Author Topic: Are These Gasket Seats Ready To Go?  (Read 1153 times)
Offline TheWhiteSamoan
« on: October 18, 2013, 03:55:44 PM »
I used a gasket prep set by 3M and this is how the gasket seats (valve and cylinder head) came out. As you can see in the closeups, there is a little pitting and scratches here and there, so I don't know if this is an issue or not. Also, how do the valves look? I haven't used grinding compound to match each valve yet, so I'm sure they will come out looking smoother, but otherwise how are they? And how about the lip/seating where the cylinder contacts the valve head?
Many thanks
Aaron
« Last Edit: October 18, 2013, 04:02:10 PM by TheWhiteSamoan »
Re: Are These Gasket Seats Ready To Go?
« Reply #1 on: October 18, 2013, 04:08:43 PM »
More photos
Offline bjbuchanan
« Reply #2 on: October 19, 2013, 04:15:26 PM »
That gasket surface is definitely good to go. For the valve seats you use the compound and use light pressure until the seats are a dull gray. Wipe the grinding compound away to check how the surface looks as the compound itself is dark gray in color
« Reply #3 on: October 20, 2013, 07:18:06 AM »
Thanks! This is the first engine I've rebuilt, so I've had many questions along the way. I'll try to post photos to this forum once I'm done with the bike. (It's a '72 CB500).
