Author Topic: Sidecar  (Read 105987 times)
Offline MoMo
  • Ride like you're invisible
Re: Sidecar
« Reply #75 on: August 24, 2018, 12:40:25 PM »
I can see why as that is one nice looking rig
Re: Sidecar
« Reply #76 on: August 25, 2018, 02:24:47 AM »
I believe the sidecar is Tuma - name of the maker - but that Jawa is 500 OHC.
Re: Sidecar
« Reply #77 on: August 28, 2018, 06:24:12 PM »
Bike Exif has a pretty 550 with side car...give it a look... Forget the name of the shop but it began with an A.
Re: Sidecar
« Reply #78 on: August 30, 2018, 03:18:09 AM »
Thanks, I will check them out, seems like there are quite few.
Re: Sidecar
« Reply #79 on: September 10, 2018, 06:42:47 AM »
Rainy weekend, spent some time machining.  This is the future swing arm.
Re: Sidecar
« Reply #80 on: September 10, 2018, 06:56:02 AM »
Mocking up.  The Air shock position will be adjustable to set the height of the swingarm above the frame.
Next I have to shape the swingarm and make some plates to box it, welding it all together is the very last step.
« Last Edit: September 10, 2018, 07:10:04 AM by 70CB750 »
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=7ggnbmm1pohfk18uf1lakm32t4&/topic,60973.0.html
Re: Sidecar
« Reply #81 on: September 11, 2018, 02:38:20 AM »
oh..you got a HP 11C....my vife still use her"s..think it are 20+ years old...a bit tricky for a maskinist like me..but those vho learned to use it hold on for life...
i hate all this v-w.... vords
Re: Sidecar
« Reply #82 on: September 11, 2018, 04:09:19 AM »
I love RPN and HP calculators.   I have HP41C from my college days I still use.
This one is from my dad, he gave it to me because he was not using it anymore.  I keep this one in my shop.
My dad was - retired now - structural engineer mainly dealing with steam turbine blades and such.
« Last Edit: September 11, 2018, 04:16:03 AM by 70CB750 »
Re: Sidecar
« Reply #83 on: October 11, 2019, 07:38:55 AM »
Swingarm.  I am trying to finish some long overdue projects, the sidecar is one of them.
Re: Sidecar
« Reply #84 on: October 11, 2019, 07:40:52 AM »
Good night, six years since I started.   >:(
Re: Sidecar
« Reply #85 on: October 14, 2019, 03:26:05 AM »
Connecting links from DOM tubing.
Re: Sidecar
« Reply #86 on: October 16, 2019, 08:27:02 AM »
Nice progress
Re: Sidecar
« Reply #87 on: November 18, 2019, 01:39:47 PM »
Swingarm assembly.  Ready to be bolted to the frame
Re: Sidecar
« Reply #88 on: December 14, 2019, 06:47:48 AM »
If I decide not to use the brake caliper I will shorten the axle but for the first test this will do.
Not sure what to use to cover the center of the wheel.
Re: Sidecar
« Reply #89 on: December 14, 2019, 01:59:55 PM »
Hey Prokop...what about modifying a sprocket carrier to fit?
Re: Sidecar
« Reply #90 on: December 15, 2019, 03:36:05 PM »
Good idea, I will see whats available in my stash.
Re: Sidecar
« Reply #91 on: December 15, 2019, 03:41:36 PM »
First test ride ended in a ditch. After adjusting toe in and lean out I was able to ride around the block. Left turns still scare the #$%* out of me.  Now I need to build a cargo box to put some ballast in.  Overall I am happy with it.
Offline bear
  • Leeton in Australia
Re: Sidecar
« Reply #92 on: December 15, 2019, 06:30:12 PM »
G'day Prokop,
I hope you won't mind me sticking my bib in now you've reached your setup stage.
K model Hondas have a relatively short wheelbase used as a sidecar platform.
Your chair looks fairly wide so I'm assuming your track is wide relative to your wheelbase.
If your interested in a discussion on setup and maybe a couple of initial riding tips let me know.
If not I'm happy to keep my nose out.  ;)
Brian
« Last Edit: December 16, 2019, 09:04:58 PM by bear »
Re: Sidecar
« Reply #93 on: December 16, 2019, 03:51:29 AM »
G'day Prokop,
If your interested in a discussion on setup and maybe a couple of initial riding tips let us know.
Brian
Thank you, Brian.  I did not do any measuring yet, just set it up by eye and feel.  I will definitely reach out to you when I know what I am looking at.
Re: Sidecar
« Reply #94 on: December 16, 2019, 06:33:09 AM »
Looks good, nice job!  Only a 6 year project!
Sorry, I cant help with setup but I think Bear raced "hacks" for awhile, so he should be able to.
Offline bear
Re: Sidecar
« Reply #95 on: December 16, 2019, 03:46:55 PM »
G'day Prokop,
Brian
No worries. One small thing though, just to help dodge that ditch.
"Roll throttle OFF when turning left."
"Roll throttle ON when turning right."
Brian
Re: Sidecar
« Reply #96 on: December 17, 2019, 03:42:56 AM »
G'day Prokop,
Brian
Brian
Thanks!  The ditch actually happened on a straight piece of road - and on the other side than I was riding.  I guess toe out will do this to you :)
Re: Sidecar
« Reply #97 on: December 22, 2019, 05:18:30 AM »
Sidecar opens all kinds of possibilities  ;D
Offline Erny
Re: Sidecar
« Reply #98 on: December 22, 2019, 09:36:13 AM »
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Re: Sidecar
« Reply #99 on: December 22, 2019, 12:54:50 PM »
Hope thats NOT what you have in mind to do!
