Author Topic: Sandcast front rim/hub ID info  (Read 578 times)
« on: October 16, 2013, 11:44:59 PM »
  I picked up a mid 69 build date 750 and a 73 drag bike with an early front end from the same estate. The rear wheel and hub from the 69 was on the dragbike are there differences in the front rotor/hub/rim that I can detect in case they swapped the front wheel too? ::)  Square shoulder on the rotor edge? Anything else?
( I just dislike the term sandcast due to the A holes calling everything under the sun sandcast to sell it to people that don't know better. Now I have one, go figure.)
« Last Edit: October 16, 2013, 11:54:50 PM by Don R »
Offline BPellerine
Re: Sandcast front rim/hub ID info
« Reply #1 on: October 17, 2013, 02:36:08 PM »
the sandcast hub is in marks book Don you can see the diff clearly.bill
1978 CB 750K ard and webers
another anfob
Offline CycleRanger
  • No comment about being an
« Reply #2 on: October 17, 2013, 05:29:24 PM »
Best I can do is a K0 setup.
Here's the rotor, hub, and rim.
« Reply #3 on: October 17, 2013, 05:35:41 PM »
Very nice thank you. I promise, I'll stop obsessing now. The correct wheels and hubs are on the 5511.
Offline brandEn
« Reply #4 on: October 17, 2013, 05:38:41 PM »
Hi Don, I have a 69 front hub if you need one. It has been powdercoated though. PM if your interested.
