Author Topic: Sidecar  (Read 120668 times)
Re: Sidecar
« Reply #25 on: December 08, 2013, 04:39:10 AM »
This is 1" tubing, fits over the 20mm just about perfectly.  The washers are actually cutouts from some project in 16 gauge.
Re: Sidecar
« Reply #26 on: December 17, 2013, 06:37:11 PM »
Right front engine mount will be one of the four mounting points. M18 bunk to be welded in.
Re: Sidecar
« Reply #27 on: December 28, 2013, 07:27:34 AM »
I have to make quite few of these, still needs to be filed flat and drilled for M12 bolt.
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
Re: Sidecar
« Reply #28 on: December 28, 2013, 09:03:06 AM »
Whazzat, exactly?
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
Re: Sidecar
« Reply #29 on: December 28, 2013, 10:10:55 AM »
Offline rb550four
Re: Sidecar
« Reply #30 on: December 28, 2013, 11:02:46 AM »
Looks like adjustable bike to sidecar mounts to me.
Re: Sidecar
« Reply #31 on: December 28, 2013, 12:42:46 PM »
Yes, anchor point @ right front engine mount.
Re: Sidecar
« Reply #32 on: December 28, 2013, 02:13:33 PM »
I will try to get pics of my sidehack mounts, most of the time swivel, or double swivel capacity, makes things easier..
Re: Sidecar
« Reply #33 on: December 28, 2013, 04:21:23 PM »
Thank you, Frank. I am doing variation on Velotex mounts.
Offline DustyRags
Re: Sidecar
« Reply #34 on: December 28, 2013, 08:12:16 PM »
Nifty, thanks!  8)
1976 CB550K- sold
Re: Sidecar
« Reply #35 on: December 29, 2013, 03:13:20 PM »
 The black V mount, bolts to left side motormounts.. Dyno side.  Lefty hack..frame slides in and clamps. The other slides over rear part of frame, and mounts to rear passenger peg mount.
« Last Edit: December 31, 2013, 08:28:19 AM by 754 »
Re: Sidecar
« Reply #36 on: December 29, 2013, 03:17:12 PM »
..the aluminum block mounts to frame, up below the steering neck. The other mount goes in outer front corner of frame. A threaded rod fits between the two, and stabilizes the outer part of hack to the bike frame.  Then the threaded rod between the mounts, can easily adjust the angle of the sidecar chassis to the bike frame, and take up any play. I ran a less adjustable one from rear shock mount to the outer side of the sidecar frame.
« Last Edit: December 31, 2013, 08:26:50 AM by 754 »
Re: Sidecar
« Reply #37 on: December 30, 2013, 04:07:54 AM »
Thanks, Frank, that helps a lot!
Re: Sidecar
« Reply #38 on: January 11, 2014, 01:49:53 PM »
Fabricating components while waiting  for the hernia to heal.
I am not allowed to lift anything over 10#, that certainly slowed me down.
M18 bungs for connecting rods.
Offline MoMo
  • Ride like you're invisible
Re: Sidecar
« Reply #39 on: July 06, 2014, 08:26:21 AM »
Status???
Re: Sidecar
« Reply #40 on: July 06, 2014, 03:41:45 PM »
Back burner, Larry. I need to get my jeep on the road first - transmission - than comes K3F and after that the sidecar :)
Re: Sidecar
« Reply #41 on: February 10, 2017, 10:30:04 AM »
Two bloody years since the last post.   >:(
Anyway, tie rod blanks from McMaster will be threaded M14 for Velorex style sidecar clamps.
Offline grcamna2
Re: Sidecar
« Reply #42 on: February 10, 2017, 10:54:07 AM »
subscribed
75' CB400F/'bunch o' parts'
Offline GV1390
  • Express Gratitude.
Re: Sidecar
« Reply #43 on: February 10, 2017, 11:02:38 AM »
I love my sidecar.....granted it's driven by a Russian machine.
Looking forward to see some progress out of this!
08' Ducati S4RS, 71’ CB500, 71' CL350, 72' R90/6, 16' Ural Gear Up & 02' ZRX1200R.
Re: Sidecar
« Reply #44 on: February 10, 2017, 11:47:22 AM »
Friend of mine - US expat living in Prague - had Ural, interesting piece of machinery, lol.
Ural or Dnepr are the only motorcycles where finding metal shavings in the oil pan is nothing to worry about - they are left there from the factory  ;D
Offline WesTenRacing
Re: Sidecar
« Reply #45 on: February 11, 2017, 08:28:50 AM »
My brother is a side car guy!  My buddies dad bought a Dnepr new in 1980 and we rode the wheels off it for years.(45 minutes at a time in the summer - it would overheat and detonate so bad you had to let it cool off for half an hour).  My brother thought it was cool looking so -  a very long story short - he bought one and an BMW donor (1000 cc) and graphed the drive train into the Dnepr.  Turned out good.  That was in about '84 and he's been riding ("piloting" for you sidecar guys) it ever since.  He even did some safety wiring etc (to pass tech) and rode it to Maxton NC to land speed race. I think he may have just broken 100mph in the mile! Edit: In April '06 he went  98.752mph - a record at the time in  SC/PG 1000/4
« Last Edit: February 11, 2017, 10:15:21 AM by WesTenRacing »
Re: Sidecar
« Reply #46 on: February 28, 2017, 05:32:51 AM »
Really bad picture of clamp mock up.  I might use SS for the strap.
Re: Sidecar
« Reply #47 on: March 02, 2017, 11:53:54 PM »
 I've got an NHRA chassis shop nearby and Drag race too. I'm thinking of using clevis' and heim end mounts with an adjustable tube with left and right threads to set toe and camber. That is if I ever build one. I'm leaning toward a cycle x 3 wheeler.
Offline koendd
Re: Sidecar
« Reply #48 on: March 03, 2017, 04:39:19 AM »
cool project!
question about the bearing spacer though. How do you keep it ligned up in the hub?
Or did you allready calculate the fact the bearings are thinner and made the spacers bigger/longer than the original one?
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Re: Sidecar
« Reply #49 on: May 04, 2018, 04:49:19 AM »
cool project!
The spacer is a copy of what Honda used on the front wheel.  I just made it for the 20 mm axle.
But i decided not to use this wheel, got a Comstar to match Red's rear wheel.  Also 18" instead of 19" will help with the geometry.
