Author Topic: Wintergreen & Water - Photo Essay  (Read 2552 times)
Offline RSchaefer
« on: October 17, 2013, 02:34:15 PM »
OK I had several requests regarding my comments made in another thread about using Wintergreen to soften rubber, specifically - and most importantly for me - the rubber carburetor hoses, and I took several pictures during the process.
The Basics - '75, CB750F hoses seem to be hard as rock.  Purchased a quart of Wintergreen (horse liniment) from Amazon for $12.95 plus $6.50 shipping (does not appear to be synthetic).  Decided against the Xylene as its flammable and the process works best when the mix is heated using either Xylene or water.
False Starts - I purchased a used Crockpot as some on the forum had mentioned for $6, it had the highest wattage rating of the 6 or so they had there (250W).  It got the solution really hot (186 degrees) but never to a boil.  I left the hoses in for an hour, no change, two hours, no change, finally went to bed and let them simmer all night, no change.
Final Setup - Got out my old Coleman stove and used gasoline as fuel, and an old metal pail.  Had no problem getting it up to a rolling boil in 5 mins. or so.  I used enough water to cover the hoses and then some in the pail, lets say less than a gallon and 4 ounces of Wintergreen.
My wife happened to have this nice little metal rack that went into the bottom of the pail to keep the hoses off the bottom.
Once she starts boiling the oil kinda comes up to the surface and goes back down, I guess you could say emulsifies.
Here you can kinda see the oil droplets up at the surface
These were my original hoses and I am trying to squeeze them together in the picture.
Here is the after - I am able to squeeze them easily, more so on the carb side, less so on the head side.
Results - It worked, took about 45 mins. at rolling boil to start seeing an impact, ended up running it for 1.5 hours by the time I finished.
I also ended up throwing in a few other pieces from time-to-time and watched each piece carefully like the small rubber spacers in the battery box, maybe 10 mins.,  the heavy rubber bottom of the battery box, 15 mins.  In the case of the rubber from the battery box it was rock hard when I started and nice and soft when I finished.
The hose on the back of my air cleaner was rock hard and it took maybe 10 mins.  It did flare the ends but they did go back to normal shape after about an hour, probably should have left the clamps in place instead of pulling them back.  This was just a test on the hose I was going to be replacing them with new.
Rock hard
After process
Flared Ends
Lessons Learned - Probably should keep it at a rolling boil rather then a high boil as I think the Wintergreen boils off quicker at a high boil.  I mean you get going and it looks like its going to work so you think OK more heat gets the Wintergreen further into the rubber.
I should have added more water initially, as it boiled I was loosing water and had to add some which slowed down the process.  But - maybe I should have not had it at such a high temperature?
I do not have a brand new pair of hoses to compare as far as the ability to squeeze but it seems the head side of the hose is harder to compress then the carb side and its maybe a little thicker in this area.  Sooooo maybe its harder to get the Wintergreen deeper into the rubber.  I think you would have to experiment a little with coming up with the "best" temperature to keep the rolling boil at, which get the best effect.  Maybe a higher concentration of Wintergreen would penetrate deeper?
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline brooze72
Re: Wintergreen & Water - Photo Essay
« Reply #1 on: October 17, 2013, 02:48:54 PM »
Thanks for documenting this process.  Maybe you could do a follow up squeeze test periodically as I am curious as to how long it will take to revert to hardness.
1972 CB500K1 - restored rider
1981 CB650C - new project
Offline RSchaefer
« Reply #2 on: October 17, 2013, 03:23:02 PM »
Well I kinda was concerned about that as well, before I ever tried it and several other members on the forum have had good long-term results, the longest was 5-years.
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline 750K
« Reply #3 on: October 17, 2013, 04:42:12 PM »
I did a full set plus a couple spares for my 77k a year ago with water and wintergreen oil, the spares are still soft and pliable. They're sitting in my tool chest in an in heated garage, I check them periodically when I pull a torque wrench out of that drawer. The ones on my bike are the same and as a bonus when I'm in traffic I can still get a whiff of wintergreen from the carb rubbers, it never really goes away it seems.
77 Cb750, 78 Kz1000
Offline RSchaefer
« Reply #4 on: October 17, 2013, 04:45:46 PM »
Good news - bad news "it never really goes away it seems."
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline 750K
« Reply #5 on: October 17, 2013, 04:49:24 PM »
Haha, I actually like it. Once you get them on the bike and put a few miles on them you only can smell it when the bike is running and they heat up a bit, way worse things they could smell like as far as I'm concerned.
77 Cb750, 78 Kz1000
Offline RSchaefer
« Reply #6 on: October 17, 2013, 07:56:27 PM »
Thats the good news!
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline Geeto67
  • A grumpy
« Reply #7 on: October 18, 2013, 04:24:51 AM »
FWIW fuel is a catalyst in the rubber hardening process. The head side of the rubber sees the most exposure to fuel, the carb side the least (since it is mostly wrapped around the outside of the carb body).
Maintenance Matters Most
Offline Deltarider
« Reply #8 on: October 18, 2013, 04:32:56 AM »
Now, what is wintergreen in Dutch? Anyone?
« Last Edit: October 18, 2013, 04:42:34 AM by Deltarider »
CB500K2-ED Excel black
« Reply #9 on: October 18, 2013, 04:37:26 AM »
Now, what is wintergreen in Dutch? Anybody?
wintergroen
Offline LesterPiglet
  • 1977 CB550F2
« Last Edit: October 18, 2013, 04:52:51 AM by LesterPiglet »
« Reply #11 on: October 18, 2013, 04:55:53 AM »
  • 1977 CB550F2
« Reply #12 on: October 18, 2013, 04:57:47 AM »
I just found 100% and updated the link.
Offline Deltarider
« Reply #13 on: October 18, 2013, 08:05:58 AM »
wintergroen
First thought you were kidding me. Then found out wintergroen is a plant. I'd never guessed.
Offline kghost
« Reply #14 on: October 18, 2013, 10:03:08 PM »
This is gonna sound kinda weird.......
I just throw those in a can filled with ArmorAll and leave them soaking for a week....
Makes them super pliable and supple if your not in a hurry.......
Total work time 5 minutes if you don't mind waiting while they soak......
Stranger in a strange land
Offline RSchaefer
« Reply #15 on: October 19, 2013, 05:14:11 AM »
Good for you, if that works great.  Wonder how long it will last and stay soft?
I had heard about the ArmorAll and others have also mentioned brake fluid but I never heard how long it lasted.  The one member had used the Wintergreen and it was still soft 5-years latter.
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline Bailgang
  • Scott
  • Indiana
« Reply #16 on: October 19, 2013, 09:53:01 AM »
Glad to hear it worked for you but I did the same and a week later they were still just as hard as they were when I first threw them in to soak.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
