This weekend I took the carbs apart to clean the emulsion tubes, and boy were they funky! A bunch of sediment, so cleaning those is definitely going to be helpful I think. Also, I noticed that the carb cutaways that you bench sync with seemed very uneven and almost completely closed on a couple of the carbs. This was after I had vacuum synced them. So When I reassemble, I will bench sync again, then double check with gauges.
I also soaked the airbox boots in the xylene/wintergreen solution to revitalize them a bit, hopefully providing a better seal.
AJK, I think I have the idle screws set at 1.5 turns out. I will double check them and try setting them a bit leaner when I get things back together.
I will report beck when I can take it for a long enough ride to test for the weirdness.
