Author Topic: 750F shocks on a 350F, will it work ?  (Read 1784 times)
Offline 72_350_FOUR
« on: October 23, 2013, 06:33:24 AM »
Im looking at putting 750F shocks on my 350F.  they look like they will fit. 2 resons.  1. I want to raise the back end about an inch which these will do, and  2. Im 6ft. 220 lbs, so thats the other reason.   Any reason not to do this?  such as it will effect the handling etc... ? Anyone tried this beofe with or without success ?
1972 Honda CB350F
Offline banzaibob
Re: 750F shocks on a 350F, will it work ?
« Reply #1 on: October 23, 2013, 06:49:41 AM »
Go for it.  The result of jacking up the rear end (on paper) an inch means that straight line stability will be (very) slightly different and it will turn a little sharper.  If this is a problem get a rear tire with a shorter profile or a front tire with a taller one.
2011 BMW R1200RT
1976 BMW R90/6
1977 Harley Davidson XLCR
1974 Honda CB750
1979 Honda XR/FT500
1976 Honda CB750F
1971 Honda CB350 Diesel conversion
1976 Honda GL1000
Offline 72_350_FOUR
« Reply #2 on: October 23, 2013, 06:59:43 AM »
Nice!  thanks for the quick reply...
1972 Honda CB350F
Offline Geeto67
  • A grumpy
« Reply #3 on: October 23, 2013, 07:50:21 AM »
buy a bigger bike. seriously, bikes are not always a one size fits all kind of deal. You can mod them within reason but let's be honest, you are probably better served with just a bigger physical bike.
1 inch should not make a big difference, but make sure you look at your chain. Some people fit taller shocks and don't realize they need to run the chain looser because when you jack the rear up you shorten the wheelbase slighly, however as the swingarm works through it's travel it will tighten up as it gets closer to parallel with the ground. The common mistake is to set the chain to factory tension with the back jacked up and then when you go over a bump and the rear compresses the chain gets streched too tight. Ideally set the chain tension at the maximum wheelbase length (usually swingarm parallel to the ground) or at least with the stock shocks in place and then install the new ones.
« Last Edit: October 23, 2013, 07:55:25 AM by Geeto67 »
Maintenance Matters Most
Offline 72_350_FOUR
« Reply #4 on: October 23, 2013, 08:17:54 AM »
ok good info thanks Geeto67, i see your in Cowtown also....   8)
1972 Honda CB350F
Offline Geeto67
  • A grumpy
« Reply #5 on: October 23, 2013, 08:47:12 AM »
yeah just moved here from Brooklyn. If you ever need any help IRL I'm around, just ping me. Only brought the cb750 and the Ducati and a small amount of tools but I'm always happy to help.
If you aren't a member of the Columbus Vinmoto Google Group you should sign up. Lots of knowledgeable and helpful people on there.
I learned the hard way about the chain - I ran 14.5" shocks on the back of my GS750 (stock is 13") and set the chain to specs with the bike unladen and jacked up in the back - first big bump while WFO in 1st gear and that chain let go. Learned a hard lesson that day and was lucky it didn't crack the cases (it snapped at the counter sprocket so no metal whip effect).
From then on when I had to set the chain tension I just compressed the rear with ratchet straps across the frame. When it was loose it made a terrible racket but I put 10K miles on that chain without a single issue. I also oiled it after every ride.
« Last Edit: October 23, 2013, 08:52:13 AM by Geeto67 »
