Author Topic: CB750: Side to side play at rear axle  (Read 2070 times)
Offline zeech
« on: October 22, 2013, 12:19:15 AM »
I pieced together a Super Sport rear end from parts off eBay:
1) Swing arm
2) Complete rear axle and all hardware
3) Rear disc brake mount/caliper
Now I'm having some side to side play when I have the axle nuts tightened as far as they will possibly go, almost like I'm out of thread on the nut side. I just realized I don't have any washers on the far outside ends of the bolt head and nut, maybe that's all it is? It seems 2 washers might do the trick. Would new bearings and seals do anything?
See the pic below for where the chain tighteners aren't getting fully flattened and are causing the play.
« Last Edit: October 22, 2013, 12:22:21 AM by zeech »
Offline spazz1984
Re: CB750: Side to side play at rear axle
« Reply #1 on: October 22, 2013, 12:33:05 AM »
You may have the wrong spacers or just the wrong one on the inside of sprocket hub
Sent from my SPH-L710 using Tapatalk
« Last Edit: October 22, 2013, 12:36:14 AM by spazz1984 »
« Reply #2 on: October 22, 2013, 01:50:55 AM »
+1
Did you check your assembly against a schema like the one at CMSNL?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: October 22, 2013, 03:53:05 AM »
Verify the sprocket hub as well. F2/F3 and K7/K8 had a 10mm wider sprocket hub than the earlier models.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #4 on: October 22, 2013, 04:15:47 AM »
I think Wilbur got it.
« Reply #5 on: October 22, 2013, 05:10:33 AM »
That sprocket looks mighty close to the hub....
I believe the later hub used a different inner spacer behind the hub as well.
TAMTF...
Wilbur
Projects:
Offline zeech
« Reply #6 on: October 22, 2013, 01:46:33 PM »
What and how do I verify? The rear wheel, hub and sprocket is how it came.
Offline jpfrk2001
  • I hate being a
  • What was that!
« Reply #7 on: October 22, 2013, 02:08:46 PM »
You could add a washer to each side sandwiched between the adjuster and hub. Then just verify the alignment of the chain sprockets. These are just thoughts at a whim. As mentioned, different size hubs could cause a problem.
From the pics, I can tell that you are forcing the swing arm together. So it is not squared up. Looks scary to me.
I do tasks the most difficult way. My life is interesting.
1978 750K
1978 550K on a table
2009 Ducati Monster 1100
77/78 cool 2 member
« Reply #8 on: October 22, 2013, 02:10:12 PM »
CycleX has info on those hubs,check them out.
http://www.cyclexchange.net/Chain%20Sprocket%20Page.htm
Offline zeech
« Reply #9 on: October 22, 2013, 02:10:58 PM »
Yea it's definitely flexing in a bit. Much more than it should be.
Not sure how to fix the issue... I'm sure there are proper spacers out there, but not entirely sure which will fit.
Offline zeech
« Reply #10 on: October 22, 2013, 02:15:41 PM »
That looks like it might be the ticket. I'll measure when I get home. It looks like I might need to track down a 36mm hub... Ugh  :o
« Last Edit: October 22, 2013, 02:23:25 PM by zeech »
Offline zeech
« Reply #11 on: October 23, 2013, 11:16:26 AM »
Thanks very much for the help guys, the hub info really helped. Turns out the wheel I was using had a smaller hub, but I still had the original wheel from the bike so I was able to swap the hubs and it then went together perfectly tight with minimal tightening.
Really love this site and how helpful it is. Many of us would be lost without it.
« Reply #12 on: October 23, 2013, 11:26:21 AM »
Cool!
