Author Topic: CB350f Performance Questions  (Read 14047 times)
Offline s_vandise
    • Vandise Rails Development
« on: October 18, 2013, 02:55:45 PM »
I've worked/collected honda's 350 twin bikes and acquired a '74 350 four a few months back.
This bike needed a lot of work, rebuilt the upper engine, brakes, electrical, etc, hence the reason I've only gotten to enjoy riding it this past month.
My experience with the twins, (I'm a 155lb rider) is that in high gear between 4500+ rpm that it accelerates rather efficiently above and beyond 60. The 350four...Not a whole lot happening below 5500+. I would suspect this considering I used the stock 47mm pistons.
What I've noticed is while I'm cursing along in high gear around 5500rpm that it accelerates rather slowly to around 60 and then begins to pick up the pace. I don't suspect any carb issues as In 4th I can easily go past 8k (but prefer not) rpm and accelerate reasonably in high. It also has a lot of "giddy up" that makes me all excited inside. I'm considering to redo/clean the carbs as the tank wasn't spotless of rust (and the petcock filter doesn't catch everything).
I'm curious to what other 350f owners have experienced with acceleration on their bikes.
Some bike specs:
Aftermarket 4-4 exhaust system (carb jetting didn't have to be changed)
Carbs have been rebuilt with all stock jets, needles, gaskets, floats, and cleaned several times with chem dip
original ignition, new points/spark plugs/rocker arms gapped properly, bikes timed perfectly.
'73 CL350 | '74 CB350f | '73 SL350 | '71 triumph t120R
Offline bender01
Re: CB350f Performance Questions
« Reply #1 on: October 18, 2013, 05:31:25 PM »
Ive had both and the four was smooth but not peppy til it was wound up! Its been four or five years but don't they redline at 10,500? I used to redline mine or close all the time!
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
« Reply #2 on: October 18, 2013, 07:11:07 PM »
just downshift it next time.
« Reply #3 on: October 18, 2013, 07:31:15 PM »
When the 350F debuted in 1972, Cycle Magazine loved it until they took it to the drag strip with their "shop" CB350 twin. The Twin beat the Four at the strip, handily. They both make about the same 36 HP in stock trim, but the Four is almost 80 lbs heavier. It isn't a 'performance' machine.
In response to those scathing reviews (and Cycle was the original "we love Hondas" rag in those days) Honda made the CB400F, a whole 'nuther kind of ride, with lower gear ratios, a 6-speed close-ratio gearbox that is easily the best of the SOHC4 collection, and almost 10 HP more, nudging the CB550F from behind.
The 350F also came in a 250F version, all the same except the piston size, and a lighter crankshaft (and smaller valves), IIRC. This suggested just how popular the Fours were in Japan and some Euro countries, more for the cool factor than anything else: the 250 only makes about 17 HP! There were/are some awful taxes on bikes bigger than 251cc in those countries.
The 350F is probably the smoothest bike Honda ever built, when it is set up right and tuned well. It was also so insanely quiet that you could not hear it running in traffic! And, it will wind clear off the tach: so does the 400F, without a whimper. The cam on the 350F doesn't start its show until 5500 RPM, and the 400F until 7000 RPM. They live to rev!
One of the more interesting facets of the Baby Fours is their incredible durability, when compared to the Twins of the same displacement. The Fours will easily run well past 50K miles with nothing more than oil changes and tuneups now and then, while the Twins rarely reached over 25k miles without significant help. In the days of 55 MPH speed limits, the 350F/400F bikes were seen touring the interstates everywhere, often 2-up, some even pushing Windjammer fairings (I even installed some of those myself on them), happy as can be!
It took me over 35 years to finally get one myself. It's a wreck in appearance, but it looks like a gem in the rough to me: next summer it will rise again. :D
Offline tomkimberly
« Reply #4 on: October 18, 2013, 09:19:16 PM »
Any 350F runs best at 9-10k RPM, anything lower and you're not riding it right.
Tom
« Reply #5 on: October 18, 2013, 09:41:53 PM »
Downshift.
 5500rpm is to low to get good acceleration on throttle twist.  Get it up above 6500 and then hammer it.   8)
« Reply #6 on: October 18, 2013, 09:45:34 PM »
downshift,if you aint spinning at 6500 your out of the power band and only cruising,these have a pretty short stroke,the actual piston speed is slow compared to the rpm.
Offline kghost
« Reply #7 on: October 18, 2013, 09:55:12 PM »
I'll comment since I have one of each.....
Spin it up 6000+ is its happy place.
Stranger in a strange land
Offline HondanutRider
« Reply #8 on: October 19, 2013, 06:50:10 AM »
s_vandise, you have correctly identified the traits of the 350 Four.  But isn't it a lovely machine to ride and admire? ;)
I have a low-mileage 1974 model of the CB350-F, as well a 1962 CB77 that I used to ride a lot in the 1960's.  I've ridden both back-to-back and can attest that the CB77 is definitely the quicker of the two.  But that 350 Four is sooo smooth. 8)
Offline s_vandise
« Reply #9 on: October 23, 2013, 07:13:23 PM »
Thanks everyone for the input, and HondaMan for your thorough answer. I really do love this machine and I worked really hard to bring it back to it's former glory. It's a vary unique riding experience and interesting machine to work on. Still needs some adjustments, but I have all winter.
Mine once was a train wreck, but it's turning into a thing of beauty.
Before:
After: (Tank only has a base coat on, too cold and humid to paint for now)
« Reply #10 on: October 23, 2013, 08:02:02 PM »
...but it's turning into a thing of beauty.
Before:
Wow, is THAT an understatement!
Offline Shane72
« Reply #11 on: October 24, 2013, 10:28:36 AM »
...while I'm cursing along in high gear...
I do that all the time.
Shane
I mount and balance MC tires--while-you-wait service by appointment.  Send me a PM.
« Reply #12 on: October 24, 2013, 10:40:18 AM »
Whats the status of your air filter?
Emulsion tubes are clean of debris? Not just chem dipped.  I mean pulled out, inspected, cleaned and replaced.
I would bet a lean mid range.  your pipes may be more free-flowing than OEM.
Drop needle clip one position, and go up to #78 jets.
Offline s_vandise
« Reply #13 on: October 24, 2013, 11:53:28 AM »
The previous air filter wasn't bad but I did replace it just this morning. Everything literally has been cleaned by hand as well as chem dip (chem dip didn't eat away all the old fuel rosin). I was going to try different jets just to see if there was any noticeable difference (I believe I have #75's in now). With the new filter and a plug check it's running a little more lean than I would like so I'll take your advice and give it a go before the snow comes :D
Heh thanks. Took over 300 hours of dedication and countless failed attempts over the months. It isn't and won't ever be perfect; but that's the beauty of it.
« Last Edit: October 24, 2013, 12:10:24 PM by s_vandise »
« Reply #14 on: October 24, 2013, 12:02:01 PM »
#80 mains would work too.  its only .000787"  more  ;D
let us know how it goes.
« Reply #15 on: October 24, 2013, 12:09:31 PM »
 ??? From picture, exhaust looks stock.
Offline s_vandise
« Reply #16 on: October 24, 2013, 12:21:04 PM »
I ordered them from Sport Wheels here in Minnesota for $550. They said they were lightly used but I didn't even notice a scratch or slight sign of rusting. I assume aftermarket considering the quality.
[/quote]
Will do. It's a matter of whether or not the USPS can beat the snow now  ;D
« Reply #17 on: October 24, 2013, 12:28:37 PM »
chrome on OEM mufflers was thin and pitted easily.
if those are OEM's, you scored @$550  :o
any stampings on them?
Offline s_vandise
« Reply #18 on: October 24, 2013, 12:41:20 PM »
There are. Not sure if all are stamped  "HMCB350F IR HM333" on the bottom, but it's what's on the bottom right muffler. I didn't ask too many questions when Sport Wheels said they acquired a 4-4 exhaust system for the 350F and mentioned the price.
Offline knowsnothing
« Reply #19 on: October 24, 2013, 12:43:19 PM »
Tom
+100  ;D
1978 CB750k Blue - for sale
« Reply #20 on: October 24, 2013, 10:11:39 PM »
If they ever come up with another set, have them call me?
Mine are terrible...
The stamping you mention may be for "Inner Right" pipe (the "IR" designation).
Offline lucky
« Reply #21 on: October 26, 2013, 10:27:42 AM »
I was a Honda mechanic at that time.
The CB350 twins had a lot of vibration compared to the 350F.
The interstate freeway system had just finished being built, so many riders wanted bikes that could go long distances at 70 mph which was the speed limit at that time. The 400F was perfect.
The fours were glass smooth.
I waited until the 400F was introduced and bought one of the first ones.
It had the 6 speed gearbox and that made it a lot better than the 350F.
The 400F looked better too.
You might try one less tooth on the countershaft.
It just depends how much freeway driving you do.
If you drive mostly  on country roads then change that countershaft sprocket.
(Front  sprocket) to the younger guys. LOL
Offline Deltarider
  • I'm back
« Reply #22 on: October 26, 2013, 11:23:00 AM »
The 350 Four is like a good friend, robust and reliable. Soichiro Honda himself considered it his best bike. Early '80s me and my girl did a six weeks trip through France, Italy and Greece, totalling 10.000 km. The only problem she encountered - in a blazing hot Peloponnesos - was a front brake that got stuck. It was easily freed by a helpful Greek tractor mechanic. My friend was comfortable following me at 130 km/h for hours on end. Ofcourse you'll have some crosswind every now and then. Nothing to worry about, so do I on my 500 which is only 13kg heavier. A trained bikerider knows he will not be 'blown away'. It's one of these jokes that's echoed over and over again, mostly by people that have set their mind on a weightier bike anyway.
« Last Edit: October 26, 2013, 11:24:56 AM by Deltarider »
CB500K2-ED Excel black
« Reply #23 on: October 26, 2013, 11:37:08 AM »
Lucky, would you also consider putting an O-ring chain on it too? ;)
« Reply #24 on: October 31, 2013, 09:36:07 PM »
Delta: did you also know it was the only Honda that Sochiro actually bought for himself? After he stepped down as head of Honda in 1973 he rode it to work on the production lines (he liked to work alongside his employees, wearing the white coveralls with everyone else!).
There is a fellow here in Colorado who has a custom bike shop: he is a Japanese immigrant (1984) who worked at Honda when he was in High School (equivalent) on the production lines, and worked many times next to the aged Sochiro. His name is Axel (fitting for his shop?), and he said Sochiro was 'just a normal guy like everyone else, loved to work on engines'. And, he was still riding his 350F to work when Axel knew him!
