Author Topic: Purchasing a torque wrench: what range for whole bike?  (Read 7537 times)
Re: Purchasing a torque wrench: what range for whole bike?
« Reply #25 on: January 06, 2020, 11:08:04 AM »
deflecting beam are the best type,those click spring micrometer types have moving wearing parts and should be stored with the setting backed of to stop the spring from sagging.
« Reply #26 on: January 06, 2020, 11:37:51 AM »
But all torque wrenches are easy to check with a vice and quality spring balance
« Reply #27 on: January 06, 2020, 12:15:05 PM »
Avoid too powerful tools, easy to ruin the threads.
I use these models, 1/4" and 1/2" sockets.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.de%2Fulk%2Fitm%2F323892639480
 10-60Nm of same brand, Hazet.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.fr%2Fulk%2Fitm%2F303147262081
These work fine for all important      assemblies.
I borrowed a bad toque wrench and overtightened the head nuts snapping one new HD stud.  I tightened around 35Nm instead of 28Nm
That costed me a new set of HD cyl studs (all to be replaced to avoid later catastrophe), new head gasket, new valve cover gasket.
This was the job that made me to install Frank's frame kit that I have had great use of many times since then.
Bad (too cheap tools) can be expensive and waste of time.
Offline JamesReid
« Reply #28 on: January 06, 2020, 01:40:28 PM »
if you got the money get this,or the equivalent in kinchrome brand,i don't like the micrometer types.
https://sydneytools.com.au/product/warren-brown-321500-38-drive-5120nm-deflecting-beam-torque-wrench
what's the advantage of this mate? compare with normal torque wrench
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #29 on: January 06, 2020, 02:11:19 PM »
Back when I was assembling nuclear things we always used a torque wrench that had sufficient range so as to have the target torque fall in the middle third due to the upper and lower thirds tending to be inaccurate. This having been proven in a lab time and again.
And no, most folks won’t get a torque right by “feel”, also proven in a lab.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline rotortiller
« Reply #30 on: January 06, 2020, 03:57:48 PM »
You can get by with a 1/4" and a 3/8" drive torque wrenches. Pick sizes wisely.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #31 on: January 06, 2020, 04:23:08 PM »
Adequate torque wrenches aren't expensive, better to get a 1/4 in model for low torque bolts (under 20 lb/ft or so) and a 3/8 or 1/2 for over that.
« Reply #32 on: January 06, 2020, 09:10:42 PM »
If your "HD" studs snapped at 35Nm, then they were crap. That's just under 26 Ft Lbs. Grade 8 8mm studs will survive much higher than that. And the delta between 35 and 28 Nm is barely 5#. Your threads would have stripped if the stud was strong enough.
Blame the stud, not the wrench.
Maybe, but the torque must be right. Especially for the weak alu threads that Honda specify too high for most of the M6.
As I have understood the HD studs they are very rigid keeping the torque. Max specified is 22.5 ft lbs. When I continued to tighten them a few monrhs later they moved at 36Nm (26.55 ft lbs).
Most of these high tensile bolts have a narrow span to stay within for the spring force and avoid overtighten when the metal gives up, plasticizing.
Honda stock studs are more forgiving but will not hold up as well, flex more.
I'm happy with mine that did not cost much more than cheap crap at the cheap parts auto store I could have bought here locally.
« Last Edit: January 06, 2020, 10:27:08 PM by PeWe »
« Reply #33 on: January 06, 2020, 09:13:32 PM »
it is a normal torque wrench
Offline web
« Reply #34 on: January 07, 2020, 12:44:00 AM »
For most, just good is good enough. There's little advantage to 0.1% accuracy. Bolts themselves aren't manufactured, worn and cleaned by yourself to such tight tolerances anyway. Most of us also won't need a wrench that lasts a million bolts either. So no need to go overboard.
With all respect to people who take pride in having the best tool for every job, cheap HF can also be totally fine. If you calibrate it and it's way off, return it. Even the cheapest of wrenches can be well within 5% or so over a full 1:5 range, so one that isn't, is just broken and should be returned. Better than 5% IMO is unneeded for reasons above.
You can also just use it with your own calibration. Recalibrate every 1000 bolts or 10 years or so, whichever comes first... If you are a shop owner it's different of course, then a tool that lasts forever through abuse without needing this maintenance is worth the price.
It's never rocket science though.
« Last Edit: January 07, 2020, 12:48:32 AM by web »
« Reply #35 on: January 07, 2020, 01:03:03 AM »
at least any of them will get bolts all the same.
Offline JamesReid
« Reply #36 on: February 06, 2020, 06:50:03 PM »
Thanks for your great advice Dave.
« Reply #37 on: February 07, 2020, 01:18:52 PM »
The highest torque on these bikes is less than 25 ft-lbs.
Offline rotortiller
« Reply #38 on: February 07, 2020, 03:40:55 PM »
Swing arm is a bit higher at 40-50 ft/lb. You want that torqued up correctly.
edit:  Considering the rear axle is 60 or 70 ft/lbs a fellow might want something that does car wheels too when sizing up a tool.  Funny how nobody uses a torque wrench on axles LOL. Some values look pretty funky for the shocks.
« Last Edit: February 07, 2020, 04:06:54 PM by rotortiller »
Offline tlbranth
« Reply #39 on: February 07, 2020, 06:04:57 PM »
I have a 100 ft-lb old-style Craftsman which just indicates torque on a scale. I trust it. I bought a HF click wrench which was a POS. I wouldn't trust one. It never clicked off. I'da stripped threads if I'd tried it on a motorcycle. Let me just throw out this too: I only use a torque wrench inside an engine. The peripheral stuff is strictly by feel. You'll learn that as you go. Most stuff outside an engine just needs to be 'tight enough'. Axles need to be tight as you can get them.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #40 on: February 07, 2020, 07:30:27 PM »
+1. Twice.
I once built an entire 750 engine using a brand-new Snap-On click wrench (50 ft-lb max) set to 17.5 ft-lbs (Honda spec) and the bike leaked oil at startup. I had twice torqued the head (with the usual overnight wait between), and when I decided to check the outer nuts (by the sparkplugs) using my 40-year-old beam torque Craftsman wrench (25 ft-lbs max) I found them to be less than 115 in-lbs. The Snap-On was set to 18 ft-lbs, but put less than 8 ft-lbs on the nuts. Never used another one like it since that engine: had to pull it out of the frame again, tear it down to the head gasket for a new one, etc...  >:(.
« Reply #41 on: February 07, 2020, 08:09:38 PM »
I use the big warren and brown 1/2 drive for car stuff,goes to 200 lbs,the kinchrome 3/8 drive goes to 90 does any bike stuff.
Offline Tracksnblades1
« Reply #42 on: February 07, 2020, 08:30:43 PM »
Imner clutch and alternator flywheel maybe a little higher also.
🤔Thinking 28-30# for clutch and 68-72# for flywheel, but don't have the manual open...🤔
Age Quod Agis
« Reply #43 on: February 07, 2020, 11:36:28 PM »
figures the skip bin driver always has the best stuff
Offline rotortiller
« Reply #44 on: February 08, 2020, 06:35:19 AM »
Click wrenches work fine but the need checking once it a while.  Clamp the end in a vice and hang a known weight off it at 12 inches. Bar wrenches are great but cumbersome and crude, good for bikes, not so good working in confined and blind areas. I do not like electronic units as have had early failure issues (snap-on crap).
« Reply #45 on: February 08, 2020, 09:05:18 AM »
Important to set the click wrench to 0 direct after use and not have it pretensioned to the used torque during a longer period of time.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #46 on: February 08, 2020, 10:35:20 AM »
i have 2 i got from harbor freight.  3/8" 0-200inlbs and a 1/2" 20-150ftlbs.
about $20 ea.  accuracy is +/- 4%
+1
cb750 k6 - ugly
Offline tlbranth
« Reply #47 on: February 08, 2020, 10:50:02 AM »
Just checked. My Craftsman beam wrench was bought in 1969. Never needed calibrating.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
