer today to see if his vast knowledge or secret warehouse full of stuff yields anything.    if not, it's fabrication time!
Offline mono
  • Definitely no
« Reply #7 on: October 22, 2013, 03:55:45 PM »
Decided on going with 304 stainless rod - at 10000 psi tensile strength I think it'll be ok unless I jump the bike off of a roof.
Got a quote from my local steel supplier for $21 for 18".  Hard to beat.
