SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
High Performance and Racing Forum
(Moderators:
Sam Green Racing
mlinder
Topic:
CB 500 57.75mm piston?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: CB 500 57.75mm piston? (Read 1753 times)
streetCB
Full Member
on:
October 25, 2013, 10:09:46 pm »
Hi,
Wondering if anyone can shed any light on the type of pistons I am running in my CB 500. When I purchased the bike the PO said it had a 605 big bore kit in it. I have recently pulled down the top end to inspect it and fix a small oil leak. on inspection it looks good but is not stock. However its doesnt appear to have the 605 dimensions either. As far as I can tell from this site the piston OD is 61mm whereas the piston OD in mine is 57.75mm with the bore measuring approx 58mm. This is an odd size? the biggest OEM overbore for standard 500 is 1mm which is 57mm and the base OD for the 550 is 58.5mm.
The piston and cylinders look good and I was hoping to go for a simple hone and new rings to accompany the new gaskets and avoid having to get a rebore and get new pistons as it was running 125psi and up on all cylinders. Does anyone have any clue about where I might find suitable rings for this piston and cylinder diameter. Thanks
Logged
754
Really Old Timer ...
Re: CB 500 57.75mm piston?
Reply #1 on:
October 26, 2013, 12:36:02 am »
THIRD oversize for 500 is what you want .75 over rings.
Logged
Kelowna B.C. Canada
streetCB
Full Member
Reply #2 on:
October 26, 2013, 01:38:36 am »
754,
appreciate the swift response but is that right? I thought 0.75 oversize would be 56.75mm? I hope you're right however.
Logged
classic bike tuner
Enthusiast
http://www.cmrch.nl/
Reply #3 on:
October 26, 2013, 04:36:12 am »
meaybe a std 550 piston 58,5 mm
Logged
754
Reply #4 on:
October 26, 2013, 08:03:43 am »
I think i read it wrong..read it as 57 being Std for 500.
Logged
Kelowna B.C. Canada
streetCB
Full Member
Reply #5 on:
October 29, 2013, 02:35:13 am »
So this is the inside of the piston. Anyone recognise the brand of this mark?
Logged
turboguzzi
Old Timer
Reply #6 on:
October 29, 2013, 06:13:28 am »
could easily be oversize pistons off some honda single, quite a common source for 500/4 pistons.
many people round here build 500/4 race motors with +0.50OS XL125S pistons = 57mm,
a +1.5 XL125S slug would be 58mm
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
(Moderators:
Sam Green Racing
mlinder
Topic:
