Author Topic: CB-500 Chrome seat trim  (Read 3608 times)
Offline rtbmrgl
  • Got Points! Roseville, Ca
« on: October 22, 2013, 07:28:13 PM »
Hello,    I wanted to give a little info I did on restoring my seat cover on my 1973 CB500.  I used the old cover as it was in good shape but the chrome trim was not. If your cover is good but the chrome trim is bad here is a fix, it maybe temp or permanent, time will tell.  I used gas tank trim, it has an adhesive in the trim.
 I spread the trim and installed over the original trim. Get it warm and it will flex better, careful with heat gun it can ruin the trim if it gets too hot.  I clammed it, it took a day for the adhesive to stick.
Here is the trim I used.
http://www.chromedhog.com/Chrome-Trim_c72.htm
http://www.ebay.com/itm/6ft-Chrome-Edge-Protection-Trim-Kit-Motorcycle-Gas-Tank-Fenders-Windshield-/300784970952
p.s.   I also used this on my gas tank, thinner than original, but doable
photos-
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Re: CB-500 Chrome seat trim
« Reply #1 on: October 22, 2013, 09:10:22 PM »
good trick,maybe move this to the tricks and tips section?
Offline rtbmrgl
« Reply #2 on: October 23, 2013, 09:45:41 AM »
Ok will try to move.
thanks, Mark
Roseville, Ca
Got Points!
